Fitting a pre-'05 seat on an '06 - BMW Luxury Touring Community
post #1 of 13 Old Nov 10th, 2006, 10:37 pm Thread Starter
mneblett's Avatar
Had a spare pre-'05 seat, so I decided to try to see if I could fit it up.
Basically, found the interference spots, then trimmed them away -- three on each side, as shown in the pics. One spot forward that needs to be trimmed to fit inside the inside edge of fairing side panel, one spot middle that also needs to fit inside the fairing panel, and a tab at the rear that needs to be wacked off.
Another option to consider!
'05 seat rear tab (about same height as cross bar)
Pre-'05 seat rear tab
Pre-'05 seat side before trimming
Side portions trimmed 1
Side portions trimmed 2
Rear tab trimmed off
Panel clearance after trimming
Finished installation
Mark Neblett
Fairfax, VA
mneblett is offline
post #2 of 13 Old Nov 11th, 2006, 2:11 am
Mark, do those same sections hit if the earlier seat is set in the high position?
post #3 of 13 Old Nov 11th, 2006, 4:47 am
grifscoots's Avatar
Did you throw a leetle ackumpucky in there to seal the seat up?
-=grif=-
Grok
grifscoots is offline
post #4 of 13 Old Nov 11th, 2006, 9:45 am
Florian's Avatar
Grif, what is ackumpucky>?
F
Florian is offline
post #5 of 13 Old Nov 11th, 2006, 9:51 am Thread Starter
mneblett's Avatar
I just checked -- the rear and middle sections do not hit, but the front parts still need ~3/8" of clearance trimming.
I personally don't care for the look with the underseat gap when in the high position, so essentially what I've ended up with is the old low seat option.
I'll get my first "test" for comfort later this morning when I ride out to my mom's house. I'll post the results later.
Mark Neblett
Fairfax, VA
mneblett is offline
post #6 of 13 Old Nov 11th, 2006, 10:04 am Thread Starter
mneblett's Avatar
I will, both for sealing and to make the white foam less visible. In the short term, I'm not terrible concerned, as that portion of the seat is already open (drain holes already there at/near the cuts).
Mark Neblett
Fairfax, VA
mneblett is offline
post #7 of 13 Old Nov 11th, 2006, 5:33 pm
grifscoots's Avatar
F
A generic term for silicone, wood filler, bondo, etc.
-=grif=-
Grok
post #8 of 13 Old Nov 11th, 2006, 7:55 pm
McRuss's Avatar
I just slapped the pre-'05 seat on the '05 bike, put'er in the high postion and rode it 30,000 miles. Yeah, there's a gap but I cant see it when I'm on the bike and I'm a rider, not a poser so I dont really care. The '05 - '06 seats are a POS in my NSHO.
Just old, clutchless and clueless
Russ Locke
Lakehills, Texas
McRuss is offline
post #9 of 13 Old Nov 11th, 2006, 8:05 pm Thread Starter
mneblett's Avatar
Guess that makes me a poser, as the folks here will no doubt confirm
To each their own -- I don't like the look, so I went to the effort to drop it.
Mark Neblett
Fairfax, VA
mneblett is offline
post #10 of 13 Old Nov 12th, 2006, 10:32 am
Florian's Avatar
I just had to know, thanks Grif!
F
Florian is offline
post #11 of 13 Old Nov 12th, 2006, 11:11 am
Beemerider's Avatar
"don't like pre-'05 seat pans on mah rahd" mneblett
I'm with ya' there...
Ride On!
Goodyear, AZ
"Yeah but its a warm heat!"
'13 SILVA K1600GTL
Beemerider is offline
post #12 of 13 Old Nov 14th, 2006, 3:56 pm
McRuss's Avatar
And I dont like the low seat position. It's all about comfort for me, that's why I swapped them to begin with. I'm considering sending the stock seat to Rick M. to see if he can work with it. Then I'll have the looks AND the comfort.
Russ Locke
Lakehills, Texas
McRuss is offline
post #13 of 13 Old Nov 18th, 2006, 8:55 pm
bruce2000ltc's Avatar
Hi Mark,
I picked up a pre '05 seat today and did the same trimming to the front and middle of the seat you did. I test fitted the seat and it seems to fit perfectly without trimming the rear tabs. Did you remove the rear taps to get the seat lower; am I missing something; or will it work fine the way I did it? I'd like to retain option to use the higher seat position occasionally if I can.
Bruce Hodges
Last edited by bruce2000ltc; Nov 18th, 2006 at 8:59 pm. Reason: spelling correction
bruce2000ltc is offline
Older seat on ?05 bike pozo_izquierdo K1200LT 7 Apr 13th, 2011 11:07 pm
Sore butt, need to replace stock seat, advice please joesb Ergonomics & Rider Comfort 45 Jul 11th, 2008 6:54 am
Soft Touch Seat Questions Crestwood330 Ergonomics & Rider Comfort 22 Apr 30th, 2006 9:27 am
Ariís winter farkle projects part 4 (power seat height adjuster) pozo_izquierdo K1200LT 21 Apr 7th, 2006 11:45 am
