2005 low beam failure - BMW Luxury Touring Community
post #1 of 2 Old Apr 5th, 2017, 9:18 am Thread Starter
Recently the low beam HID failed on my 2005LT. The igniter had failed when bench tested. The replacement unit did not start when installed. Turns out there is no power to the low beam circuit (green w/ blue tracer) as the left and right side markers do not light either. I have power thru the #5 fuse and the tail light is on.
High beam works fine and drops out when starting. Strangely the tail light does not go out when cranking.
Any ideas on where to start looking?
Thinking that I may have to pull the tank and have a look in the wiring box.
Chuck Swenson,
Sioux City, IA
2010 R1200RT Low with ESA2!
2005 LT
iowalt is offline
post #2 of 2 Old Apr 5th, 2017, 8:52 pm
Re: 2005 low beam failure
I'm stuck as the load shed relay feeds F5 (low beam and tail) as well as F6 (high beam). I would at least follow the wire back from the after market ballast and check where is goes from the original bulb connector to the feed through connector on the headlight assembly. From there it goes to some tie point somewhere. The tail lights should be going out so I suspect that the failed ballast may have drawn excessive current and melted wires together.
R1200RT 2010 Brake Failure buiduc_hung RT Series 17 Mar 9th, 2013 1:51 pm
HID high beam failure? BMWWANDRR K1200LT 2 Feb 2nd, 2012 9:59 pm
2005 LT low beam HID?? bowdon K1200LT 5 Jan 31st, 2009 9:29 am
HI LO HID Installation on 99 K1200LT With Pics ! JPSpen Lighting 37 Jul 13th, 2008 12:44 am
Negative experience with high-wattage low beam paulcbrowne Lighting 4 Nov 15th, 2005 3:01 pm
