Wheel removal advice - BMW Luxury Touring Community
post #1 of 11 Old Nov 30th, 2006, 4:22 am Thread Starter
rodgtc's Avatar
This will be my first time removing my wheels to have tires changed. Any advice would be appreciated. Can I leave it on the center stand and use a floor jack to balance the bike ? 05 KLT
Thanks Rodger
Life is not measured by the number of breaths we take, but by the moments that take our breath away. Ride Safe
rodgtc is offline
post #2 of 11 Old Nov 30th, 2006, 5:34 am
lenny's Avatar
yes you can
lenny is offline
post #3 of 11 Old Nov 30th, 2006, 7:30 am
Glad you asked!
First, get a BFH (basic five-pound hammer =). You will use this for striking the motorcycle (or vise) to relieve your frustrations.... oh, wait... sorry, I thought I was on the Harley board for a minute there...
Ignore that first comment..
I put my '05 on the HCS then put some weight in the topcase to help balance...
Next, put a 1x4 under the bike against underside of engine and gently jack until the REAR wheel touches the ground with enough pressure to "stablize" the bike.
Commence front wheel procedures.
Remove jack, 1x4 and weight you put in the topcase.
Commence rear wheel procedures.
After all is back together and properly secured, don't forget you MUST "scrub" your new tires in CAREFULLY.
good luck.... if all else fails, remember my first comment... =)
J.M.J...
Dcn Channing
post #4 of 11 Old Nov 30th, 2006, 7:43 am
Pretty straight-forward...yes, use a small jack, or a block of wood, blah blah blah. One one word of real advise: remember to tape your wheels to prevent the calipers from scratching them. I use Gaff tape. Masking tape works too. Duct tape leaves behind the wonderful goo.
HTH
post #5 of 11 Old Nov 30th, 2006, 9:04 am
Smile Front Calipers
I found that if you take the brake pads out of the front calipers it makes the removal much easier. You remove two retaining clips, and the two pins and slide the pads right out.
schostev is offline
post #6 of 11 Old Nov 30th, 2006, 10:09 am
Originally Posted by messenger13
I use Gaff tape.
HTH
Where do you buy gaffer tape? I have looked at all the usual suspects and can find duct tape in every possible description and color, but no gaffer tape.
Motor On ,/'
jkersh1 is offline
post #7 of 11 Old Nov 30th, 2006, 5:01 pm
I buy it on eBay. Three rolls at a time. It's not cheap. But I don't leave home without it.
post #8 of 11 Old Nov 30th, 2006, 8:00 pm
Zotter's Avatar
Gaff vs Duct tape???
Dude, grab some masking tape and tape a rag round the rim - done
Tate
02 Mauve - my 'Light Truck'
Zotter is offline
post #9 of 11 Old Nov 30th, 2006, 8:37 pm Thread Starter
rodgtc's Avatar
Thanks for all the tips, expecting a foot of snow tomorrow so I am going to yank them off.
Rodger
rodgtc is offline
post #10 of 11 Old Nov 30th, 2006, 9:53 pm
dmatson's Avatar
I just changed the tires on the 05'. I just put a floor jack under the center stand skid plate and raise it just enough to raise the front a few inches off the ground. The front calipers won't touch the rims if you rock them (after the bolts are out) to compress the pads. Just grab them with your hands and gently rotate them to the inside of the wheel then to the outside then they just slide off right past the rims with plenty of space. Put a rag on the brake handle to remind yourself or anybody else to keep from touching it or put a wedge in between the pads. Done this four times now and not one scratch on the rim.
14' KTM 1190
03' KTM 450 EXC Dually
72' Honda SL 100
67' Triumph Bonneville
65' Honda CB160
70' Honda CB350
dmatson is offline
post #11 of 11 Old Nov 30th, 2006, 10:24 pm
One more tip, remove the rear first, then you can raise the front high enough to get the front tire out without removing the fender.
Big_E is offline
Front wheel removal - HOT Tip messenger13 K1200/1300GT (The Next Generation) 15 Aug 4th, 2008 11:34 pm
Uni-go Info and Looking for Advice jwd98056 Trailers, Sidecars, & Trikes 38 Aug 16th, 2006 8:12 pm
Rear wheel removal rixchard Tires 4 Jul 5th, 2006 12:40 pm
Rear Wheel Removal Help Needed oldschool78 K1200LT 17 Jan 21st, 2006 9:30 pm
