Two sided tape - BMW Luxury Touring Community
post #1 of 13 Old Nov 25th, 2006, 5:37 pm Thread Starter
Two sided tape
My crome strip on the right saddle bag keeps coming loose and I keep pushing it back on. I have tried the auto zone tape but it does not hold well. I had to remove the strip to do a repair (not to the plastic). Now can not find a tape that holds well.
ltride is offline
post #2 of 13 Old Nov 25th, 2006, 5:47 pm
Motomadman's Avatar
Did you remove all the old tape residue? When I do and install like this I use some rubbing alcohol to clean up the plastic before tape install. Molded plastic pieces need a release agent to keep from sticking to the molds when manufactured.
Craig Hutchison
02 Pac Blue (Aka Blue Ox)
34° 14’ 12.63 N
119° 01’ 21.64 W
Why coast through Life when you can Corner it.
Motomadman is offline
post #3 of 13 Old Nov 25th, 2006, 5:47 pm
Senior Member (ret.)
RaffyK's Avatar
3M make a few. They come in narrow or wide strips. Lowe's or Home Depot.
Raffy
RaffyK is offline
post #4 of 13 Old Nov 25th, 2006, 5:56 pm
cccpastorjack's Avatar
Gorilla Snot???? Try This!!!
You might try 3M Weatherstrip Adhesive (otherwise know as "Gorilla Snot")! Follow the instructions on the tube and just be careful...'cause you will find out how it earned its name! Don't use too much or it will squeeze out around the sides. This stuff works!!!!!
Jack Homesley
Cornelius, NC USA
Too many others to list...
cccpastorjack is offline
post #5 of 13 Old Nov 25th, 2006, 6:08 pm
RonKMiller's Avatar
You specifically need the "exterior" rated 3M tape - it is grey and has a red backing. Clean both mounting surfaces with alcohol first and make sure you apply the tape when it is warm - 70F or better. You'll need to cut it into some thin strips and place some near the top and bottom of the piece you are going to attach, less is best. Insert the back of the trim into the notch at the rear of the saddle bag, then press the rest of it along to the front. Push HARD.
If it is colder than 70 the visco foam backing does not compress very well to irregularities or curves, and the glue does not stick. A hair dryer works great to get both surfaces warmed up.
ID:	8362   Click image for larger version
"Like Butt-ahh!"
RonKMiller is offline
post #6 of 13 Old Nov 25th, 2006, 6:28 pm
RonKMiller's Avatar
Awesome stuff on rubber weather stripping, but unfortunately it won't work for plastic on plastic.
"Like Butt-ahh!"
post #7 of 13 Old Nov 25th, 2006, 6:55 pm
I second the stuff RonKMiller recommends. It holds my computer speakers to the side of my monitor. Also used it to hold my decorative license plate frame to the rear door of my car to stop the annoying rattle every time I closed the door. I got mine at WalMart.
TimVipond is offline
post #8 of 13 Old Nov 25th, 2006, 9:51 pm
Super Moderator
dfinazzo's Avatar
Cool 3M Tape more than adequate
Worked on a project 15 years ago with 3M and is was the preferred method to attach truck bodies to frames for industrial box vans and trucks. Outperformed welding, bolting, screwing and riveting in fatigue, rust, mechanical and environmental tests in overall ownership and fleet maintenance.
So all you need to do is find the right stuff, provide for proper surface preparation and apply it correctly - will most likely meet all your requirements.
Most body shops and 3M tape distributors can help. But since you need so little the red backed tape mentioned should do the trick - it is just one of the commercial grades you can try out . . .
Dan Finazzo
dfinazzo is offline
post #9 of 13 Old Nov 26th, 2006, 7:12 am
Schweintechnik's Avatar
Cool It's in the tape!!
Like Ron said, you need the right stuff. 3M makes Automotive Attachment Tape, which is what we often use at H-D to put medallions on fuel tanks. Make sure surfaces are cleaned (with alcohol) and warm.
There are many varieties of 3M's Automotive Attachment tape - the gray stuff (0.030" thick), white (0.045" thick, stronger than gray), and two blacks (0.045" and 0.060" thick, the strongest of all double-stick tapes on Earth). You can find 3M's product info here and here, and you can buy some of the stuff at Amazon here. I would go with this stuff.
'03 K1200LT-C Dark Graphite
Schweintechnik is offline
post #10 of 13 Old Nov 26th, 2006, 5:31 pm
deputy5211's Avatar
Another vote for the 3M exterior tape, grey with red backing. It works great on everything I've used it for so far. Echoing what RonKMiller said, just be sure that you clean both surfaces VERY well and make sure that the tape and the material to be adhered are warm (70F -ish).
Fair warning, though. You have to be really careful with this stuff. My wife used a oiece of this tape and now I can't get her off my back
Tony
deputy5211 is offline
post #11 of 13 Old Nov 27th, 2006, 7:09 am
Lol
Tony
1 vote for quote of the month.....
post #12 of 13 Old Nov 30th, 2006, 11:53 am Thread Starter
Thanks to Ron and all for the info and help. I will diffidently keep this away from my wife.
ltride is offline
post #13 of 13 Old Nov 30th, 2006, 12:06 pm
graydude's Avatar
3M Helps
Being a 3M'er, I'm often asked about one of the 85,000 products 3M makes. I always refer folks to a great source. call 1-800 3M helps (800-364-3577). There you will talk to a live body and they can help you find a source for what you are looking for.
2005 K1200 LT "Graphite Graydude Metallic"
Todd "Graydude" Ask me why I'm the best Realtor you've ever met!
IBA#22266
graydude is offline
Beware of Jiffy-Lube - Caught on Tape deliberate fraud usmctpdog Chit Chat 12 Sep 7th, 2006 9:01 am
Black reflective tape... Indeed it works ! buffalo K1200LT 6 Aug 5th, 2006 7:42 pm
Reflective BLACK tape buffalo K1200LT 19 Jul 24th, 2006 9:36 am
Books on tape or CD Moonshine iPod/MP3 10 Jan 5th, 2006 4:18 pm
reflective tape on LT RaffyK K1200LT 10 Oct 31st, 2005 11:22 am
