2005 K1200LY - BMW Luxury Touring Community
post #1 of 7 Old Jun 22nd, 2017, 4:07 pm Thread Starter
2005 K1200LY
Riders,
I need some advice. My 2005 K1200LT needs a new battery. Can anyone spec a replacenment and are there any concerns replacing it myself? Anything else I should be concerned about?
Thanks!
PSobz is offline
post #2 of 7 Old Jun 22nd, 2017, 4:18 pm
JNW003's Avatar
Re: 2005 K1200LY
A lot of people replace the LT battery with an Odyssey PC680. I had one on my '07 LT, and when it comes time to replace the one in my GTLE, I'll probably go with it also. It's fairly simple to replace and there is a lot of info on this forum about how to do it...
Dave Beck
'16 K1600GTLE
'07 K1200LT (sold 9/24/16)
JNW003 is offline
post #3 of 7 Old Jun 22nd, 2017, 11:20 pm
Ron Williams's Avatar
Location: 26793 Madison Ave. STE 100. Murrieta, Ca. 92562
Odyssey pc680 is the only battery i will install in my bikes or my customers bikes period. The k1200 not only has a demanding electrical system it is the only bike i know of that has a full size alternator like a car. I believe at least 65 amps. The pc680 is a gell cell style battery and can discharge completely without hurting itself like led acid batteries will. When i started riding LT bikes i used led acid batteries but every time i let it sit for a week or so with the alarm on the battery would be dead. The lead acid batteries dont recover no matter how new they are.
Hope this helps.
Ron Williams is offline
post #4 of 7 Old Jun 23rd, 2017, 5:17 am
Re: 2005 K1200LY
The Odyssey PC680 is definitely the way to go. Whatever you do, just don't install it backwards. I see that a few people has installed a battery backwards and unfortunately, the electronics and wiring isn't forgiving.
dvpadgett is offline
post #5 of 7 Old Jun 23rd, 2017, 7:14 am Thread Starter
Re: 2005 K1200LY
Thank you all for the advice. Ill check with the dealer on the PC680, sounds like thats the choice! Apologies for the multiple spelling errors in original post...
PSobz is offline
post #6 of 7 Old Jun 23rd, 2017, 8:12 am
Re: 2005 K1200LY
Don't forget the TPS(throttle position sensor)reset any time you disconnect the battery: With the key on, but the engine not running, rotate the throttle slowly from off to full. Do that three times.
Buck W.
San Diego
1999 K1200LT
Canyon Red
Buck is offline
post #7 of 7 Old Jun 24th, 2017, 10:37 am
fatbob307's Avatar
Re: 2005 K1200LY
Also, very important! Disconnect the negative lead first, then positive. When connecting new battery connect positive lead first, then negative. Never have just the negative lead connected. This can fry an ECU. BTDT.
fatbob307 is offline
Used 2005 vs.2007, To SERVO or not? njfatz RT Series 13 Apr 2nd, 2016 7:37 pm
2005 RT and 2011 RT dinku RT Series 12 May 13th, 2011 2:00 pm
Who replaced a O2 sensor on a 2005 LT?? bowdon K1200LT 8 Apr 14th, 2010 8:36 am
Does Post 2005 BMW K1200LT Logo Emblem fit Pre 2005 models? MattKas K1200LT 1 Jan 27th, 2008 3:33 pm
Metzler 880 vs. BT020 debate on 2005 and up Crestwood330 Tires 16 Dec 16th, 2007 7:17 pm
