07 lt abs light stays on - BMW Luxury Touring Community
 1Likes
  • 1 Post By jzeiler
post #1 of 13 Old Jul 15th, 2017, 1:13 pm Thread Starter
mr1150gs's Avatar
Bought this bike with non fuctioning headlight and brake fault warning indicator on. Bike also had aftermarket brake strobe light that was removed. Center rear brake bulb works. Brake fluid was very dark so I bled them and checked all fluid reservoir levels. Headlight was replaced and is functioning. The brake fault fault light is not blinking and does not go off but you can hear the relay working. Brakes are functioning. Battery was previously low but now fully charged.
Is there a reset for the integrated abs system? Not sure what else to look for.
BMWMOA - #47511
2007 K1200LT - Nice now!
1981 R100CS - Sadly gone
1986 K100RS - In the past
mr1150gs is offline
post #2 of 13 Old Jul 15th, 2017, 2:51 pm
Re: 07 lt abs light stays on
Look at this chart to diagnose what the lights indicate.
http://www.bmwlt.com/forums/attachme...abs-legend.jpg
There is a drive off rolling test before they go out so just starting it and not moving isn't enough since the wheel sensors have to sense the pickup rings.
Only reset I know of without a computer is disconnecting the battery.
The dealer or a gs911 could read the fault codes to further diagnose the issue.
_____________
Kim Thomson
Motorcycle Cigar Smoker
85 K100 Standard - Big Red
Gone, but not forgotten...
85 K100RT - (wore out)
alabrew is offline
post #3 of 13 Old Jul 15th, 2017, 7:12 pm Thread Starter
mr1150gs's Avatar
Thanks alabrew. Based on the chart I'm experiencing the first of the faults on the list which is risidual braking only. Rolling test does not eliminate the fault code. I will have to see if anyone has a 911. Also wonde.ring if the relay is stuck but I do hear it ticking. Have disconnected battery but no luck to reset.
I also have a GS with the same abs system so may be worth a try to interchange relays.
BMWMOA - #47511
mr1150gs is offline
post #4 of 13 Old Jul 16th, 2017, 10:04 pm
There is no "relay" to drive the ABS it is all in the ABS solid state brain. The servos trigger on input pressure and/or application of a brake switch (front or rear). These feed directly into the brain and the brain then sends a signal to the brake light relay to light the lights. This system is self resetting once the fault is eliminated. So if you still see the light the fault is still there. Really need to get a fault code and go from there.
post #5 of 13 Old Jul 17th, 2017, 9:27 am
Brake fluid levels ?
simoncharles is offline
post #6 of 13 Old Jul 17th, 2017, 9:42 am Thread Starter
mr1150gs's Avatar
Thanks John,
Previous owner indicated he had a mechanic read the codes that pointed to the then non-functioning head light. The head light has since been replaced but the brake fault indicator on the dash remains.
The brake fluid was very dark and I believe I may have allowed air in the system but I re-bled the brakes to be sure.
I was hoping to eliminate the blue relay that manages the dash light (understand it does not drive the ABS) being at fault as I would think a faulty ABS pump would not allow the brakes to function as well as they do.
Hopefully someone local will have a 911 as the closest BMW dealer is 2 1/2 hours away.
BMWMOA - #47511
mr1150gs is offline
post #7 of 13 Old Jul 17th, 2017, 9:44 am Thread Starter
mr1150gs's Avatar
Fluid levels are all fine and the battery is now fully charged.
Thanks for replying.
BMWMOA - #47511
mr1150gs is offline
post #8 of 13 Old Jul 17th, 2017, 11:15 am
You are more than welcome.
I had more or less the same problem on my 2005, and it wasn´t until I filled the rear brake round container up to MAX that I managed to solve the problem.
Worth a try.
post #9 of 13 Old Jul 17th, 2017, 11:38 am Thread Starter
mr1150gs's Avatar
Worth a try.
Thanks for this but have already ensured all levels are up.
BMWMOA - #47511
mr1150gs is offline
post #10 of 13 Old Jul 17th, 2017, 2:48 pm
The relay is triggered by a ground signal from pin 10 on the ABS unit. If that relay was stuck all the time the light would never flash even during start up and I believe that is what you said that is never flashes. But you are correct - the trouble shooting chart says only residual is available if the that light is steady on. That would mean very weak braking so there may be another reason for the light if you have decent brakes.
You may not have a fault at all just a stuck relay. #2 in the picture.
Name:	Relay ID 1.JPG
simoncharles likes this.
post #11 of 13 Old Jul 17th, 2017, 6:07 pm Thread Starter
mr1150gs's Avatar
EURICKAH!!! I found a yellow/brown wire to the #4 terminal on the relay that was not making good connection. When this wire is jiggled, the dash light flashes as required. Thing is, how do I secure this connection inside the plastic cubical that the wire sits in?
BMWMOA - #47511
mr1150gs is offline
post #12 of 13 Old Jul 18th, 2017, 5:55 pm
If you mean here the relay plugs in... just a spade connector in there. Should be able to bend it a little with a small screw driver blade to tighten it up.
post #13 of 13 Old Jul 18th, 2017, 9:10 pm Thread Starter
mr1150gs's Avatar
Thanks John yes the spade connector on the middle pin. It never fails to amaze how such a small issue cause so much angst and bewilderment.
BMWMOA - #47511
mr1150gs is offline
Coming home from work.. ABS light lights up and ABS pump won't turn off Ksnarf K1200LT 19 Mar 1st, 2015 4:42 am
My Father purchased 2002 K1200LT with 7000 miles the abs pump stays on all the time Autodeal1 K1200LT 6 May 2nd, 2012 7:02 am
Turning off the ABS Flashing light tpfeffer RT Series 4 Jul 7th, 2011 12:18 pm
