Brake failure light falshes and warning light stays on. - BMW Luxury Touring Community
 2Likes
  • 1 Post By red85k100rs
  • 1 Post By jzeiler
post #1 of 17 Old Jun 5th, 2017, 9:17 am Thread Starter
RockyW's Avatar
Red face Brake failure light falshes and warning light stays on.
I've posted this earlier but can't seem to find my thread on this, anyway I am unable to figure out why the brake failure light comes on (2002 K1200LT), all is full of fluid, this started when the front brake line was replaced and the guy that had it before me didn't add fluid in the frt. reservoir, after I filled it and bled the system the light went out and about 3 weeks later it came back on , I keep finding bleeders in places I haven't seen before, is there a specific way of bleeding the system if so does anyone know the procedure, I know you go from farthest from MC to Shortest but not sure on the ABS. Also sometimes it stays off for several miles before it comes on and sometimes it comes on right away.
RockyW is offline
post #2 of 17 Old Jun 5th, 2017, 10:07 am
bmwcoolk1200's Avatar
Re: Brake failure light falshes and warning light stays on.
Rocky, here is a video specific to your version of ABS with the dual reservoir located on the right side at the front of the passenger seat.
https://www.illinoisbmwriders.com/se...egrated-brakes
having the funnel referenced in the first post you made on this makes the job much easier.
Servo Assist Brake Bleed/Flush Funnel Tool
And lastly, if you click on your own name in this thread and open the user profile, you will see a statistics tab and on that, there are links to see all your posts and all of the threads you have started so you don't need to start a new thread if it falls out of view off the home page.
Gordon
Sugar Hill, GA
bmwcoolk1200 is offline
post #3 of 17 Old Jun 5th, 2017, 6:12 pm
In a nut shell there are two separate circuits for both the front and the rear and fluid does not go between them. Front control has a reservoir on the handle bar and it is bled at the ABS. The front wheel circuit reservoir is the rear half of the reservoir under the pillion seat and it is bled at the front calipers. The front half of that reservoir is shared between the rear control (bled at ABS) and the rear wheel (bled at the rear caliper). The pillion seat reservoir has both chambers monitored for fluid level ad it is very sensitive to a small drop in fluid.
The attachments show the F and R control circuit ports on the ABS and for a proper bleed do 1,2 3 and 1 again on both the front and rear.
The control circuits can be bled with the key off. The wheel circuits require the key on.
ID:	126961   Click image for larger version
post #4 of 17 Old Jun 5th, 2017, 8:57 pm
guitarjim's Avatar
Are you sure both containers are full that are located under the seat? One of those containers is difficult to see and get to. For me, I just had to top up both of the containers under the seat to get the light to go away and the flashing lights haven't been back since.
Current Ride: '02 LT - The Mistress
guitarjim is offline
post #5 of 17 Old Jun 6th, 2017, 6:45 am
I found an 02 k1200lt for a friend, ABS lights were blinking alternately. The dealer (honda) thought it needed $2200 servo and just wanted to unload it.
He drove it home 300 miles with the lights blinking. We took off the seat and added less than $1.00 brake fluid. All is good 1700 miles and smiles so far.
37k miles, loaded.$1500 Even came with a super nice $170 BMW drink holder, J-pegs, Bead seat pad, Cover, pretty new tires.
Patric likes this.
red85k100rs is offline
post #6 of 17 Old Jun 7th, 2017, 4:57 am
The same with me with my 2005, which only has one small round container under the seat.
The strange thing is that apparently and visually, this container doesn´t have any electrical connections leading to or from it.
simoncharles is offline
post #7 of 17 Old Jun 7th, 2017, 4:11 pm
It doesn't. The sensors are on the reservoirs on top of the ABS unit itself on the 05 and up. On the 02 - 04, there is a dual reservoir in the place where your single round one is and that one does have sensors.
Gordon
Sugar Hill, GA
post #8 of 17 Old Jun 7th, 2017, 5:26 pm
Understood, but what tells the computer that the fluid level is low ?
post #9 of 17 Old Jun 7th, 2017, 7:30 pm
There are floats in the ABS units built in reservoirs and connectors on top of the floats.
Name:	Reservoir Float 17.JPG
ID:	127049   Click image for larger version
simoncharles likes this.
post #10 of 17 Old Jun 7th, 2017, 8:04 pm
JZ has the ABS reservoirs covered for the wheel circuits and how the computer measures them. There are no sensors on the round reservoir or on the handle bar reservoirs so they could go dry and you would not know it until that happened or until you do a visual inspection.
Gordon
Sugar Hill, GA
post #11 of 17 Old Jun 8th, 2017, 2:21 am
Again, understood, and thanks to both of you, but I still do not understand how, by just topping up my reservoir from in-between MIN and MAX to just above MAX, solved my problem.
post #12 of 17 Old Jun 8th, 2017, 3:37 pm Thread Starter
RockyW's Avatar
Thanks for all the info , does anyone know which bleeder Ion the abs I need to bleed first or is there an order to do this?
RockyW is offline
post #13 of 17 Old Jun 8th, 2017, 5:05 pm
http://www.ascycles.com/pdf/Integrat...ntegralABS.pdf
post #14 of 17 Old Jun 9th, 2017, 10:26 am Thread Starter
RockyW's Avatar
Thanks for the info Voyager, I'll get this to Engineering ASAP. :-)
Live Long and Prosper.....
RockyW is offline
post #15 of 17 Old Jun 9th, 2017, 2:48 pm
When you asked about the Ion bleeder, I assumed you were working on an impulse drive.
post #16 of 17 Old Jun 9th, 2017, 3:52 pm
Ludicrous speed GO!!!!
Gordon
Sugar Hill, GA
post #17 of 17 Old Jun 9th, 2017, 7:23 pm
Just like the 05 + link Voyager posted 123 and then 1 again for a proper bleed only use the diagram in my earlier post (#3) as yours is oriented different than the 05 diagram and use the F1, F2, F3 and R1, R2, and R3.
