Running Motolight harness advice needed - BMW Luxury Touring Community
post #1 of 9 Old Nov 16th, 2006, 3:00 pm Thread Starter
MickS's Avatar
I have a new harness from Motolight to use with motolights that were on a 99LT.
Search found several Auto switch installation threads for Motolights but I plan to use switch that I got with harness and would love to not have to remove tank on my 2000LT.
Just what tupperware needs to come off to run harness ends to front under light. Do you suggest left or right side run etc.
I saw one post about coat hanger fish from front but not sure that was for a harness or just wire run.
Any suggestions appreciated.
Mick
MickS is offline
post #2 of 9 Old Nov 16th, 2006, 3:22 pm
usmctpdog's Avatar
Smile
I used a wire loom that came with my Wally World 55watt Dual Halogens to a switch just above my headlight adjustment knob. I took off the R-Side tupperware and ran the wires back from the lights under the nose back to the battery connection. No need to take off Gas tank!
see here for Story & Pics:
http://www.bmwlt.com/forums/showthread.php?t=15821
Good luck!
2005 PearlBlue FJR1300 (Sold)
*Ridin steady since 1973
Religion began when the first scoundrel met the first fool. Voltaire.
usmctpdog is offline
post #3 of 9 Old Nov 16th, 2006, 4:42 pm
Senior Member (ret.)
RaffyK's Avatar
left side upper body panel only. That's how Motolight does most of their installations.
Raffy
RaffyK is offline
post #4 of 9 Old Nov 16th, 2006, 5:25 pm
gunny's Avatar
A suggestion:
Use a quick disconnect at some point during installation, will make it easier one day when you do end up pulling the tank or other work.
B D R
gunny is offline
post #5 of 9 Old Nov 16th, 2006, 5:27 pm
Hey Raffy,
no need to worry about the tank removal. There is plenty of cable with the harnesses sent by Motolight to get away from that. You may have to figure where you'd like to place the excess wires more. Wire ties will help. The left sisde is the prefered side to remove as you already know. Good luck. Should take about 1 hr.
canyonrider is offline
post #6 of 9 Old Nov 16th, 2006, 6:21 pm
bowlesj's Avatar
Mick
Mick,
You take off the right side plastic and expose the tank, raise the seat, sight down under the tank on the right side and you will see tunnel like area that you can route up to a 1/2 wire harness fairly easily.
This is best in my opinion for future tank removals. You can ty-rap everything down at a later date.
2004 - LT - Anthracite
bowlesj is offline
post #7 of 9 Old Nov 16th, 2006, 6:35 pm Thread Starter
MickS's Avatar
Thanks all for the harness advice.
Any suggestions on best switched power source to tap.
Mick
MickS is offline
post #8 of 9 Old Nov 16th, 2006, 9:12 pm
Power Source
I tapped into one of the running lites, then ran the power cord back to a 2nd fuse block I installed.
SeaMarshal is offline
post #9 of 9 Old Nov 17th, 2006, 1:24 am
bmwrubbercow's Avatar
Mick
The parking light is a very assessible switched power source for your switch.
Tom
2003 R1150RT, Black Beauty--this is one sexy bike!
1999 R1100GSA, Does everything well, what else can one say?
1992 K75SA, If this engine had been 4-valve instead of 2, it would be the smoothest BMW ever built!
1978 R100S, my first and favorite BMW.
1976 R75/6, A 30 year old gentlemen I still love to take out for a Sunday ride.
bmwrubbercow is offline
Advice Needed - Mounting a radio in saddlebag Tom_Becker K1200LT 9 May 30th, 2007 1:41 pm
Microphone Wiring Advice Needed ehaughn Intercom, CB, & 2-Way Radios 6 Aug 13th, 2006 4:17 pm
Advice Needed: Planning DFW to Yellowstone vstromboli Ride Tales 14 Apr 25th, 2006 11:13 pm
Battery Advice Needed BeemerBob Batteries, Chargers, & Electrical 8 Dec 27th, 2005 3:05 am
I am buying one,which one? Advice needed jbuffalo K1200LT 26 Nov 29th, 2005 6:19 pm
