2006 lt stereo aux input - BMW Luxury Touring Community
post #1 of 4 Old Apr 29th, 2017, 2:09 pm Thread Starter
Tricky_dickey's Avatar
sorry to ask such a silly question - before i go buy all the little farkles to hook it up
wanted to know if i could hook up my ipod to the aux input and and would play through the stereo system
want to remove the stacker. I have the remote system but seems like such a pain to operate it
would be easier and much simpler to hook my ipod up and operate it from the stingray
thanks in advance
Tricky
Tricky_dickey is offline
post #2 of 4 Old May 3rd, 2017, 7:18 pm
Miles of Smiles
Hilton's Avatar
Re: 2006 lt stereo aux input
Morning. Assuming your bike was supplied with the 6 CD stacker, (i.e. factory fitted wiring) the VOICE II control unit in the stingray has an AUX input.
Connect the iPod to that with a 3.5mm aux cable and you should be good to go. IIRC you will have volume control but not much else.
HOWEVER...
A better solution is to use a DICE (or similar) interface.
Replace the stacker with that (was plug and play) and you free up the space in the saddlebag, plus it allows you to view and select tracks etc from the iPod.
Little tricky to set up but works.
Thought you'd like that.
Jenna: Ocean Blue '06
Rena: The Committee.
ET4 Thing 1
ET4 Thing 2
Hilton is offline
post #3 of 4 Old May 3rd, 2017, 8:38 pm Thread Starter
thanks very much
i did buy one of those and was hesitating installing as every time your turn off then you have to open the bag and turn the Ipod on from what i understand
will try the 3.5 to 3.5 i have a remote control and can hang that off a ram ball
thanks again
post #4 of 4 Old May 5th, 2017, 1:17 am
If you leave the DICE powered up so you get memory retention and on-screen feedback and (some) remote control, it'll flatten your battery within a few days.
I only run it on longer trips (music from Ipod through DICE) when out of radio reception, and it's on a switched source. Quite a few OLD threads on it...
Making Custom Cable For Dice sreid iPod/MP3 29 Apr 19th, 2010 10:36 pm
Help, connect to Aux input but no sound. fh8932 K1200LT 18 Apr 3rd, 2010 10:04 am
Select AUX input??? kflanigan Satellite Radio 3 Jun 20th, 2007 5:53 pm
Radio Aux input. Where is it??? kmcg K1200LT 9 May 5th, 2007 7:23 pm
colors of wires and plan for the AUX input ? tforand iPod/MP3 1 Jun 21st, 2006 9:57 pm
