Brass Fuel Quick Disconnect - BMW Luxury Touring Community
post #1 of 12 Old Nov 15th, 2006, 7:06 am Thread Starter
bigbear's Avatar
Just an FYI for anyone wanting to install the brass QD's from MSC Direct. They currently show being on backorder with availabilty of 12/24/06.
reference Item #88080486 (2 each).
#88080445 (2 each) still show being in stock
Roy
Roy Gregersen
85 K100RT sold
02 LTC DOA 9/21/14
12 R1200RT
bigbear is offline
post #2 of 12 Old Nov 15th, 2006, 2:10 pm
grifscoots's Avatar
Call them, they have an alternative.
-=grif=-
Grok
grifscoots is offline
post #3 of 12 Old Nov 15th, 2006, 3:03 pm Thread Starter
bigbear's Avatar
Grif
According to there discription on the website the alternative does NOT have the check valve in it. With out this check gas would leak out when disconnected.
I did not call them but can if there is a substitute that has the check.
Roy Gregersen
85 K100RT sold
02 LTC DOA 9/21/14
12 R1200RT
bigbear is offline
post #4 of 12 Old Nov 15th, 2006, 3:21 pm
murray's Avatar
Backorders Shipped
I ordered 3pair 1 month ago ,at that time they were on bo. I received email yesterday my order was shipped.
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #5 of 12 Old Nov 15th, 2006, 3:25 pm
DanMartin's Avatar
Roy
I used the Acetyl ones available at McMaster-Carr at $13.68 per pair. They are rated for gasoline. Items 5012K712 and 5012K672
Dan Martin
DanMartin is offline
post #6 of 12 Old Nov 15th, 2006, 4:52 pm
Dan Martin
That is what people are trying to replace! The plastic ones are occasionally cracking, causing fuel leaks. Even worse, if the end breaks off, a massive leak ensues.
post #7 of 12 Old Nov 15th, 2006, 5:26 pm
zippy_gg's Avatar
Thumbs up
Or you can oder from http://www1.mscdirect.com :
2 x 88080445 @$24.81 ea
2 x 88080486 @$15.30 ea
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #8 of 12 Old Nov 15th, 2006, 5:40 pm
Did you not read the first post in this thread??
post #9 of 12 Old Nov 15th, 2006, 5:59 pm
zippy_gg's Avatar
Oops!
Oops! I didn't realize these were the same part numbers, as Bigbear was referencing brass units while these are stainless steel. But hey... I got pics!
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #10 of 12 Old Nov 15th, 2006, 7:47 pm
They are chrome plated brass, not stainless steel.
I searched the manfacturer's web site (Colder Products), and they have stainless in some products, but not these particular items.
I also tried to find another distributor, no luck. McMaster Carr has some sizes in plated brass, but not the 5/16" tube ID that is needed here.
The Colder Products part numbers are:
Male - LCD22005
Female - LCD17005
post #11 of 12 Old Nov 15th, 2006, 8:48 pm
DanMartin's Avatar
The ones they are replacing are black plastic that is not rated for gasoline. These are. If I wasn't such a tightwad I probably would use brass too.
dan
post #12 of 12 Old Nov 15th, 2006, 9:38 pm
dan
CPC makes the fittings, and the black ones are most likely the same acetal material, just colored differently, maybe at the request of BMW?
Here is the CPC catalog, you will notice there are no black fittings in the type/size needed. http://www.colder.com/Downloads/IndCat_REV_FINAL.pdf
I know BMW has made some mistakes, but using a material for these not rated for gasoline is not one they are likely to make.
The fittings are cracking/breaking at the neck of the barbed portion, probably due to the strain the hoses put on them since they are pretty well jammed in place, along with the heat and vibration. They are not failing due to chemical attack. Some have suffered "O" ring failures, but we learned a long time ago that it is very cheap to have several "O" rings on hand, and change them when doing service.
By far the best approach is to use the chrome plated brass fittings, but they are not as readily available, and cost considerably more.
Fuel Quick Disconnects - Were BMW Parts Redesigned? Toolman K1200LT 27 Feb 25th, 2011 9:55 pm
Male quick disconnect fuel line fitting mjac K1200LT 4 Jun 15th, 2010 2:20 pm
Question on fuel line Quick Disconnects Tat_n_Telle K1200LT 7 Dec 4th, 2006 1:19 pm
Metal fuel quick disconnects RaffyK K1200LT 6 May 1st, 2006 7:32 pm
