Radio Panel Problems.... - BMW Luxury Touring Community
post #1 of 8 Old Nov 25th, 2006, 6:23 pm Thread Starter
Unhappy Radio Panel Problems....
Bike has been garaged since '03 birth...only wet during rides and occasional washes. Today while setting stations on AM, I decided to start the bike and bingo...it all went blank. Blank as in nada!
Dealer said I shouldn't have started the bike with radio on! Can you imagin saying something like that?
So now it appear as another $500+ is going down the toilet due to the over-engineering of the turds in the Fatherland!.
BMW - Bring More Wompum! Turds all. . .gawd, what a disappointment!!
Next bike won't have the electronic crap...possible my remote XM portable will be hooked up so I can listen to the Cowboy games (America's team)during the Funday rides.
Anyone have experience with this type problem??
Thanks, HT
harleeetom is offline
post #2 of 8 Old Nov 25th, 2006, 7:22 pm
Thanks, HT
HT - I've never heard that one. Fact, I think I've done just that a coupla times. At any rate, before you shell out some bucks - and I assume you're saying the radio display went blank, not the whole dash; and the bike DID start? - I'd disconnect the battery for about an hour or three, then re-connect and see if the radio is re-born. Seems that has been a cure for some folks who were experiencing weird problems related to the radio. HTH.
Edit: forgot; after you reconnect the battery, and before you start the bike - turn on the ignition; twist the throttle grip to wide open and let it snap back (do that twice); then start the bike and ride around the block or so and let the Motronic relearn the throttle settings; then try the radio and see if the problem is gone.
post #3 of 8 Old Nov 25th, 2006, 11:00 pm
And in addition to what Dick suggested:
Make sure to check the fuses. IIRC there is one under the seat in one of the fuse boxes and another on the back of the radio unit under the stingray. (Seems that the sound system has multiple power feeds.) Not sure as to which fuse box, but sure someone will jump in.
HTH (True to my sig line!)
Duane
Check the obvious first!
73 Z1 Kawi
and 7 long gone
Dman is offline
post #4 of 8 Old Nov 26th, 2006, 12:31 am
Zotter's Avatar
Poppy Squat - I can count on one hand the number of times I've started my '02 without the radio turned on. It's *always* on!
Tate
02 Mauve - my 'Light Truck'
Zotter is offline
post #5 of 8 Old Nov 26th, 2006, 5:04 am
atps1234's Avatar
Radio can get hung on engine start
Believe it or not, this happened to me twice. Both times, disconnecting the battery for 1/2 hour or so fixed the problem. I asked the service guy at my local dealer about this, and he said (no lie) that the radio can get hung on startup if it is on at that time. He recommended that I turn off the radio after shutting down, and waiting until the engine is started to turn on the radio. I did get into the habit of turning off the radio and turning on only after the engine is started. 2 yrs and no more problems.
OB
Bob OB
Sedona, AZ
'08 R1200RT Sand Beige Metallic
atps1234 is offline
post #6 of 8 Old Nov 27th, 2006, 10:03 am Thread Starter
Wink Radio Panel Problem...SOLVED
Thanks to all for the responses on this unique if not strange phenomenon!
Before posting original 'cry for help'...I did disconnect the battery for about 5 minutes without postive results. So after reading Dick's suggestions, the plan was disconnect for 1-3 hours at conclusion of yesterday's Polar Bear central New Jersey ride and hope for the best.
Long and 'short' (no pun intended)...once disconnected I decided to hold the hot line to the post for one last try before going inside for the night.
Bingo...the original station starting playing as if nothing happened. All presets were working so I folded up the tent, reset the clock, reset the throttle as suggested and went to bed.
Thanks again...Tom Spader #119635
K12LT
R11RT
'Busa
post #7 of 8 Old Nov 27th, 2006, 10:06 am
rkirker's Avatar
MY 02 Raidio and XM always on
Me Too Everytime.
Can you turn the radio off ?
Rich Kirker
2002 LTC Pacific Blue
Caliper Moto Lights, Hyper light brake lights, Spiegler brake lines, Ride West side markers, Grip puppies, HyperPro Springs and CA HID Kit.
BMWMOA #124306
2009 Honda Shadow (Wife's)
Blue & Pearl
"Well It’s not rocket science but absolutely a nightmare. At the end of the day you had a fairly unique situation that I personally at this moment in time could see me having as well 24/7. With all due respect, it shouldn’t of happened."
rkirker is offline
post #8 of 8 Old Nov 27th, 2006, 10:14 am
Zotter's Avatar
Dang Rich - should we start knocking on wood or something?
Mmm, wonder if I can get a wooden cup holder......
Tate
Zotter is offline
Radio/CD Problem JohnR K1200LT 22 Jun 28th, 2009 8:43 pm
Need to remove the radio control panel Harby K1200LT 4 Sep 3rd, 2007 6:29 am
radio problems jmc88_2 K1200LT 7 May 3rd, 2007 2:26 pm
Radio Panel...'03 LT harleeetom Trailers, Sidecars, & Trikes 0 Nov 25th, 2006 5:49 pm
Radio control panel barryst1100 K1200LT 3 Mar 13th, 2006 10:20 am
