Clutch Maintenance Questions - BMW Luxury Touring Community
post #1 of 5 Old Nov 24th, 2006, 12:07 pm Thread Starter
Question Clutch Maintenance Questions
The clock turned 39K miles last week. I noticed a slow transmission engagement after I let the clutch out under a quick acceleration, and it repeated under the same conditions. No other suspicious behaviors related to the drive train. Is this normal?
I was thinking that maybe itís a sign the slave cylinder is failing. What do the experts say? Could the clutch plate be wearing thin or some other clutch assembly component be in need of replacement?
I was planning on doing a major service, replacing the shocks, and drilling the slave cylinder housing between Christmas and New years. Should I stop riding and commence with tearing it down immediately?
Regards,
2000 K1200 LTC - Canyon Red
jgburns is offline
post #2 of 5 Old Nov 24th, 2006, 12:29 pm
IF it is clutch slave cylinder leakage causing the problem, it is too late to save the clutch. Once brake fluid contaminates the clutch plate causing slippage, there is no going back, the clutch plate will need replacing. Sounds like you may be just a little late drilling the drain hole. By the way, it is not the slave cylinder housing you drill, it is the transmission housing. I assume you just used the wrong terminology. Would not want to see anyone start drilling into the slave cylinder.
Clutch plates wearing out is not in any way usual, and has happened to only one or two that I can remember being posted about in the 5 plus years here. The clutch has to be pretty severely mistreated, or something else wrong to wear it out.
post #3 of 5 Old Nov 24th, 2006, 12:55 pm Thread Starter
Dave, thanks for the feedback. Wrong terminology about the drilling remark (I've been reading, not studying, the sections on the clutch).
Since there is no slippage under normal riding conditions, does that mean it's NOT the lave cylinder leaking DOT 4 into the clutch plate area? Or, could this be the first signs it is leaking?
Regards,
jgburns is offline
post #4 of 5 Old Nov 24th, 2006, 2:20 pm
The best way to determine if it is fluid contamination that I know of is to accellerate full throttle in 5th gear from about 2,500-2,000 RPM, if the clutch is contaminated it will go up to some RPM and all of a sudden break loose when the engine power exceeds the clutch's ability to hold it.
post #5 of 5 Old Nov 24th, 2006, 10:54 pm Thread Starter
Thanks Dave, it passed that test. However, I decided to not delay in drilling the transmission housing and doing the other planned maintenance.
Regards,
jgburns is offline
Unreliable clutch advice please cyclecamper K1200LT 11 Dec 1st, 2008 10:23 pm
No Clutch! birdman K1200LT 8 Sep 6th, 2006 11:36 am
Clutch Questions? surfran K1200LT 5 Jun 27th, 2006 12:44 pm
lost my clutch parishollow K1200LT 11 Jun 6th, 2006 7:45 am
