Help: Missing wires! - BMW Luxury Touring Community
post #1 of 4 Old Nov 24th, 2006, 4:46 pm Thread Starter
dencla's Avatar
Installed a Garmin 2610 on my (reconstructed) 05, There is a gps support with two wires sticking out from under(they become one), one of wich slides on the GPS, the other a round affair with lots of contacts?? When I tried the GPS, it would not fire up?? Took the plastic off yesterday and found out why: the said wire is not plugged into anything!! I am now trying to find out what wire I have to get to power the unit and where does it plug in?? That's not the only mystery, I also found another plug that does nothing (no it does not fit the one from the GPS!!) I have included a couple of pics and I am sure someone out there will easily recognize them and light my lantern. The one coming from the GPS ends with a white plug (07 686 670)That's the one that needs power, it has three wires. The "mystery plug" is black and has four wires. Thanks, Denis
ID:	8324   Click image for larger version
ID:	8325   Click image for larger version
ID:	8326   Click image for larger version
ID:	8327   Click image for larger version
dencla is offline
post #2 of 4 Old Nov 24th, 2006, 5:21 pm
Denis, I'll let someone with an '05 LT give you the positive answer, butt on my LT, that connector with the female white insert lives just to the left of the other two connectors. There is a slide rail that the connector snaps onto, and a corresponding male plug connects there. I can't remember what the connector/plug handles, butt like I said, that is what my '99 LT has. If I'm right, there you should find the male plug back underneath the stingray 'shoulder'.
post #3 of 4 Old Nov 24th, 2006, 5:36 pm
Denis - a follow up to my post. I checked on a couple of the 'similar threads' displayed below your thread and found this. Don't know if helps, butt hope so.
post #4 of 4 Old Nov 24th, 2006, 9:23 pm Thread Starter
dencla's Avatar
Will have to check that tomorrow, will let you know, thanks
dencla is offline
running wires for trailer NOGILLS2 Trailers, Sidecars, & Trikes 10 Mar 4th, 2012 8:22 pm
Autocom Super ProAVI, am I missing something Doug_Gentry Intercom, CB, & 2-Way Radios 2 Oct 16th, 2006 7:19 am
TB's / Plug Wires & and the test rides bushj1 K1200LT 4 Mar 18th, 2006 5:43 pm
Finding power wires on the radio strsout Batteries, Chargers, & Electrical 0 Jan 22nd, 2006 2:44 pm
Eaten wires airborne K1200LT 10 Oct 30th, 2005 12:40 pm
