EHCS - BMW Luxury Touring Community
 1Likes
  • 1 Post By Voyager
post #1 of 10 Old Aug 2nd, 2017, 1:49 pm Thread Starter
EHCS
I would like to convert my EHCS to a manual center stand. Has anyone done this? The EHCS is a pain in the aftermarket.
ibeamhd is offline
post #2 of 10 Old Aug 2nd, 2017, 1:53 pm
bmwcoolk1200's Avatar
Re: EHCS
There are usually some available on Ebay. Changing it over should not be difficult. I am working on going the other way.
Gordon
Sugar Hill, GA
bmwcoolk1200 is offline
post #3 of 10 Old Aug 2nd, 2017, 2:36 pm
mr1150gs's Avatar
Re: EHCS
Not sure why this is a feature that is not appreciated other than it not working properly and needing a rebuild (not difficult to do). Can you elaborate on why/how it is being a pain?
BMWMOA - #47511
2007 K1200LT - Nice now!
1981 R100CS - Sadly gone
1986 K100RS - In the past
mr1150gs is offline
post #4 of 10 Old Aug 2nd, 2017, 3:41 pm
Re: EHCS
My 06 LT EHCS was needing a rebuild. 1.5 weeks with JZeiler and all is now good.
Sammy
Sent from my SM-G935V using Tapatalk
sgroover is offline
post #5 of 10 Old Aug 2nd, 2017, 4:52 pm
Re: EHCS
How often do they need rebuilding??
cbxchris is offline
post #6 of 10 Old Aug 2nd, 2017, 4:58 pm
Re: EHCS
When they leak faster than you can refill them
Gordon
Sugar Hill, GA
post #7 of 10 Old Aug 2nd, 2017, 6:08 pm
Re: EHCS
I read from others in this forum that the unit last about 5 years. Seals leak, and brushes in the motor wear out. I just pulled out the actuator from my 2005 K1200LT. I'll ship it to jzeiler for rebuilding this week.
acorrea is offline
post #8 of 10 Old Aug 2nd, 2017, 8:40 pm
Super Moderator
dfinazzo's Avatar
Re: EHCS
With only 4 posts to date . . . I believe you should hang around here a little more and ask questions you will get a ton on input and advice.
This site has demonstrated for the past 18 years a willingness to educate, help and console those who have issues and really step up to solving the simple tasks of keeping these bikes running in tip top shape Every issue raised here has been asked and commented on many many times and with a "little help from your new friends" you can gain knowledge like nowhere else!
Rebuilding and refurbishing an EHCS is a fairly straight forward mechanical task - ping John Zeiler if your not up to the task. John can rebuild one for you or walk you through the issues f you are up to the challenge - John is retired with all sorts of time on his hands
However you could take off the motor and wiring components - get handy with a welder add significant bracing to the stand for a foot lever. I do not believe you can use a stand from an earlier model, without modifying it, since the frame geometry is slightly different as it changed in 2005 and I believe its a bit lower to the ground. Others might chime in on this assertion.
In any case good luck in your quest . . .
My 2 cents!!
Dan Finazzo
dfinazzo is offline
post #9 of 10 Old Aug 2nd, 2017, 8:54 pm
Re: EHCS
I don't know the statistics, but my LT is 10 years old and approaching 58,000. I use my EHCS every time I ride my LT as I park it on the center-stand in my garage so it takes up less width. It is one of the few systems on my LT that hasn't yet failed. Knock on wood.
Mark65 likes this.
post #10 of 10 Old Aug 3rd, 2017, 6:08 pm
Re: EHCS
The key to longevity is how clean you keep the shaft on the cylinder. There is a wiper to remove dirt but the stock one is fragile and wears out. Then dirt gets to the shaft seal and the leak starts. 10 -15 ml of oil gone and she will falter on a lift.
For the original poster - easy to retro fit as the bolt pattern is the same for all years on the cradle mount to the transmission. There are some safety interlocks that are lost when you retrofit, but is you use a push button and relay to operate it you should not have an issue.
ELECTROHYDRAULIC CENTER STAND (EHCS) TSQUARED K1200LT 17 Oct 17th, 2018 10:52 am
K1200LT EHCS Centerstand Issues mondrage K1200LT 11 Apr 13th, 2016 11:00 am
EHCS flushing and elec. motor maintenance TSQUARED North West 1 Mar 26th, 2013 7:34 am
EHCS motor problem - solved. pozo_izquierdo K1200LT 2 Dec 4th, 2010 7:48 am
Most likely cause for EHCS not working? atps1234 K1200LT 4 Mar 11th, 2007 2:29 pm
