Cooling fans always on - 99 k1200lt - BMW Luxury Touring Community
 4Likes
  • 1 Post By bmwcoolk1200
  • 1 Post By loflyn
  • 1 Post By jzeiler
  • 1 Post By loflyn
post #1 of 7 Old Jul 11th, 2017, 4:31 pm Thread Starter
loflyn's Avatar
I am in the process of putting my bike back together after replacing my rear main seal. At the point of putting the fuel tank back on, I wanted to let the bike run and put it in gear to make sure there wasn't any strange noises coming from the clutch or transmission. But when I turned the key without starting the bike, both cooling fans are coming on. I've checked fuses, reset montronic, checked coolant temp connection. What is my next check? This is as far as I've ever gone into this bike by myself and it's all because of the help I've received from forums like this that I've even considered tackling a job this large. I'm sure it's something simple that I'm missing.
'68 Triumph Bonnie
'71 R75/5 **
'72 R75/5 (2)
'73 R60/5 **
'73 R75/5
'76 R90/6
'77 R75/7 '77 R100/5 "bitsa" bike
'79 R100RT **
'88 R100GS
'90 K75S
'90 K75C **
'99 K1200LT **
'99 K1200LT **
** denotes owns currently
loflyn is offline
post #2 of 7 Old Jul 11th, 2017, 5:16 pm
bmwcoolk1200's Avatar
Re: Cooling fans always on - 99 k1200lt
Check the temp sensor on the left side attached to the back side of the head behind the coil pack. If that is unplugged or has been damaged, the fans will come on at key on and not turn off. If you failed to unplug it prior to lowering the engine to remove the transmission, that was a $120 mistake as it stretched the cable and damaged the wires. Ask me how I know.
beech likes this.
Gordon
Sugar Hill, GA
bmwcoolk1200 is offline
post #3 of 7 Old Jul 11th, 2017, 9:55 pm Thread Starter
loflyn's Avatar
Thanks Gordon, I'll check that out. Hopefully, I didn't remember to plug it back in. Terry
bmwcoolk1200 likes this.
'68 Triumph Bonnie
'71 R75/5 **
'72 R75/5 (2)
'73 R60/5 **
'73 R75/5
'76 R90/6
'79 R100RT **
'88 R100GS
'90 K75S
'90 K75C **
'99 K1200LT **
'99 K1200LT **
loflyn is offline
post #4 of 7 Old Jul 12th, 2017, 9:23 am
You should hope you DID forget to plug it in as then it is an easy fix. That is how I check my fans after I get the bike back together. Unplug they come on plug in they go off.
post #5 of 7 Old Jul 12th, 2017, 11:19 am
Found my old thread when doing Cedric's clutch and starter. Here is a picture I took as we went along clearly showing that this cable was not removed before lowering the engine. In any case, this is the plug you need to check.
Gordon
Sugar Hill, GA
post #6 of 7 Old Jul 12th, 2017, 4:51 pm Thread Starter
loflyn's Avatar
Appears that that sensor was the culprit. From memory, I don't think that I had unplugged it to lift the frame. To look at it, it doesn't appear any worse for wear (crimped or stretched). Luckily, I have a spare parts bike in which I removed that sensor. Other than it was a bear to swap out without removing the coils, everything it working as it should for now. Thanks for all the information.
'68 Triumph Bonnie
'71 R75/5 **
'72 R75/5 (2)
'73 R60/5 **
'73 R75/5
'76 R90/6
'79 R100RT **
'88 R100GS
'90 K75S
'90 K75C **
'99 K1200LT **
'99 K1200LT **
loflyn is offline
post #7 of 7 Old Jul 12th, 2017, 4:54 pm
The sensor that I stretched was damaged right where the wire went into the sensor leaving nothing to attempt a repair with. Glad it is all better.
Gordon
Sugar Hill, GA
looking to buy k1200lt, LA, CA powerman5kw South West 32 May 29th, 2017 11:56 pm
08 K1200LT Fans BlueBeemer K1200LT 7 Jul 22nd, 2008 7:19 am
Cooling Fan / Motronic Connection? Chuck_Gardner K1200LT 6 May 3rd, 2007 6:53 pm
Cooling Fans Texas42 K1200LT 1 Jul 20th, 2006 7:28 pm
One of my cooling fans doesn't work JMMRoad K1200LT 5 May 13th, 2006 3:59 pm
