Timing Chain noise - BMW Luxury Touring Community
LinkBack Thread Tools
Old Jul 29th, 2017, 9:14 am Thread Starter
Timing Chain noise
I have a 2000 K1200LT with 127,000 kms. It runs well on the highway and I just rode the going to the sun road in Glacier park Mt. In the City it has a clanging sound at idle at in first and second gear? Anyone heard of this?
Ridout is offline
Old Jul 29th, 2017, 9:29 am
Does it change when you disengage the clutch?
Old Jul 29th, 2017, 2:51 pm Thread Starter
Re: Timing Chain noise
No change at all with the clutch.
Ridout is offline
Old Jul 29th, 2017, 11:27 pm
Munmi's Avatar
Do you here this sound while stopped or while underway? I ask because many of us have the 'cow bell syndrome' which is from the rear brake disc rattling at EVERY little crack or bump in the road at lower speeds.
Scott and Theresa
Munising, MI
2004 K1200LT Black
2014 Kawasaki KLR650
Munmi is offline
Old Jul 30th, 2017, 4:38 am
Axle's Avatar
I think he covered that one Scott
Ridout it depends on your definition of clanging, a timing chain rattles it doesn't clang and probably wont go away and then come back if it is indeed the problem?? hows your oil level
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
Old Jul 30th, 2017, 2:30 pm Thread Starter
not sure if it's a rattle or clang but seems to be there at idle and in 1st and second gear at lower RPM's below 3000.
Ridout is offline
Swapped in used motor, cracked timing chain cover, oil leak westvandude K1200LT 15 Oct 31st, 2018 5:21 pm
Confused on timing chain cover wallyo K1200LT 1 Apr 13th, 2009 8:09 am
voice separation on the LT's loudspeaker jusufbw K1200LT 6 Oct 8th, 2007 11:03 pm
Timing Chain Cover questions bigbear K1200LT 3 Nov 6th, 2006 2:50 pm
Timing chain ALIGNING DEVICE measurement ? Frenchy K1200LT 15 May 15th, 2006 6:54 pm
