reverse - BMW Luxury Touring Community
 3Likes
  • 1 Post By bmwcoolk1200
  • 2 Post By jzeiler
post #1 of 5 Old Jul 27th, 2017, 6:32 pm Thread Starter
reverse
Can using the reverse once a day have bad effect on your starter. Wear it out sooner? 07 LT Jim
Jriverside is offline
post #2 of 5 Old Jul 27th, 2017, 6:39 pm
Mark65's Avatar
Re: reverse
Well, they installed it to be used, so I'd guess no. Plus, it uses the starter switch, but I'm not at all sure the starter motor itself gets engaged. I hear the engine note change, but I don't hear a starter whine, and of course the engine is already running. I could be WAY off on all of these thoughts, though, so take it with a grain of salt.
Mark
Mark(Big Poppa) and Julie(Fireball)
'06 K1200LT Magnesium Black "Stella"
Glendale, AZ
BMWMOA#206887
RA#44657
AMA#3647653
Let's Ride!
Mark65 is offline
post #3 of 5 Old Jul 27th, 2017, 9:45 pm
bmwcoolk1200's Avatar
Re: reverse
It does indeed use the starter motor to reverse the bike. It is a far lighter load than cranking the engine so wear should be less on the brushes but it can't help but cause some wear. The brushes are pretty thick so it is designed to be used. Eventually, it will fail but I wouldn't be worried about using it once a day unless you back it up 50 feet or so. I try not to use mine on surfaces that I can push back with my feet though. It is a pain to get to and replace/service.
Mark65 likes this.
Gordon
Sugar Hill, GA
bmwcoolk1200 is online now
post #4 of 5 Old Jul 28th, 2017, 7:23 pm
Re: reverse
But then it is like "don't use the starter to start the bike because it will wear it out".
Point of reference I have 103 K on my 05 and I use reverse a lot. I had the transmission out for a bearing change and opened the starter up while the bike was apart. I replaced the front bearing (used during starting) as it was dry but smooth. The rear bearing (used during reverse) was perfect. Oh and the total brush length was 9 mm (worn down from 12 mm when new.
Use reverse whenever you need it, the starter will last a long time.
bmwcoolk1200 and Mark65 like this.
post #5 of 5 Old Jul 29th, 2017, 1:17 pm Thread Starter
Re: reverse
Thanks I feel better using it now. Jim
Reverse Inoperable sully2028 K1200LT 40 Jul 23rd, 2014 9:53 pm
Beware of reverse nplenzick K1200LT 1 Oct 31st, 2008 10:06 am
Update: Radio pause & reverse not working ArthurKnowles K1200LT 6 Apr 17th, 2008 9:29 am
Reverse Inoperative JosephFry K1200LT 10 Aug 22nd, 2007 4:53 pm
Technique/effort to engage Reverse? juggler K1200LT 4 Jan 14th, 2007 5:22 pm
