Oil in Drive Shaft Housing - BMW Luxury Touring Community
 1Likes
  • 1 Post By jzeiler
post #1 of 4 Old Jul 18th, 2017, 11:52 am Thread Starter
mr1150gs's Avatar
So in going over this new to me 07 LT, I discover about a tablespoon of gear oil at the bottom boot. No doubt this is what caused the rear wheel to be so dirty but there is no indication of fresh oil on the wheel. Not sure if this oil is from the rear main seal or the FD so I used Purple in the trani and regular in the FD to see what transpires over time. I suspect it is the rear main seal otherwise the rear wheel would be wet.
Any thoughts on this much oil in this area being normal?
BMWMOA - #47511
2007 K1200LT - Nice now!
1981 R100CS - Sadly gone
1986 K100RS - In the past
mr1150gs is offline
post #2 of 4 Old Jul 18th, 2017, 5:52 pm
Re: Oil in Drive Shaft Housing
There should never be any oil in the swing arm housing. Two things can put it there. 1. transmission output shaft seal 2. rear drive pinion seal
Most likely one is the transmission output shaft seal. Not a big deal if it is just a teaspoon, clean it and monitor. The transmission hold 3/4 of a liter so a teaspoon is nothing.
saddleman likes this.
post #3 of 4 Old Jul 18th, 2017, 7:00 pm
Yep, I've had both within 54,000 miles.
post #4 of 4 Old Jul 19th, 2017, 1:39 pm Thread Starter
mr1150gs's Avatar
Thanks guys, you're the best!
BMWMOA - #47511
mr1150gs is offline
Final drive oil Marve RT Series 9 Jan 28th, 2014 2:04 pm
final drive gear oil tenrocky K1200LT 23 Jul 19th, 2011 9:16 pm
Final Drive murray K1200LT 22 Sep 28th, 2008 10:02 am
drive shaft failure roadcrave K1200LT 4 Mar 28th, 2007 9:55 am
