No Starter - BMW Luxury Touring Community
post #1 of 8 Old May 29th, 2017, 10:40 pm Thread Starter
No Starter
Hi, all!! I received such good advice on this forum recently, solved my problem!! It was appreciated. I now have another: 2000 LT, press starter switch, no start. My earlier problem was the starter relay. Per advice on this forum, I installed the factory upgrade and all was well. However, for about the last year, I have noticed that I have had to push the starter switch harder and harder in order to turn the starter over. Today, it finally failed to make contact. Can I take apart the switch assembly and replace the switch, or do I have to replace the entire assembly which includes the kill switch, right turn signal, and turn signal cancel switch? All help will be appreciated.
Jerry
BMWMOA # 134919
2000 LT Hannigan Trike
1986 Suzuki TM400 (gone)
1957 BSA 500 cc Twin (long gone)
1955 BSA Golden Flash (longer gone)
1950 or thereabouts HD 165 cc 2 stroke! (gone in 1954)
scubajgp is offline
post #2 of 8 Old May 29th, 2017, 11:50 pm
bmwcoolk1200's Avatar
Re: No Starter
The multi function switch assembly can be taken apart and if you could source the water proof push button switch, it could be replaced or you can tap into the wires and add another switch somewhere else. I bought a switch assembly on Ebay for $50 and it had a broken kill switch tab on top. I pulled it all apart and swapped my good housing for the broken one as I burned out my kill switch with a short and it all works.
There are several on there now from about $45 on up so once you verify it actually is the switch, I would go ahead and order one and just replace the unit. If you pull the right side panel and open the electrics box, you can test with a meter on pins 3 and 5 of the plug on the connector block. That might be easier than disassembling the switch as the switch is not serviceable. The wires are are black W/Yellow and Green W/Yellow. It is a black 10 pin plug with a blue plug daisy chained with a single heavy wire.
Good luck with the repair.
Gordon
Sugar Hill, GA
bmwcoolk1200 is offline
post #3 of 8 Old May 30th, 2017, 1:59 am Thread Starter
Re: No Starter
Copy that, thanks much for that reply. I will take a look at ebay tomorrow. I appreciate your help!
scubajgp is offline
post #4 of 8 Old May 30th, 2017, 11:57 am
Re: No Starter
Good luck. There was one that was low priced but looked different in the kill switch area so make sure the one you get is right for your bike. I didn't pay too much attention as I just did a general search to see if they were readily available and they are.
Gordon
Sugar Hill, GA
post #5 of 8 Old May 30th, 2017, 10:14 pm Thread Starter
Re: No Starter
Yes, I have that inquiry in process! Thanks!
Jerry
BMWMOA # 134919
scubajgp is offline
post #6 of 8 Old May 31st, 2017, 6:00 am
Re: No Starter
You have checked your fuses?
I have taken apart and cleaned the contacts in my hand switches, put back and all has been good.
Another time I broke off the green mushroom on the starter button. (putting gauntlets on or off I don't remember) All I have for start button is the shaft. It has worked for years, I just got a replacement at a swap meet, yet to install.
This was on my 85 k100rs but the start button looks the same.
If you do go in to try to service the switches, know they are considered "NON SERVICEABLE" that said, be careful not to loose anything. There are very small springs in there, not replaceable.
I have a friend that just started cleaning his switch and lost a spring taking it apart. Work in a clean confined space to contain small parts.
I would try before I bought one, what, ya gonna do brake it?
red85k100rs is offline
post #7 of 8 Old Jun 1st, 2017, 12:48 am
LTExfisher's Avatar
Have you checked the ground for the stater? I had the same symptom and the bolt on the ground strap was way loose. Hard to reach but much easier.
LTExfisher is offline
post #8 of 8 Old Jun 1st, 2017, 11:49 am
Re: No Starter
That is always a good thing to check with starter or odd electrical issues Sam. If however, simply pressing harder on the start button gets it going with no other action, I would not suspect that as the cause in this instance unless we are getting inaccurate information on how it is acting. I too had that pesky screw fall out and it caused all sorts of electrical oddities till jzeller pointed me to it.
Never hurts to check out the possibilities.
You can see it with a bright light looking down in front of the battery slightly to the left. It is circled in red in the attached picture. This is the ground point for the load shed relay and is a known issue of coming lose and causing issues. I had to cut down an allen wrench to get it in-between the frame and onto the bolt itself. Give it a look see just to be sure.
Name:	Bolts for starter1.jpg
Gordon
Sugar Hill, GA
Starter Runs!! scubajgp K1200LT 4 Jan 16th, 2017 8:38 am
starter issues ggurnard K1200LT 7 Apr 14th, 2015 10:07 pm
Fried Starter Relay and Dead Battery btcarver K1200LT 6 Jan 11th, 2011 1:50 pm
Need help! Starter solenoid is stuck on 2000 K1200LT....Any suggestions? wildwestrider K1200LT 3 Jun 6th, 2009 4:12 pm
Starter Sprag Clutch TimVipond K1200LT 3 Nov 17th, 2005 3:33 pm
