Headlight problem. - BMW Luxury Touring Community
post #1 of 15 Old Nov 25th, 2006, 10:15 am Thread Starter
Headlight question.
I did a search, but couldn't find anything on this.
I've got a 2003 K1200LT that I bought used a couple of months ago. The headlights are nowhere near as bright and don't seem to be aimed as far down the road, as the ones on my Yamaha Majesty scooter I had before this. I don't even get lights blinked at me at night, when I'm on hi-beam. All the bulbs work.
There is this little gizmo on the dash that is supposed to adjust the light depending or rather you're carrying a passenger. All it does is spins freely. I understand that this is supposed to adjust the lights for passenger/no passeenger. I assmue you lower the light when carrying a passenger, since the weight on the back would raise the front of the bike.
Any way to tell what position the light is in by looking at it? Any way to raise it or to fix the gizmo (which I figure is broken.) that is supposed to raise them?
CajunBass is offline
post #2 of 15 Old Nov 25th, 2006, 10:33 am
zippy_gg's Avatar
The adjusting cable is either loose or broken, as the knob should not spin freely as you describe.
The bummer is that you need to take a bit of tupperware off before you can get to either end of the cable if you need to replace it or find what is wrong with it.
Also there are 2 adjusting screws, one for horizontal and the other for vertical adjustment, in the headlight assembly. You may want to start with these first as the knob is more for fine tuning. You should be able to get to those without disassembly, it is just a bit tricky.
I'll try to attach a headlight assembly part fiche when I have a moment...
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #3 of 15 Old Nov 25th, 2006, 10:41 am
Shogun54's Avatar
The knob turns a cable that is routed to the throttle side of the headlight housing under the noseone. It turns a lever that will alter the aiming of the headlight. It is possible that the cable is not connected or the knob is stripped. Regardless, it is possible to access the mechanism on the headlight. There is an adjustment screw (Phillips) directly below the lever that is used normally to fix the aim with the adjustment knob . If you're able to reach it, turning the screw LEFT raises the light, Right lowers it.
HTH,
Brett
Get busy livin' or get busy dyin'!
2003 BMW K1200LTC "El Gato Grande"
1993 Suzuki GSXR1100W
1978 Suzuki GS1000C 'Project'
Shogun54 is offline
post #4 of 15 Old Nov 25th, 2006, 10:46 am
zippy_gg's Avatar
Lightbulb I forgot...
to state the obvious (at least for those who dunnit)... The best way to cure the poor lighting on the LT is a low beam HID kit, and since you may have to take the nose cone off (if your adjustment cable is broken or loose) you might as well install one. There many threads on HID and a few nice write-ups with photos to help you.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #5 of 15 Old Nov 25th, 2006, 1:59 pm
Schweintechnik's Avatar
May be nothin' at al
Before you get too far down the road...
When I first bought my used 2003 LTC, I also thought the headlight knob was turning freely. I kept turning, and turning, and turning, and turning... and then finally it stopped! It just has like 429 revolutions from stop to stop.
Also be VERY careful in that you can quite easily over-torque the knob at the end of its travel, and then it will really be spinning freely! (Or just break off in your hand)
To verify whether anything's actually going on or not, go out into your driveway at night, close the garage door & shine the headlight on it from about 20 feet away, and start turning the knob. You will see very, very gradual movement of the top cutoff of the pattern against your garage door (hopefully).
I ride with mine all the way down.
And, oh yeah. Go get an HID setup!
'03 K1200LT-C Dark Graphite
Schweintechnik is offline
post #6 of 15 Old Nov 25th, 2006, 2:35 pm Thread Starter
Thanks everybody, especially you Dave. I'll have to keep turning mine. There isn't much resistance, but it might be what you say. I was expecting a short click one way, then the other.
I'll keep y'all posted.
post #7 of 15 Old Nov 25th, 2006, 2:56 pm
SilverBuffalo's Avatar
I'm gonna hafta go along with "Zippy" on this one,
you may have an adjustment cable issue,
but repairing that is not going to solve your inadequate light problem,
the LT has by far the worst stock headlight of any motorcycle I have ever had.
Forum members have tried every possible thing you can imagine to add more lighting to these bikes,
but the bottom line is nothing, absolutely nothing will improve your lighting more than an HID headlight conversion.
Their prices have come way down to $111.
you don't have to take my word for it do a search for HID, you want the H7 5000
it's worth every penny.
http://cqlight.ca/index.php?cPath=32_45
Hans
St. Petersburg FL
2002 K1200LTE
"Silver Buffalo" Totaled 5/06
2005 LT
"Esperanza"
BushtecGenesisTrailer
SilverBuffalo is offline
post #8 of 15 Old Nov 26th, 2006, 4:14 am Thread Starter
Thanks Dave. You were right. I fooled with it last night, and turned it a few dozen times, and it came up.
I'll have to check out some extra lighting. The ones on my Majesty would light up the road like daybreak. I'm really disapointed in the ones on the Beemer. (That's about the only thing.)
post #9 of 15 Old Nov 26th, 2006, 6:44 am
Yippeee!
Glad it was the quick fix! Like Zippy said, this knob is the "fine" adjustment - if you had to turn it all the way to the opposite end of travel just to get it to peek up into the 'normal' range, at some point you may want to pull the nose cone and make the macro adjustments using the adjusting screw(s).
Everyone's right - you will be just as impressed (if not more) with a new HID low beam as you are disappointed with the stock halogen low beam. SilverBuffalo recommended the 5000K H7 from cqlight.ca - you can also go to hid-online.com and get a 4100K H7. When you do your forum and HoW search for HID, you'll find ('specially from David Shealey) that the lower the HID color temperature, the better, where 5000K is about as high (higher=bluer) as you wanna go, and lower (4100K for example) provides whiter, more effective light.
The job involves a nose cone pull, a small amount of drilling & filing plastic, a probable glue-up of a small block to create a level shelf on top of the headlight housing, and some basic electrical wiring with relays. By no means rocket science, and a good Saturday project if you're by yourself, you've never pulled the Tupperware before, and you want to work at a methodical pace. Better yet - look for a tech session in your area, and you're bound to find one where others are doing it and others have done it before.
post #10 of 15 Old Nov 27th, 2006, 7:15 am Thread Starter
Wow. What a difference. I rode to work this morning and instead of the headlights pointing at the ground in front of me, they were actually pointing down the road. I could SEE! Wooo Hoooo!
Totally off topic, but I also got the bike on and off the center-stand without dropping it. Another first.
post #11 of 15 Old Nov 27th, 2006, 6:10 pm
Steve_R's Avatar
Standing to the side or astride it?
On His Ride,
Steve
KA5MTE
'00 Unigo - Dragon's Egg
Have you
bmwlt.com lately????
Steve_R is offline
post #12 of 15 Old Nov 27th, 2006, 7:12 pm
zippy_gg's Avatar
Talking
I would suggest to the side to put the bike ON the center stand, and astride or to the side to take it OFF the center stand. I wouldn't even venture to try putting it on the center stand while astride!!! Way too awkward!
I would also suggest riding while astride... but it's just my opinion.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #13 of 15 Old Nov 27th, 2006, 8:03 pm
Steve_R's Avatar
Gilles,
I was asking Wayne because of a discussion we had here in another thread. I was checking to see if had taken my advice. I always come off the centerstand astride the bike.
On His Ride,
Steve
KA5MTE
Have you
Steve_R is offline
post #14 of 15 Old Nov 28th, 2006, 9:03 am Thread Starter
Astride it Steve. I'm not going "by the book" anymore on that.
post #15 of 15 Old Nov 28th, 2006, 12:16 pm
zippy_gg's Avatar
Talking
Gilles,
Yes Steve, I remember that thread... I just could not resist being my silly self.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
Radio Problem fixed thanks to the HoW... lhamonic K1200LT 8 Oct 20th, 2016 11:30 am
Rain induced problem on '04 LT? bwdjr K1200LT 3 Nov 19th, 2009 11:01 am
Weird electrical problem ronbok K1200LT 5 Jul 2nd, 2008 10:37 pm
Headlight Problem mistral K1200LT 5 Oct 3rd, 2006 2:56 pm
Oil Usage Problem Solved..Finally herk402 K1200LT 7 Sep 26th, 2006 12:51 pm
