Centerstand Broke - BMW Luxury Touring Community
post #1 of 13 Old Nov 16th, 2006, 9:03 am Thread Starter
tony's Avatar
Centerstand Broke
Howdy All:
I hope you are doing great.
My centerstand broke this morning. How does this happen? Has this happened to anyone else?
It looks like the bar between the two legs broke. but it was raining this morning and I have not had a chance to take a good look.
Any thoughts? Anyone know what a centerstand costs?
Best regards, tony
Northville, MI
tony is offline
post #2 of 13 Old Nov 16th, 2006, 9:15 am
Tony,
There have been several reports of centerstands breaking (including mine). The break on mine was on the right hand side of the cross piece and occurred just outside of the weld. It was replaced under warranty so I don't know how much it cost. Several people have mentioned trying to have theirs re-welded. I didn't try this because of the warranty and because I was concerned that it was caused by a break in the tubing and not in the weld. This is generally caused by a type of corrosion called weld decay.
ďRes ipsa loquitur, sed quid in infernos dicet?Ē
Alan Stuber
2003 K1200 LTC Titan Silver
Austin, Texas
astuber is offline
post #3 of 13 Old Nov 16th, 2006, 9:34 am
stringplay's Avatar
Tony,
Mine broke also. I had a friend weld it to what looked better than new, but it never was "straight" again & the bike never felt secure when it was up on the stand. He even took pains to try and make sure that it was aligned as much as possible when he welded it. I finally got a new one from the dealer here in town and had them install it. I don't know how much it was because my wife gave it to me as a birthday gift (installation & all!), but I'm sure it wasn't cheap. You might look at beemerboneyard.com to see if they might have a inexpensive used one. Also be prepared for some difficulty in removing the old one - don't ask me how I know that. Heat guns, oversize allen wrenches........ Good luck!
stringplay is offline
post #4 of 13 Old Nov 16th, 2006, 9:46 am
Bandit
Guest
Posts: n/a
mine has not broken but "feels" fragile. it flexes, sorta, like it was engineered for a smaller, lighter bike.
post #5 of 13 Old Nov 16th, 2006, 9:57 am
MattKas's Avatar
Mine has been recently broken as well. Just last night I replaced with another used one. (total cost $73.25) Two local dealers here did not want to claim warranty (My bike is 2002 model with 71K miles on) Currently, there is one used centerstand available on E-bay Item number: 200014971215 . He was ready to sell for $100 although listed for $125.
Good Luck,
Matt Kas
"Riding Year around"
MattKas is offline
post #6 of 13 Old Nov 16th, 2006, 11:49 am
Originally Posted by tony
Howdy All:
Hi, Tony! Hope you find an easy solution, and at minimum cost!!
Lissen, if you find a trusted welder, then that may work. Butt, if not, give Edgar Tanner < eatanner > a ping here and see if he has one stored down at my storage unit. BTW, I forget what model year your LT is.
Good luck, Tony.
post #7 of 13 Old Nov 16th, 2006, 12:48 pm
tsBMWminer's Avatar
Howdy All:
Tony
Mine broke and I popped me ankle while putting it up
I had my maintenance mechanic weld it for me 2 years ago. If you get it welded MAKE SURE IT IS STRAIGHT.
Tim In Portland
2000 Lt Icon
"Ike"
tsBMWminer is offline
post #8 of 13 Old Nov 16th, 2006, 1:05 pm
OKUIII's Avatar
Angry
Yep, mine broke and when it fell over in the garage it took out the windscreen, windscreed adjuster, GPS, back right speaker arm reat and gpe sun screen. Approximately 875.00 all together including a free centerstand.
OKU
O. K. Upchurch III
Irvine, California
2016 R1200gs
2000 K1200LT (Best Bike #1)
1997 R1100RT (Best Bike #2)
1995 K1100LT
1990 K75RT
OKUIII is offline
post #9 of 13 Old Nov 16th, 2006, 8:19 pm
Had one go on an RT with 32,000 miles. Rust under the step portion that is welded on the down bar. Bike hits the ground quickly. Now I spray silicon in this junction to stop rust, this point does not allow you to check for a rusting and failing stand.
cf-transplant is offline
post #10 of 13 Old Nov 17th, 2006, 9:07 am
My 2000 broke at the crossover weld in the summer. Had it welded. Works great.
Jim_Schuyler is offline
post #11 of 13 Old Nov 20th, 2006, 9:43 am Thread Starter
tony's Avatar
Howdy Again All:
I hope you are great.
I guess I just thought that was something that would not break.
So how hard is it to remove???
Do I need a heat gun? would a blow dryer work?
What about Spring tensioner, BMW No. 46 5 710 like it says in the book? Could I use pennies?
Any wisdom would be appreciated, I would like to get it off today so I can ride to work tomorrow.
Best regards, tony
Northville, MI
tony is offline
post #12 of 13 Old Nov 20th, 2006, 10:12 am
The hardest part is removing the springs. Many people suggest putting pennies in between the coils of the spring, this needs to be done with the spring extended, kind of hard to do if the center stand is broken. There is an internal snap ring on the left hand side that needs to be removed to get the center stand off. The first time I managed to remove the spring with a screw driver and a pair of vise grips.
Alan Stuber
Austin, Texas
astuber is offline
post #13 of 13 Old Nov 20th, 2006, 10:56 am
Good luck, Tony.
Hey, Tony - hope your git 'er done today. BTW, I checked with Edgar and he had already sold his centerstand sometime ago. Sorry about that dead end chase. I guess you've already looked at Beemerboneyard or Chicago BMW for a replacement. I'm not sure Deep6Auctions is still selling K1200LT parts, butt they do have a storefront on eBay. Good luck, Tony.
