Trickle charger - BMW Luxury Touring Community
post #1 of 5 Old Nov 28th, 2006, 7:26 pm Thread Starter
jiminabqnm's Avatar
Trickle charger
Hello Gents, just want to know if it is ok to place a charger on the Batt with it still connected to the bike. Nothing more than 2 amps. I know the owners manual say's 'no', thanks for the input.
Jim
05' Ocean Blue
Albuquerque, NM
jiminabqnm is offline
post #2 of 5 Old Nov 28th, 2006, 8:55 pm
Zotter's Avatar
Many of us use 'smart chargers' that auto-adjust charge voltage/current to maintain a battery. BMW even makes a trickle charger for their bikes.
Should be no prob - but if it's a dumb charger, watch it close. Even at 2amps you can cook 'er dry and ruin it in as short as tens of hours. DAMHIK.
Tate
02 Mauve - my 'Light Truck'
Zotter is offline
post #3 of 5 Old Nov 28th, 2006, 9:19 pm
CharlieVT's Avatar
Trickle charger on a timer
If you want to connect a trickle charger and forget about it, plug it into one of those 24 hour timers which allow you to turn lights on/off a specific times.
I set the time to turn on the charger for just 10 or 15 minutes in a 24 hour period to serve as battery maintenance.
If you want to charge a battery that is in need of recharging, I'd set it to charge for 12 hours or so and then check the battery. I wouldn't leave it charging for 24 hours or more.
I have a 1 amp el cheapo trickle charger which works well this way. The charger does have interal regulation that limits amperage and voltage but it is not a "smart" charger like a Battery Tender that responds to the battery's condition. Never had a problem with it.
CharlieVT is online now
post #4 of 5 Old Nov 30th, 2006, 8:38 pm
bflemingor's Avatar
I use a "Smart Charger" ($39 to $59), and leave it connected to one of the 12 plugs 24/7. Seems to work well.
bflemingor is offline
post #5 of 5 Old Nov 30th, 2006, 9:42 pm
dmatson's Avatar
I use the "Battery Tender Plus" the one made for BMW, says right on the top of the charger (they make the offical BMW one).
14' KTM 1190
03' KTM 450 EXC Dually
72' Honda SL 100
67' Triumph Bonneville
65' Honda CB160
70' Honda CB350
dmatson is offline
Dead Battery: Wrong Charger? ICXC K1200LT 9 Oct 12th, 2006 5:10 pm
Has my BMW charger died? ronlray K1200LT 3 Aug 25th, 2006 5:06 pm
Is a charger a charger? graydude Batteries, Chargers, & Electrical 28 Dec 10th, 2005 11:13 pm
Trickle charger for 05 LT mpillis Batteries, Chargers, & Electrical 17 Nov 28th, 2005 1:01 pm
