07 K1200lt Electrical Issues - BMW Luxury Touring Community
 1Likes
  • 1 Post By mr1150gs
post #1 of 25 Old Jun 30th, 2017, 7:17 am Thread Starter
mr1150gs's Avatar
Bought this bike with the Xenon headlight not working (replacement on order) and dash lights would not go off. Stripped it down to find aftermarket brake strobe lights installed, blown 4 amp fuse on 2nd fuse box but no other frayed wires that I can see. Ground connections are good but when I replace the 4 amp fuse I get all of the dash lights on irrespective of what position the key is in. Any suggestions? Thanks in advance.
BMWMOA - #47511
2007 K1200LT - Nice now!
1981 R100CS - Sadly gone
1986 K100RS - In the past
mr1150gs is offline
post #2 of 25 Old Jun 30th, 2017, 8:53 am
bmwcoolk1200's Avatar
Re: 07 K1200lt Electrical Issues
If you are referring to the instrumentation back lights on the dash, a quick look at the schematic shows them connected to the onboard computer. Fuse 15 box 2 looks like an always hot link to the OBC and Fuse 14 looks like a switched feed to the OBC. I am only guessing here but if F15 is the one that was blown and now replaced and you pull F14 and the lights continue to stay on, I would suspect the OBC as being faulty or some issue in the wiring that provides the switched 12V to it through F14. Check to make sure that F14 goes on and off with the key with a meter. If it does, look into the OBC as possibly being faulty.
I am not intimately familiar with this and only making suggestions to try and isolate the issue based on what I see on the schematic. Someone else may have first hand knowledge on the dash lights and how they function to help you further.
Gordon
Sugar Hill, GA
bmwcoolk1200 is offline
post #3 of 25 Old Jun 30th, 2017, 9:28 am
silverlt2002's Avatar
Unless you have already done it, my first step would be to remove the aftermarket brake strobe entirely to see if that solves your issues.
Steve Green
US Army (Ret)
2002 KLT
Titan Silver
silverlt2002 is offline
post #4 of 25 Old Jun 30th, 2017, 10:02 am Thread Starter
mr1150gs's Avatar
Brake strobe thingy removed! Other than the top led light on the trunk now coming on as it should (before it was not working), this has not effected the dash light issue.
I will have to see what the replacement headlight will do to resolve the issue.
I'm also not sure why the OBC makes a ticking noise that goes away when the engine is started. Is this normal?
The fact that the headlight is not functioning is also preventing, in my opinion, the ABS lights from coming on.
BMWMOA - #47511
mr1150gs is offline
post #5 of 25 Old Jun 30th, 2017, 11:18 am
mtrevelino's Avatar
Being that the LT is a non CAN-BUS bike, the headlight should come on as soon as you turn the key on. Check to see if you are getting voltage to the headlight connector plug.
Just to clarify, not that it matters with year, the title of your thread is "07....", in your signature line, you have "2006..." LT.
Mike Trevelino
Williamsburg, VA
2008 RT
mtrevelino is offline
post #6 of 25 Old Jun 30th, 2017, 1:39 pm Thread Starter
mr1150gs's Avatar
Hi Mike, and thanks for your post.
Yes, just getting back into bikes after selling the 06 LT and 03 GS. Still have to figure out how to update my signature as this site is a little different then what I remembered, and cumbersome...
Regarding CANBUS, not sure if I do or do not have CANBUS, how do I tell? I thought a dead give away was the thinner electrical wires used indicating CANBUS.
Mauro
BMWMOA - #47511
mr1150gs is offline
post #7 of 25 Old Jun 30th, 2017, 1:58 pm
billr's Avatar
Mauro
The LT does NOT have a canbus electrical system.
Sent from my SM-G935T using Tapatalk
Bill Reitz
Surf City, USA
'06 Storm Gray Metallic LT
billr is offline
post #8 of 25 Old Jun 30th, 2017, 4:39 pm Thread Starter
mr1150gs's Avatar
Thanks for confirming.
BMWMOA - #47511
mr1150gs is offline
post #9 of 25 Old Jul 1st, 2017, 5:47 am Thread Starter
mr1150gs's Avatar
13 volts at the headlight connector plug.
Still puzzled as to why the top right 4amp fuse position on #2 box witch is allways live, turns on dash when fuse is replaced even though key is off.
BMWMOA - #47511
mr1150gs is offline
post #10 of 25 Old Jul 1st, 2017, 8:01 am
mtrevelino's Avatar
Once you install the replacement headlamp, that will at least take care of one issue. As others have said, either disconnect or remove completely amy non bmw installed device, and start fresh. Good luck!
Mike Trevelino
Williamsburg, VA
2008 RT
post #11 of 25 Old Jul 1st, 2017, 10:54 am
Which fuse are you referring too? I don't have the 2 box setup on the 05 so I can't go look.
Gordon
Sugar Hill, GA
post #12 of 25 Old Jul 1st, 2017, 1:31 pm Thread Starter
mr1150gs's Avatar
It is #7 on box 2 in your picture. It is indicated as the terminal 30 (not sure what that means), instrument panel, and control unit for EHCS. I have tested this to reveal this is allways live but when fuse is replaced it is as if you have turned the key to the on position. Makes no sense.
I also see that the tail light has an extra yellow where connecting one bulb to the center bulb. Removing this connection does not allow the center brake light to come on when applying brakes.
mr1150gs is offline
post #13 of 25 Old Jul 1st, 2017, 1:45 pm
#7 or fuse #15 on the schematic is an always hot line to the OBC so that would be normal. #6 or fuse #14 on the schematic is the switched power to the OBC from ignition. Check to make sure that fuse #14 ( 6 ) is not hot with the key off. This should be the wake up signal to the OBC. If this line is always hot also, then you have an issue there. If it comes and goes as it should with the ignition switch, then as I stated in the first post, the OBC is suspect as being bad and the dash lights are connected to the OBC according to the schematic.
You mentioned a clicking by the OBC, Not sure this is normal but I have an 01, not an 06 and they are slightly different but mine doesn't click. I suspect it is not normal for yours but someone who has one will have to confirm that part. Pull fuse 6 from box 2 and see if the dash goes off with the key off. If not, the you may be looking for another OBC or some short in that area.
Gordon
Sugar Hill, GA
post #14 of 25 Old Jul 2nd, 2017, 5:56 am Thread Starter
mr1150gs's Avatar
Thanks Gordon, will check that. Seems odd that everything else, apart from the non working headlight and one blown parking light, works fine. The dash lights show a fault which I attribute to these bulbs not working.
Mine is an 07 (still trying to figure out where I can update my signature on this site) but should be the same as an 06. Are you using the Clymer manual schematics?
Thanks, Mauro
BMWMOA - #47511
mr1150gs is offline
post #15 of 25 Old Jul 2nd, 2017, 8:16 am
Thanks, Mauro
Yes I am. Listed as 06 on.
Sig is updated under tools >> user CP from the top menu. Edit Signature in left sidebar.
Gordon
Sugar Hill, GA
post #16 of 25 Old Jul 2nd, 2017, 8:17 am Thread Starter
mr1150gs's Avatar
#6 is not hot with key off and dash, other than center display, goes off with key off. Low fuel indicator, temp, and distance to empty all work fine.
mr1150gs is offline
post #17 of 25 Old Jul 2nd, 2017, 8:26 am Thread Starter
mr1150gs's Avatar
Thanks!
BMWMOA - #47511
mr1150gs is offline
post #18 of 25 Old Jul 2nd, 2017, 9:00 am
Well, without anything else to go on, I would take a look at the OBC as the cause. I would suspect that whatever electronics are inside use the signal from #6 to turn on the lights. No idea id that is transistor driven and it has gone bad or relay driven and it is stuck.
Good luck.
Gordon
Sugar Hill, GA
post #19 of 25 Old Jul 2nd, 2017, 9:37 am Thread Starter
mr1150gs's Avatar
Not sure if it all stems from the headlight and one parking light being out. Will replace those and continue searching.
Would be good to know if the tail lights require the bulb to bulb connection or was that part of the brake strobe connection.
mr1150gs is offline
post #20 of 25 Old Jul 2nd, 2017, 9:43 am
The center rear brake light bulb needs to be in place and can't be an LED without added resistors. This bulb is fed by the ABS controller. The others are fed by a relay and they can all be removed or burnt out with no indication of an issue. Just the center bulb is monitored. All the other lights are not associated with the OBC where the dash lights are shown to connect.
Gordon
Sugar Hill, GA
post #21 of 25 Old Jul 2nd, 2017, 10:39 am Thread Starter
mr1150gs's Avatar
So that makes sense that the fault indicator on the dash. It was that center bulb that wold only come on with the yellow wire connection to the other bulb. But why did it not clear the fault on the dash?
mr1150gs is offline
post #22 of 25 Old Jul 2nd, 2017, 6:09 pm Thread Starter
mr1150gs's Avatar
So replaced #7 fuse (4 amp) in box 1, and the front parking light bulb that was blown, makes all work as it should provided I do not replace the #7 (4 amp) fuse in box 2. Of course the headlight is still out, but receiving power at the connector, until the replacement part comes in.
I see no relays on this bike but the OBC continues to be a suspect as to why the Demond #7 fuse in box 2 is not acting properly.
BMWMOA - #47511
mr1150gs is offline
post #23 of 25 Old Jul 2nd, 2017, 6:42 pm
Most of the OEM relays are in the electrics box under the tank but there isn't one specifically for the dash lights or lighting other than the brake lights. If there is a relay, it is built into the OBC but it is more likely a transistor but since I have never taken an OBC apart. I don't know. Some type of switch inside that senses the power from the key on.
Gordon
Sugar Hill, GA
post #24 of 25 Old Jul 2nd, 2017, 8:15 pm Thread Starter
mr1150gs's Avatar
URIKA!! Found some frayed wires at the front of the engin on the right side behind the fan housing. Also discovered the housing for the relays to determine it is the blue relay, top row that males the clicking noise that goes away when you start the engin. I'm going to assume this is normal perhaps to do with the abs system pre-test.
All fuses are in place and dash functioning as required with the key on.
Now wait for the Xenon replacement parts to get that working.
Thanks to all that replied, especially Gordon, for your help.
Mauro
bmwcoolk1200 likes this.
BMWMOA - #47511
mr1150gs is offline
post #25 of 25 Old Jul 2nd, 2017, 10:42 pm
Mauro
Congratulations. That blue relay is the one that flashes the ABS lights on the dash and is normal until you roll the bike forward a few meters, then they go out. Time to start enjoying it!!!!
Gordon
Sugar Hill, GA
How low to go to sale 03 LT? shotgun K1200LT 37 Apr 6th, 2017 5:50 pm
2002 K1200LT Electrical Gremlins and Other Adventures bmwollman K1200LT 15 Dec 29th, 2013 11:16 pm
Electrical Issues - Help! Goalie K1200LT 10 Oct 1st, 2012 10:27 pm
05 K1200LT electrical issues politiri Other K-Bikes Discussion 0 Jun 13th, 2012 11:21 am
Electrical Problem 2002 k1200lt reds K1200LT 1 Apr 7th, 2006 5:53 am
