Necessary to change plugs at 1200??? - BMW Luxury Touring Community
post #1 of 11 Old Nov 26th, 2006, 9:40 pm Thread Starter
Coming up on 12K on my 05LT and wonder if it's really necessary to change the plugs. The wrench turner at local dealer says yes, but the counter guy said he has 24K on his.
SeaMarshal is offline
post #2 of 11 Old Nov 26th, 2006, 9:56 pm
Changed mine at 29,000, the new ones didn't look any better than the old ones. I will not be doing it again in 12,000. I think 12,000 is old school & went out with leaded gas.
Big_E is offline
post #3 of 11 Old Nov 26th, 2006, 10:00 pm
vernvernvern's Avatar
I did
I changed them at 12,000 and now again at 24,000. Easy to do and is recommended in the Clymer Manual I use.
It gives you a quick check on how your engine is doing on each cylinder by looking at the plugs when changed.
Just my .02!
78 years young!
Converted HD rider.
Vern
vernvernvern is offline
post #4 of 11 Old Nov 26th, 2006, 10:22 pm
omurphy's Avatar
if it's running good and the plugs look good why not just put them back in the engine? after all, new plugs are sometimes bad but very rare. omurphy
omurphy is offline
post #5 of 11 Old Nov 26th, 2006, 10:58 pm
Motomadman's Avatar
You boys know what to look for in a set of plugs besides soot and other residue? Look at the electrodes and make sure they are nice and square and have no rounded corners. The edges wear by sacrificing a little bit of metal every time it sparks. No one said these bikes were cheap to maintain. Start cutting corners and the rest of motor will wear sooner trying to make up were it's lacking else where....
Craig Hutchison
02 Pac Blue (Aka Blue Ox)
34° 14’ 12.63 N
119° 01’ 21.64 W
Why coast through Life when you can Corner it.
Motomadman is offline
post #6 of 11 Old Nov 28th, 2006, 9:57 am
BecketMa's Avatar
Don't know if it is necessary. But, it's FUN!
Just be sure to get 4--force of habit, I ordered two and two valve cover gaskets; needed a new socket for the new plugs.
bob, 00LT
BecketMa is offline
post #7 of 11 Old Nov 28th, 2006, 10:31 am
I will change mine at 12k intervals. There was a noticeable difference in the idle and feel of the engine after doing that on my '05.
J.M.J...
Dcn Channing
post #8 of 11 Old Nov 28th, 2006, 4:32 pm
I did for the first few sets, and could always notice a little improvement in the way the bike ran, but not something earth shaking.
I started running Platinum tipped plugs, and those can go 50K plus with no problems. I used Splitfire TP416D, but there are other platinum and iridium tipped plugs available. I liked the Splitfire because they had platinum points on both positive and negative electrodes, not like some that only put platinum on the positive center electrode. That one erodes the most, but when you are going for long mileage the un-tipped negative electrode will erode if it does not have platinum tips.
post #9 of 11 Old Dec 14th, 2006, 6:18 am
DanMartin's Avatar
Last night leaving the office my bike started running so badly I didn't think I would make it home. Felt like it was missing on 1-2 cylinders. No power and stop and go traffic was worse than usual. I got home and changed the plugs. Now runs great. I was using the Splitfire TP416D recommended earlier. They had been in for 33,000 miles. Think I'll go back to the 12k recommendation.
Dan Martin
Houston, Tx
DanMartin is offline
post #10 of 11 Old Dec 17th, 2006, 10:43 am
speedy's Avatar
Save your money!
For the 1st 45k I replaced the plugs as recommended, but noticed that there was no significant wear or deposits on the plugs, so I decided to experiment with extending the interval. On most modern engines with the high output ignition systems there is no reason the plugs can't safely go at least 30k, even 60k. It now has 137k, the oil gets changed every 5k (easy math) valves check every 12-15k (haven't had to change one in years) & the plugs & fuel filter every 30k. There has NEVER been any change in the performance or fuel mileage.
speedy is offline
post #11 of 11 Old Dec 17th, 2006, 12:25 pm
I run mine till I start to notice a slight dropin performance and idle quality. For my bike that was usually between 14-18k. I also flip back and forth between the iridium and splitfire plugs. I think I like the splitfires better though.
Brian Ley
WA State of mindless sheep
2007 K1200GT
2010 650GS
BMWOA 119892
sanjaun2 is offline
What About My Used Spark Plugs camtr K1200LT 6 Mar 29th, 2006 5:45 am
MOTO GUZZI RT rival? NORGE 1200 ustasub Chit Chat 10 Nov 24th, 2005 9:49 am
Edit title... Title does not change ? buffalo BMWLT Site Support Forum 4 Oct 11th, 2005 12:37 am
