2003 K1200LT brakes dragging - BMW Luxury Touring Community
post #1 of 5 Old Jun 4th, 2017, 4:00 pm Thread Starter
My '03 K1200LT has 65,000 miles. Bought from a dealer with no warrenty a month ago. After 500 miles of riding, there is a problem with the brakes. A couple days ago, After a stop, the bike didn't want to move. I could tell the brakes were hanging - felt like the fronts. I squeezed the brake lever about six times, and felt the brakes release. The red triangle warning light lit, and stayed on. No other warning light. About 10 miles down the road, I braked lightly while driving, and felt the brakes hang. I kept the bike rolling at 50 mph, and squeezed the brake lever rapidly. That cleared the hangining. Parked the bike for about an hour, and drove 20 miles home with no issues, no triangle light. Today, everything was fine until I pulled the clutch in to start shifting down for a stop sign. The brakes activated by themselves - big drag but never touched the levers. I squeezed the brake lever rapidily, and it cleared up. Red warnng triangle again. No other warning light.
The previous owner put SS lines on front and back. I'm trying to figure out what is causing this. From what I've seen on this forum - it could be a couple things. I don't have a code reader handy.
toddk is offline
post #2 of 5 Old Jun 4th, 2017, 6:11 pm
Re: 2003 K1200LT brakes dragging
Could be some air in the control lines and as they warm up they are applying pressure to the servo unit. Two things cause the brake servos to run; 1. Brake pressure in the control line, 2. Activation of one of the brake switches (lever or foot pedal). Since there were SS lines put on I would first do a good bleed of the system but be sure you understand it before you try it as there are two separate circuits for both the front and the rear. Check out the video here done by Kirk. Although it is just a flush and not a full bleed the techniques are the same.
Also the ABS is oriented vertical on yours and the reservoirs are off the ABS unit. Front half is shared between the rear control and rear wheel circuits, the back half is for the front wheel circuit.
ID:	126929   Click image for larger version
post #3 of 5 Old Jun 5th, 2017, 3:17 pm
beech's Avatar
I've seen a pebble jam in the rear brake arm causing trouble.
Beech
beech is offline
post #4 of 5 Old Jun 5th, 2017, 5:42 pm
Axle's Avatar
Funny I was going to say the same thing, but thought better of it. I too have seen this. The dealer freighted it back 5 hours to workshop under warranty, flicked the stone out then sent back to owner another 5 hours.
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #5 of 5 Old Jun 9th, 2017, 10:34 pm Thread Starter
Interesting follow up. I had a hunch that it's going to need the brakes bled. The stainless lines looked relatively new. When I had the hanging, I was using both brakes. I've ridden four days with only using the front. No problems. My guess is that the rear integral system needs bleeding.
toddk is offline
What is the best brakes for an 05 K1200LT dcsorric K1200LT 5 Jun 11th, 2017 9:05 am
Replacement Battery for 2003 K1200LT curtamus K1200LT 22 Jun 30th, 2012 4:05 pm
About to buy a 2003 K1200LT, any advices? franncisco K1200LT 18 Sep 20th, 2011 10:19 pm
How to: Change brakes on 2003 K1200LT? clanmclain K1200LT 1 Jan 28th, 2011 3:15 pm
