Sintered clutch plate - BMW Luxury Touring Community
post #1 of 5 Old Nov 13th, 2006, 1:37 pm Thread Starter
bikesnumbnuts's Avatar
If a sintered clutch plate was to be available for the LT as it is for the boxer twins range , would this material absorb oil and brake fluid .
I ask this question because these clutch plates don, t wear out and they are supposed to be a lot stronger than the original plate .
Just imagine no more clutch problems with leaking fluids.
regards bikenumbnuts
04 your 05 in graphite
in blighty
bikesnumbnuts is offline
post #2 of 5 Old Nov 13th, 2006, 2:01 pm
in blighty
Sintered metal friction materials, brake shoes, clutch pucks, etc. are "porous", and would still tend to "soak up" and then release any fluids that get on them, so would still cause a clutch slippage problem if brake fluid/oil get on them.
post #3 of 5 Old Nov 14th, 2006, 1:42 pm Thread Starter
would ceramic absorb.?
regards bikenumbnuts.
04 your 05 updated in graphite
in blighty
post #4 of 5 Old Nov 14th, 2006, 2:28 pm
in blighty
I don't know much about ceramic pads, but I think they may be organic base with ceramic particles in it, similar to how semi metallic brake pads are made. If they are fully sintered ceramic, they MAY be homogenous enough to avoid fluid penetration. However, there are ceramics that are also porous in nature, depending on what is desired of the product.
Hopefully someone with technical knowledge of ceramic brake pads will comment.
post #5 of 5 Old Nov 14th, 2006, 2:32 pm
Just found this on a web site:
Since they were first used on a few original equipment applications in 1985, friction materials that contain ceramic formulations have become recognized for their desirable blend of traits. These pads use ceramic compounds and copper fibers in place of the semi-metallic pad's steel fibers. This allows the ceramic pads to handle high brake temperatures with less heat fade, provide faster recovery after the stop, and generate less dust and wear on both the pads and rotors. And from a comfort standpoint, ceramic compounds provide much quieter braking because the ceramic compound helps dampen noise by generating a frequency beyond the human hearing range.
Based on that, I would think that ceramic friction pads will suffer the same problems as anything else if brake fluid gets on them.
I also know that people who have tried ceramic brake pads on the rear of the LT eventually had the same squealing problems as before, so that is not a "fix" for the noise either.
Clutch Replaced. And Now, Page 2... hschisler K1200LT 23 Feb 27th, 2007 6:22 am
No Clutch! birdman K1200LT 8 Sep 6th, 2006 11:36 am
Cracked Footrest Plate when bike dropped RealWing K1200LT 6 Aug 21st, 2006 6:11 am
lost my clutch parishollow K1200LT 11 Jun 6th, 2006 7:45 am
