Oddiments box lock will not release - BMW Luxury Touring Community
post #1 of 10 Old Nov 1st, 2006, 10:36 am Thread Starter
McRuss's Avatar
It has happened twice now, lock just will not 'depress' to release. I've been able to go in with a long hex wrench and spring the catch enough to get it open but don't know what the problem is. Anyone else have this problem? I 'fixed' it the first time without knowing how. Was removing plastic to get the stingray off and suddenly it was working. I cannot see where it is binding and it just acts like it is locked (I checked, it is not.....)
Just old, clutchless and clueless
Russ Locke
Lakehills, Texas
McRuss is offline
post #2 of 10 Old Nov 1st, 2006, 11:00 am
This is the key - on the stingray "tongue" below the latch there are two screws that secure the "tongue" to the seat frame. The screw on the left side MUST be a very short screw or it will bind the electric lock mechanism. You can access this by removing just the little panel under the latch (once you get the lid open). Also there is a bit of up down adjustment on the latch pin in the lid itself. May have to mess with that if it is not a lock issue.
post #3 of 10 Old Nov 1st, 2006, 12:43 pm
If you push down on the stingray lock at the same time you hit the unlock button on the fob it will usually open. Then you can check the settings and screw length.
BEhrler is offline
post #4 of 10 Old Nov 1st, 2006, 1:00 pm
Super Moderator
DavidTaylor's Avatar
This happened to me when the power lock wouldn't disengage. Turns out something in the harness that controls it shorted, and it was a PITA for the delaer to find it. I didn't get into the details with the tech but it was replaced under warranty.
David Taylor
San Jose, CA
2010 R1200RT Polar Metallic
AMA, BMWMOA
Booze Brother #4
DavidTaylor is offline
post #5 of 10 Old Nov 1st, 2006, 1:39 pm
dwsdad's Avatar
Maybe this is just nature's way of telling you to sell the LT and buy the new Connie.
'06 K1200GT - "Road Rocket"
Marshall, Tx
dwsdad is offline
post #6 of 10 Old Nov 1st, 2006, 9:42 pm Thread Starter
McRuss's Avatar
Hmmmm
Do ya think?
Russ Locke
Lakehills, Texas
McRuss is offline
post #7 of 10 Old Nov 1st, 2006, 9:52 pm
Hey, Russ... I had same problem.. just use very short screws and don't overtighten... just as Jzeitler stated.
J.M.J...
Dcn Channing
post #8 of 10 Old Nov 2nd, 2006, 5:55 pm Thread Starter
McRuss's Avatar
Fixdit
Yessir, that did the trick....I think....
What I dont understand is why it did it the first time, in the middle of a ride, and with the stock length screws? This time it was my fault, 10mm screws instead of the shorties.
Russ Locke
Lakehills, Texas
McRuss is offline
post #9 of 10 Old Jan 3rd, 2010, 1:27 pm
Re: Oddiments box lock will not release
Same thing happened to me after removing some tupperware. As mentioned above, itīs the middle left hand screw that needs to be short.
Thanks to everyone for their advise.
simoncharles is offline
post #10 of 10 Old Jan 3rd, 2010, 6:43 pm
wacolt's Avatar
Electric locks?
As my flight instructor used to say, "Simplicity means dependability."
Rider of Stahlross
1999 Basalt Grey LT
2001 Classic Red Ducati 748
wacolt is offline
Oddiments box lock failure niobium K1200LT 6 Aug 22nd, 2006 9:36 pm
Color mine Blue / qick helmet lock Randy K1200/1300GT (The Next Generation) 22 Jun 16th, 2006 9:51 pm
Trunk Lock Jammed UltraLT K1200LT 2 May 10th, 2006 3:45 pm
Disabling the locking Gas Cap justincase K1200LT 25 Apr 15th, 2006 9:39 am
BMW Bike Lock - Proper use Triker Other Stuff 5 Oct 20th, 2005 10:40 am
