Radio/CD Player Stopped working - BMW Luxury Touring Community
post #1 of 11 Old Nov 29th, 2006, 9:44 am Thread Starter
MattKas's Avatar
Question Radio/CD Player Stopped working
This morning I turned on the CD Player (single head unit), inserted my favorite CD. Then, started the engine. After starting the engine, the radio/CD player never came back. I pushed the turn on/off switch. Still there was no power. Possibly a fuse gone bad??? Does anybody have a similar experience? Which fuse should I check? or do I need to replace the Radio/CD Player?
Thanks in advance,
Matt Kas
"Riding Year around"
MattKas is offline
post #2 of 11 Old Nov 29th, 2006, 10:15 am
First thing I would try is disconnecting the battery for 30 minutes to an hour. My radio is doing this about once a week now (the battery is 3 years old) and this always fixes mine.
When you reconnect the battery you need to set the throttle position sensors (full open and fully closed), Turn on the key but do not start the engine. Open the throttle slow to the full open position twice. Turn off the key. Restart as normal. You will need to ride for a few miles to get the Motronic fully reset.
Alan Stuber
2003 K1200 LTC Titan Silver
Austin, Texas
astuber is offline
post #3 of 11 Old Nov 29th, 2006, 12:14 pm
Lost_but_Happy's Avatar
There was a thread about this a couple of days ago (and I'm too lazy to look for it). What was determined was, that it's not a good thing to start the radio, etc. prior to starting the engine. The fix is as was suggested, disconnect the battery for about 30 minutes, reconnect and reset the throttle sensor.
I don't remember the details on it, but one member here even was told this by a tech...
HTH.
AJ
2013 K1600GTL (not yet named)
Lost_but_Happy is offline
post #4 of 11 Old Nov 29th, 2006, 12:20 pm
HTH.
Happy- That thread was me. My radio just up and quit. Turned out to be the fuse under the rear seat was blown. Why I don't know, but it's seems to be fine now. But, what's the deal with the throttle sensor? I didn't do this and the bike seems to run OK.
Bruce_N is offline
post #5 of 11 Old Nov 29th, 2006, 12:25 pm
The throttle position sensor doesn't HAVE to be reset, but can help. When you disconned the battery, the Motronic loses it's memory for what the fuel settings should be. By resetting the sensor (turn key on - don't start, rotate throttle all on, all off and repeat, then turn key off) you give the motronic the two ends of the spectrum to work from. Not doing just means the motronic has to learn from scratch, which it will do in time.
AJ
post #6 of 11 Old Nov 29th, 2006, 12:34 pm
Interesting. I guess next time I unhook the battery I'll try that. But for now it seems to be OK. Thanks Happy.
Now back to the dude trying to fix his radio. Check the fuse under the seat, easy to get at.
Bruce_N is offline
post #7 of 11 Old Nov 29th, 2006, 12:46 pm
I have started turning my radio off before I start the engine. This has just started in the past month or so and I think my battery may be getting weak as it is 3 years old and has not been replaced.
My LT doesn't run very well for the first 5-10 miles if I don't do the throttle reset. It doesn't seem to want to idle if I don't keep the throttle open a little. YMMV
Alan Stuber
Austin, Texas
astuber is offline
post #8 of 11 Old Nov 29th, 2006, 2:36 pm Thread Starter
MattKas's Avatar
Thanks, guys. As soon as I disconnected and connected the battery. the radio started working. I also did the throttle sensor thing to be on the safe side. :-)
Matt Kas
MattKas is offline
post #9 of 11 Old Nov 29th, 2006, 3:22 pm
McRuss's Avatar
multi threads
I have a thread about radio quitting too. But I've tried all the suggested tricks and nothing has worked. I hardly ever turn my radio off but always turn the key to the 'lock' position. 30k with no problems until last week. And it ate a CD!
Did you leave the battery disconnected for a long time (30 min to 1 hr)? I just disconnected and reconnected mine. Maybe it needs to 'bleed off' some memory power?
Just old, clutchless and clueless
Russ Locke
Lakehills, Texas
McRuss is offline
post #10 of 11 Old Nov 29th, 2006, 3:32 pm Thread Starter
MattKas's Avatar
Yes, I disconnected the battery little longer than 30 minutes.
Matt Kas
MattKas is offline
post #11 of 11 Old Nov 29th, 2006, 3:34 pm
I have found that it takes at least 30 minutes to reset the radio. I can always tell that it has been enough time as the alarm will give 2 beeps as I am reconnecting the battery. Make sure that you have the alarm fob when you reconnect the battery. DAMHIK.
I have disconnected the battery several times and did not get the alarm beeps and the radio did not come back on.
Alan Stuber
Austin, Texas
astuber is offline
Radio / CD player manual bmwtwisty K1200LT 1 Sep 13th, 2006 3:04 pm
2004 LT radio/CD suddenly not working... overtime K1200LT 2 Dec 3rd, 2005 5:46 pm
My CD Player just started playing.... tyroneteeth K1200LT 5 Nov 6th, 2005 7:23 pm
Want to replace the CD Player with and MP3 FredTurner iPod/MP3 10 Oct 9th, 2005 2:09 pm
mp3 Player - Flash Memory Based ytk iPod/MP3 2 Oct 5th, 2005 8:57 pm
