2000 K1200lt ABS reset - BMW Luxury Touring Community
post #1 of 2 Old Jul 31st, 2017, 10:17 pm Thread Starter
Unhappy 2000 K1200lt ABS reset
I tried the ABS reset with pin 2 on the diagnostic plug where I had no power, and pin 21 on the ABS plug the lights would go solid but as soon as I cycled the key switch they started flashing alternately. Not sure what to do about no power to pin 2 on the Diagnostic plug the wiring looks good.
Terry Hovey is offline
post #2 of 2 Old Jul 31st, 2017, 11:10 pm
bmwcoolk1200's Avatar
Re: 2000 K1200lt ABS reset
I take it that you were attempting to read the fault code on pin 2 by the needle drops on an analog volt meter.
First, did you have the meter set for DC volts and not AC? that might be an insulting question for some but it still has to be asked.
Another thing you need to remember is that BMW does not use the frame as ground. Make sure you are going to the negative side of the battery when ground is referenced in a test like this.
I have not tried this method myself so I can't say what you should see on pin 2. If you can tell us what area you live in, there might be someone close enough with a GS911 to drop by and read any fault codes and do a reset that way to see if it makes a difference.
Gordon
Sugar Hill, GA
bmwcoolk1200 is offline
2005 k1200lt abs questions pdrrock K1200LT 22 Jan 4th, 2015 10:21 pm
2000 k1200lt abs piston cleaning whiteguy K1200LT 11 Dec 29th, 2014 10:55 pm
2000 K1200LT Questions scotti K1200LT 23 Sep 20th, 2014 12:28 pm
ABS II problem after reset and modulator clean jackd K1200LT 4 Nov 11th, 2012 8:21 pm
