Rear Brake Disc (Rotor) Wear - BMW Luxury Touring Community
post #1 of 4 Old Nov 8th, 2006, 6:54 am Thread Starter
I recent road home from London and on way the rear brake started to make a different noise, on inspection I noticed the right side face of the disc (rotor) was slightly marked due to contact from the metal back plae of the pad.
Can anybody tell how bad the damage must be before the disc (rotor) must be replaced. If I go to a UK dealer they will most certainly replace the disc.
The disc (rotor) thickness is still well within the required limits.
I have a new set of rear pads and can fit these myself.
Any help would be much appreciated.
Thank you
alanprorib is offline
post #2 of 4 Old Nov 8th, 2006, 7:57 am
zaphod's Avatar
I would suggest that if you're having any rear brake problems, replace them with ECB pads and a new rotor. It's a fraction of the cost of OEM and they work a lot better. The procedure as easy. There were a few write ups, just search for ECB.
Malcolm McGee
Little Rock, AR
'00 K1200LTC Canyon Red
'09 Kawasaki KLR 650
'96 Bunkhouse
IBA #24557
BMWMOA #117769
zaphod is offline
post #3 of 4 Old Nov 8th, 2006, 12:21 pm
You mean EBC pads & rotor. Check this thread for details and where to order.
As for the original question, it depends. Are there noticeable grooves worn into the old rotor? If so, then it should be replaced. If you're on a tight budget, you could put new pads on and check them often to see how they are wearing, but personally I never skimp on safety items like brakes or tires. My life is worth more than a few $$ saved.
post #4 of 4 Old Nov 8th, 2006, 3:06 pm
zaphod's Avatar
It was early, not enough tea, fat fingers, dyslexic, and anything else you can think of.
...never skimp on safety items like brakes or tires
Neither do I. With the rotors marked and the improvement the EBC provides, why do it half way?
Malcolm McGee
Little Rock, AR
'96 Bunkhouse
IBA #24557
BMWMOA #117769
zaphod is offline
Rear brake light not working wjg4 K1200LT 1 Jul 31st, 2006 9:26 pm
Rear Disc Problem Petre K1200LT 7 May 18th, 2006 11:16 pm
BMW Service Bulletin for Rear Brake Squeal Serebigal K1200LT 4 Apr 8th, 2006 9:40 am
Drilled rear brake rotor???? DRothermel K1200LT 10 Apr 7th, 2006 1:01 pm
Rear brake squeal linked to front brakes? Vince_nj1 K1200LT 19 Apr 2nd, 2006 10:37 am
