Small Oil Leak - BMW Luxury Touring Community
post #1 of 6 Old Nov 29th, 2006, 12:45 pm Thread Starter
BeemerRiderBoB's Avatar
Small Oil Leak
Well, after 42,000 miles i've developed a very small oil leak that's dripping from near the oil drain plug, but may be originating elsewhere (centerstand parked). Have not had a chance to really check it out and likely won't until my next service in the spring. The leak started after an oil change and returning from a 2500 mile trip.
Oil's been changed regularly but last time added a bit more oil than I normally do. If I recall correctly it was 3.8 qts vs 3.2 qts that I normally add.
Have ridden the bike with the leak for more than 2 weeks and no noticeable decrease in oil level in the sight glass. And sometimes when I park the bike (centerstand) it doesn't leak at all.
Anyone had a similar experience and if so what was the problem or final result with the fix? I'm fairly certain it's not the drain plug as I do all my service to specs/torque. Anyone care to speculate? thanks.
BeemerRiderBob
Dallas/Ft. Worth
'82 R100 Sidecar
'91 R100 GS BumbleBee
'93 R100 GS/PD
'02 K1200 LTC- KIA 09/04/07
'03 KTM 450 Exc (living in Colorado)
'08 R1200 GS Adventure (Joy)
Only 41% of the World Left to Visit!
BeemerRiderBoB is offline
post #2 of 6 Old Nov 29th, 2006, 1:15 pm
bmwrubbercow's Avatar
Check your oil pan bolts. Vibration can loosen them. Also check the bolts holding the plate on the bottom that covers the oil filter. And you did snug the oil filter a little didn't you. But don't over tighten it!
Tom
2003 R1150RT, Black Beauty--this is one sexy bike!
1999 R1100GSA, Does everything well, what else can one say?
1992 K75SA, If this engine had been 4-valve instead of 2, it would be the smoothest BMW ever built!
1978 R100S, my first and favorite BMW.
1976 R75/6, A 30 year old gentlemen I still love to take out for a Sunday ride.
bmwrubbercow is offline
post #3 of 6 Old Nov 29th, 2006, 6:50 pm
mtrevelino's Avatar
Speculate! We can all do that. It seems a little early for the rear main seal to be leaking, but it could be possible. $1,600 for that replacement! Hopefully, it may just be the o-ring on the oil filter access housing since it started after your oil change. A lot less expensive than $1,600!! Good luck.
Mike Trevelino
Williamsburg, VA
2008 RT - Sold December 2019
mtrevelino is offline
post #4 of 6 Old Nov 30th, 2006, 11:24 am
vernvernvern's Avatar
Thumbs up Simple things first!!!!!!!!!!!
quote from your post.....
Bob,
I sometimes put the drain plug in finger tight and then forget to tighten it. So maybe you didn't get it torqued right. It's an easy check and then you're sure.
Also, maybe the oil you saw was left overs from the oil change. I usually try to use a rag to clean all the spills on the bottom of the engine when I'm done.
Then I start her up and let it run for 5 minutes, shut it off and then put a piece of clean cardboard under it to see if there is a drip on it the next morning. No drips and it's good to go.
As I get older, the more double checks I can do helps me sleep better. LOL
Hope your fix is easy.
78 years young!
Converted HD rider.
Vern
vernvernvern is offline
post #5 of 6 Old Nov 30th, 2006, 11:40 am
donn's Avatar
I had a small oil leak also, after ruling out the oil filter and plug, trailered it to the dealer.....rear main seal bad, also replaced clutch plate (oil on it) 7-9 hrs to do job. Mine is a 02 with 75000 on her...Good luck.
donn is offline
post #6 of 6 Old Nov 30th, 2006, 6:29 pm
oil leak
I had an oil leak and it appeared to be coming from the cover bolts. It was close to time to change the oil so I went ahead and changed it, and the leak went away. I figure since it had been a good bit of time/miles since I changed the oil, possibly the o-ring under the cover had become brittle. In your case maybe you have some foreign material between the o-ring and the cover groove.
Joe and Robin
2001 K1200LTC 60K miles
space coast of Florida
lavamanz is offline
Possible coolant leak into the oil RealWing K1200LT 52 Feb 20th, 2007 11:58 am
Small oil leak at final drive DerickO K1200LT 8 Oct 13th, 2006 7:23 pm
Oil Leak old1951 K1200LT 4 Jul 17th, 2006 9:14 am
Drive line oil leak near gearbox barryst1100 K1200LT 13 Jul 11th, 2006 4:25 pm
rear drive oil leak? louatlvc K1200LT 4 Jun 11th, 2006 7:17 pm
