help, wiring, turn sig cancel, autoswitch - BMW Luxury Touring Community
post #1 of 7 Old Nov 23rd, 2006, 3:14 pm Thread Starter
hdfan's Avatar
Question help, wiring, turn sig cancel, autoswitch
weekend project of HID and motolights and other signal safety farkles yahoo.
1) Is there a way to connect to the turn signal cancel at the rear of the bike instead of on the handle bar?
2) Vectra lights. I can get the TS and power from the turn signal but where is the best place to tap into the brake light for both the right and the left side application? If it is in the same harness as the TS cancel, maybe I am better off doing it all at the handle bar anyway (see number 1).
3) Motolights. When people say "slave" to the low beam I assume they mean connect the "relay switch power lead from the mototlight instructions", (the only free wire I have after battery pos and ground), to the wire that feeds the low beam such that it is always on? Can I connect to the power to the map light instead? It appears more easily accessable. I just want to make sure that the motolights are on all the time unless I switch them off with the provided switch.
Bike, 2003 LT
Thanks for your wisdom. Ken
hdfan is offline
post #2 of 7 Old Nov 23rd, 2006, 8:11 pm
I'm assuming you are using an AutoSwitch. The AutoSwitch must be on the wire that the comes from the canel button on the right grip. As far as I know that wire is a signal wire to the computer to turn off the signal lamps.. it is only easily available just forward of the cancel switch. That is where I attached my AutSwitch.
IMO the easiest place to attach the pick signal for the relay is to the wire that provides 12v to the seat heater. It is active except when starting.
2001 Black LTC
2015 Blue R1200GSA
jackd is offline
post #3 of 7 Old Nov 23rd, 2006, 8:59 pm
Just ridin'
Randy's Avatar
No. You have to connect to the cancel wire at the handlebar or at the electrical junction box under the fuel tank.
You will have to bring a brake light wire back from the rear of the bike. There is a way to tap in in the electrical junction box under the fuel tank, but it is much easier to bring a wire up from the taillight or taillight wiring connector under the topbox. You would still connect the MotoLights power (fused line) directly to the battery.
Using the provided switch, I would recommend that you get the power to the switch from the low beam headlight lead. If you used the map light the MotoLights would not go on and off with the ignition key. An additional benefit of using the low beam lead is tying the MotoLights to the load shhead feature of the starter circuit, causing the MotoLights to go off when the engine is being started. The low beam wire is white/yellow at the headlight connector.
Bike, 2003 LT
Thanks for your wisdom. Ken[/QUOTE]
Randy Prade
Aurora, CO
Just ride it!
Meet Riley
Randy is offline
post #4 of 7 Old Nov 23rd, 2006, 10:28 pm Thread Starter
hdfan's Avatar
Ok Randy you have peaked my interest. What is the difference between the signal at the back of the bike and the signal from the front brake on the handlebar?
Questions, but not questioning. Thanks
hdfan is offline
post #5 of 7 Old Nov 23rd, 2006, 10:37 pm
Just ridin'
Randy's Avatar
Ok Randy you have peaked my interest. What is the difference between the signal at the back of the bike and the signal from the front break on the handlebar?
The VectraLights need +12v in order to trigger the brake LEDs. I mistakenly assumed the switch on the handlebar was on the ground side. It is on the +12v side of the relay so you could tap into the gray/yellow wire at the handlebar brake switch.
Randy Prade
Aurora, CO
Just ride it!
Meet Riley
Randy is offline
post #6 of 7 Old Nov 24th, 2006, 2:49 am
FWIW, I found "the correct wire" in the wire loom under the nose cone. I scraped a little insulation off, and soldered the wire from the AutoSwitch onto it. I preferred this location over going up under the handlebar trim and connecting there.
post #7 of 7 Old Nov 24th, 2006, 9:41 am Thread Starter
hdfan's Avatar
Thanks but it would be worth a lot more if I knew which one.
hdfan is offline
Wiring diagrams for 2002 K1200LT Tat_n_Telle K1200LT 10 Feb 24th, 2014 8:20 am
Motolights + Autoswitch install tiedend Lighting 6 Jul 7th, 2009 10:30 am
Turn signals dont cancel Empath K1200LT 20 Oct 4th, 2006 1:21 pm
wiring harness festus K1200LT 5 Jul 16th, 2006 9:19 pm
Wings Of Gold (turn signal saftey question) Jimbo3 K1200LT 1 Jan 16th, 2006 9:45 am
