Sudden Shut Off - BMW Luxury Touring Community
post #1 of 19 Old Nov 21st, 2006, 9:48 pm Thread Starter
Sudden Shut Off
My LT did something it has never done before: Shortly after leaving the office today it died. I was riding about 35 mph on a city street and it happened precisely when I pulled the clutch lever to shift. The ignition was still turned on, lights on, dash lights on, etc., the engine just quit -- no sputtering or anything. I hit the start button and it fired right up with no further symptoms for the rest of the trip home.
Info: '05 LT, 24,600 miles, 24k service done just last Friday.
Any ideas what could have caused this, and should I be concerned about it happening again? Could the tech have done anything at the 24k service to cause it? It has to go back in the shop anyway so maybe they should be looking at it...
post #2 of 19 Old Nov 21st, 2006, 9:56 pm
Senior Member (ret.)
RaffyK's Avatar
I have had that happen about 4 times early in the morning when I pulled the clutch in preparing to stop. Always in the morning and always on cold days and within two blocks from the house.
Raffy
RaffyK is offline
post #3 of 19 Old Nov 21st, 2006, 10:00 pm Thread Starter
Interesting. It was 22 when I left for work; no issues. It was 42 when I left the office today, and that's when it happened.
Did you ever determine what caused yours to do it?
post #4 of 19 Old Nov 21st, 2006, 10:27 pm
kdog's Avatar
Ditto to what Raffy said. Happened maybe 5 times in 100K miles. So it's just one of those things.
If I'm still moving, I just bump start by letting out the clutch in the next gear, and it starts right up.
Regards,
-joel
kdog is offline
post #5 of 19 Old Nov 21st, 2006, 10:45 pm
happened 2 times in 17k miles.. both whencold.. There was a recall on the fuelpump relay... and I think it coud be part of the "intermittent/occassional" stoppage. Otherwise, it could be a slightly loose power connector for the fuel pump.
J.M.J...
Dcn Channing
post #6 of 19 Old Nov 21st, 2006, 11:17 pm
RaffyK's Avatar
Nope never new why. Just figured it was cold weather related.
Raffy
RaffyK is offline
post #7 of 19 Old Nov 21st, 2006, 11:23 pm
Gino's Avatar
Also happened a few times to me with enough consistency that I brought it in.
Service technician said it had something to do with the idle speed when the throttle is off (rotated forward).
Not sure if that was the exact cause, but it's never done it since it was "serviced."
Gino
Modesto, CA
'02 Silver
For they passed a noble law,
Gino is offline
post #8 of 19 Old Nov 22nd, 2006, 1:07 am
Never has happened to me, but my brother has had this happen with his LT a handful of times. Exactly as you've described.
post #9 of 19 Old Nov 22nd, 2006, 5:08 am
Ekim's Avatar
Me too
It has happened to me a couple of times in the morning when the bike is cold. Usually at the first or second stop sign from my house. Now when pulling up to the stop signs I give a few quick gooses of the throttle while the clutch is in which seems to work.
I have also noticed now that it is colder (in the 30's-40's here) the big beast is slow to turn over and a few times has started, run rough and then died right away. Hit the starter again she fired right back up and idled fine. Is this just another "one of those things"?
-Ekim
2005 K1200LT (R.I.P.)
Manchester, MD
Ekim is offline
post #10 of 19 Old Nov 22nd, 2006, 7:02 am
It hasn't happened to me on my 99LT. I have had it happen on a couple of cars. Both times it happened once and then never a problem. It does make one wonder though.
ATFLT is offline
post #11 of 19 Old Nov 22nd, 2006, 7:09 am
I have had it occur a couple of times in the past two years. Same type of conditions. One of life's little mysteries perhaps?
rixchard is offline
post #12 of 19 Old Nov 22nd, 2006, 7:47 am
Throttle Technique
Howard,
Now you know why Harley riders blip the throttle all the time... If they don't then their engines die!
I have had this happen a few times as well. When it is cold out and until the engine temp is up I just never chop the throttle completely. Besides you just can't hear it when we blip out throttles.
post #13 of 19 Old Nov 22nd, 2006, 7:54 am
How about RF
Maybe something messing with the electronics like high RF. Better put some aluminum foil in your pants. Several years ago when they first installed the NEXRAD radar in Amarillo the thing would sweep through the control tower on a maintenance run and everything, including shielded, would go crazy. They moved the tower but not before I took those guys some bags of Jiffy Pop to hang around their necks as radiation badges.
TandemCyclist is offline
post #14 of 19 Old Nov 22nd, 2006, 12:45 pm
My '02 died like that a couple of times when it was new. Pull up between cars to the front of the line, pull in the clutch and the bike dies, just as the light turns green. That's usually when the bike was cold, but at least it's never been 22 degrees here.
Of course, the dealer said it was normal. I later figured out that it was just the Motronic learning the idle position. These bikes don't have a hard idle set screw like the old carburetors, so it takes some time to figure out what the proper fuel flow is for a stable idle.
I've had similar issues just after unplugging the battery. Rotating the throttle full open and full closed twice helps set the throttle position limits, but the bike still needs to map fuel flow versus rpm. It's just most sensitive at idle speeds, so if it dips too low then the bike can die.
So once again, the answer is to Just Ride It.
post #15 of 19 Old Nov 23rd, 2006, 8:16 am
ibbones's Avatar
About the same here. I have an 02 and the first stop sign is five houses away. She is idling about 1200-1300rpm. I turn and go about 3/4 mile and the next stop sign I have learned to keep the throttle open just a bit. She will drop down to 400-500 rpm. It ONLY happens when the bike is cold. Sometimes in the summer the outside temp will be a bone crushing 75* in the early morning but it acts the same.
"BONES" <///><
2018 R1200RT
2002 K1200LTC--- Belle
ibbones is offline
post #16 of 19 Old Nov 23rd, 2006, 5:38 pm
Guest
2191's Avatar
Red face
I had it happen 1 time, it died as I was pulling out from a stop sign and turning left. Yea, I dropped it.
Picked it up, started NO problem except for my red Face.
It was 27 degrees that morning, I now keep the RPM up when it is cold.
2191 is offline
post #17 of 19 Old Nov 24th, 2006, 3:01 am
harrowbmw's Avatar
Greetings all.
This precise problem is still happening to my '83 K100. When she shuts down it's quick like an electrical problem. All the dash tell tale lights light up, I hit the starter and away she goes. Go figure that one. I'm currently thinking maybe a fuel injection relay fault.
Kindest regards to all.
Paul Harrington
Australia
[email protected]
1999 K1200LT Champagne "Bismarck"
1983 base K100 "Bavarian Belle"
harrowbmw is offline
post #18 of 19 Old Nov 24th, 2006, 9:02 am
Sounds like one of these little guys at work. (No, not Buggs Bunny)
CajunBass is offline
post #19 of 19 Old Dec 10th, 2006, 5:52 pm
rkirker's Avatar
Check out recall Maybe ?
Howard:
Check out the recalls on the technical pages.
Think it related to the 05s
"ON CERTAIN MOTORCYCLES, AT LOWER TEMPERATURES, WIRING WITHIN THE ANTI-THEFT CONTROL UNIT MAY PRESS AGAINST THE FUEL PUMP RELAY. THE FUEL PUMP RELAY CONTACTS COULD OPEN, INTERRUPTING THE FUEL SUPPLY TO THE ENGINE, RESULTING IN STALLING."
Rich Kirker
2002 LTC Pacific Blue
Caliper Moto Lights, Hyper light brake lights, Spiegler brake lines, Ride West side markers, Grip puppies, HyperPro Springs and CA HID Kit.
BMWMOA #124306
2009 Honda Shadow (Wife's)
Blue & Pearl
"Well It’s not rocket science but absolutely a nightmare. At the end of the day you had a fairly unique situation that I personally at this moment in time could see me having as well 24/7. With all due respect, it shouldn’t of happened."
rkirker is offline
If you're Dumb, Shut off the bike NascaLT K1200LT 37 Apr 29th, 2012 12:13 pm
brakes with bike shut off lenny K1200LT 7 May 24th, 2006 10:48 pm
Starter Will Not Shut OFF DaveSwanson K1200LT 4 May 1st, 2006 1:04 pm
Sudden Electrical Starting Problem ecirwin K1200LT 3 Apr 12th, 2006 9:07 am
Shut Down! Daman858 Chit Chat 2 Dec 8th, 2005 9:33 pm
