Hi guys I have a problem with clutch - BMW Luxury Touring Community
post #1 of 2 Old Nov 11th, 2006, 5:44 am Thread Starter
dave4462's Avatar
My bike has only 22000 ks on it. I got is second hand of a guy who owned it for four years, so it has sat for some extended times, and the clutch is slipping. It went fine for the first 7000ks since I have owned it but now I am sad, so I wont sell my Aprilia yet.
-no loss of clutch fluid from master cyl.
-no oil in ground under the bike.
-the leaver seems kind of slow to return some times after pulling it in and then releasing it.
-it also seems a bit slack/spongy when pulled in.
have I got a slave that has allowed air in?
have i got a broken/split pressure plate?
a colapsed thrust bearing?
will it fix with just a blead up?
Is the slave just gundged up from sitting?
any sugestions? or am i just going to have to pull the friggin thing to pieces to find out?
dave4462 is offline
post #2 of 2 Old Nov 11th, 2006, 8:51 am
Well, the symptoms are strange, have not heard of those before.
Bleeding the system certainly won't hurt, and MAY do something, so since that is the easiest thing you can go, go ahead and try it.
I would be really surprised if the pressure plate spring has failed, and if so you would have clutch slipping.
My first GUESS would be that somehow one of the pistons, either in the master or slave has either galled or the piston seal edge has rolled, causing sticking. I had a slave piston that spun in the cylinder when the little throwout bearing siezed, but the symptom was rapid failure of the seal, then fluid loss and clutch contamination.
In any case, if you do have a failure of some kind in the slave cylinder, if not fixed quickly you will end up having to replace the clutch, so If it was me I would likely be pulling the slave to check it.
We (I) fell over - clutch problem bowlesj K1200LT 10 Sep 4th, 2006 9:31 pm
K1200lt Clutch Problem ACKERS K1200LT 7 May 22nd, 2006 1:11 am
Starter Sprag Clutch TimVipond K1200LT 3 Nov 17th, 2005 2:33 pm
New LT w/a Clutch Problem hschisler K1200LT 14 Oct 20th, 2005 7:27 am
