Quick Scan Mirrors? - BMW Luxury Touring Community
post #1 of 7 Old Nov 17th, 2006, 9:30 am Thread Starter
Quick Scan Mirrors?
For several years when touring two up I have been using additional bags from HelenTwoWheels that strap on the side of next to the top case and just above the side cases. Helen sells a special strap that goes under the top case and secures the bags very well. They work fine except the bags interfer with the view in the mirrors and I can not see behind the bike. I know some have suggested RS mirrors and I may try them. But has anyone used the Quick Scan mirrors from Saeng.com? They are the suggesting shield mounted version for the LT.
Dave Granzin
'00 K1200LT
'04 R1150GS
'93 Honda Nighthawk
dgg155 is offline
post #2 of 7 Old Nov 17th, 2006, 10:01 am
I have the quick scans. I would go with the RS mirrors if to do over again. The quick scans are pretty small and do vibrate quite a bit. I have mine mounted on the clear air deflectors. IMO, they're a good second choice and probably a little less $$.
Sunderland is offline
post #3 of 7 Old Nov 18th, 2006, 7:10 am
radar41's Avatar
Dave;
I too use the HTW bags and travel two up, go with the RS mirrors they word GREAT and there is no vibration to them. You will not regret it.
djw
Don Wreyford
BMWMOA, 91738
RA 27032
ABC 7915
00 LT, 84 RS, 98 GS, 76R75/6
"An Elephant is eaten one bite at a time"
radar41 is offline
post #4 of 7 Old Nov 18th, 2006, 9:03 am
Talking very pleased
i have the saeng mirrors mounted to the shield and have not noticed any vibration. The mounts that were great on the R1200CLC and were on the outside surface will not adjust for an outside mount on the LT. mounted on the inside of the LT OEM shield they are a little closer together then i would prefer, however they do the job great. They remove the blindspot and I am able to see the car passing me while it is still visible in the mirror. NO one can sneak up on me now. And coming back from CCR with extra bags mounted on the sides the Saeng mirrors helped. A winter project is the replacement of shield with a Ceebailey with wings that will separate the mirrors a little more.
Toby in New York
1983 R80RT Red (sold)
Lusting after K1600 GTL
tobiwan is offline
post #5 of 7 Old Nov 18th, 2006, 5:35 pm
BLBantz's Avatar
99 cent stick on mirrors from Wal-Mart stuck on the inside of the regular mirrors let me see everything in both lanes right up to the rear wheel of the LT.
Brian
Fanwood, NJ
2003 K1200LT Anthracite
BLBantz is offline
post #6 of 7 Old Nov 19th, 2006, 1:27 pm
RMW
RMW's Avatar
Dave,
I used the Saeng mirrors mounted on the clear wings for a while. Wedged a piece of clear rubber hose between the wing and dash to all but eliminate the vibration. They worked well for wider angle and some rear view but they are limited when you have to rely on them exclusively.
Go with the RS or other mirrors you will be much happier with the results.
Good luck.
Name:	Better Mirrors.jpg
ID:	8245   Click image for larger version
Name:	Best Mirrors.jpg
Ron Wilkerson
05 LT
07 KLR
09 GSA
RMW is offline
post #7 of 7 Old Nov 19th, 2006, 3:51 pm
These blindspot mirrors are intriguing to me. Sounds like they are the same shape of the OEM mirrors, just stuck on top. Has anyone tried these?
http://www.safetymirrorsonline.com/html/technology.htm
How to Remove After-Market Adhesive Mirrors? hschisler K1200LT 17 Sep 14th, 2016 3:19 pm
Muth mirrors report skurtenbach K1200LT 20 Oct 17th, 2013 9:40 am
Fuel Quick Disconnects - Were BMW Parts Redesigned? Toolman K1200LT 27 Feb 25th, 2011 9:55 pm
PIAAs Mounted on the Mirrors - One Option midwilshire Lighting 8 Nov 20th, 2006 11:27 pm
