07 LT Central Lock, Alarm, No Key Fob - BMW Luxury Touring Community
post #1 of 4 Old Jul 4th, 2017, 1:20 pm Thread Starter
mr1150gs's Avatar
I purchased this bike used and the PO indicated there was no key fob as the bike had no alarm and central lock. Striping the bike down to find the alarm and electrical connections to the locks so I suspect central locks and alarm came with this bike. Is there a way of getting these functions to work again with a replacement fob?
How would the system be disconnected so that the bike is not immobilized without the key fob?
BMWMOA - #47511
2007 K1200LT - Nice now!
1981 R100CS - Sadly gone
1986 K100RS - In the past
mr1150gs is offline
post #2 of 4 Old Jul 4th, 2017, 2:39 pm
Re: 07 LT Central Lock, Alarm, No Key Fob
Yes you can buy a FOB but you will need the alarm code to sync it. There is a paper tag on the alarm unit with a 5 digit code(see the photo for 14111), this is what you take to the dealer and he sends it off to the Fatherland to get the actual alarm code you can use.
Option two is to remove the alarm's 12 pin connector and jumper a few wires as follows:
To get the bike running again you need to jumper the following pins on the 12 pin connector. Pin 3 (black/white/yellow) to pin 11 (black/yellow); this is the starter button signal to the starter relay. Then jumper pin 10 (green/violet, switched power) to pin 6 (blue/violet, engine electronics relay). Now the bike will start and run normally.
Name:	alarm location.jpg
post #3 of 4 Old Jul 4th, 2017, 3:16 pm Thread Starter
mr1150gs's Avatar
Thanks John. This 07 must have already had that done to it as the battery has been disconnected many times, once connected the bike works fine with the key and no alarm/ immobilizer issue. Just wonder if it is worth the expense to get it back to original.
BMWMOA - #47511
mr1150gs is offline
post #4 of 4 Old Jul 4th, 2017, 5:11 pm
Not necessarily. The alarm can be programmed to leave the immobilizer off and it does not always revert back following a battery disconnect. But it often does, so the only way to know for sure is to pull off the top case and have a look. I carry a 12 pin plug pre-wired just for this issue in case my alarm dies on me on a trip. 10 minutes I have it going again.
Bizarre Alarm issue CR125Honda K1200LT 6 Mar 20th, 2017 4:57 pm
central lock doesn't open vlad273 K1200LT 5 Dec 14th, 2012 3:48 am
Alarm/ Central Locking/ Immobiliser System K1200lt 1994 New Look lnagel K1200LT 5 Nov 14th, 2011 2:10 am
Central Alarm Locking Wire & Saddle Bag Gizmo1137 K1200LT 2 Nov 12th, 2011 5:30 pm
Top case trunk central lock SmokinJoe K1200LT 14 Apr 20th, 2011 7:24 am
