3.09 FD LT Gear Ratio Build - BMW Luxury Touring Community
 20Likes
  • 8 Post By saddleman
  • 3 Post By saddleman
  • 1 Post By Hilton
  • 2 Post By saddleman
  • 1 Post By jzeiler
  • 1 Post By saddleman
post #1 of 12 Old Sep 25th, 2016, 7:17 pm Thread Starter
Enjoy The Ride
saddleman's Avatar
I'm taking some pictures of the Final Drive I'm building to use at the Smoky Mountain Fall Reunion at the Iron Horse Lodge in Robbinsville North Carolina.
This is for my 2000 LT so I'll need to install the speed sensor ring on the taper bearing hub. I freeze the hub & remove the taper bearing. I use red Loctite when I install the speed sensor ring. It then sits on the press for 24 hours. Then I epoxy the ring to the hub.
I use EP lube on the taper bearing back lash spacer so the Loctite I use when I install the taper bearing can't stick to the spacer. After I reinstall the taper bearing it sits in the press for 24 hours. This is something I also do on all of my rebuilds.
Name:	3.09 FD 2000LT Build 001.JPG
ID:	116097   Click image for larger version
Name:	3.09 FD 2000LT Build 002.jpg
ID:	116105   Click image for larger version
Name:	3.09 FD 2000LT Build 006.jpg
ID:	116113   Click image for larger version
Name:	3.09 FD 2000LT Build 016.jpg
ID:	116129   Click image for larger version
Name:	3.09 FD 2000LT Build 017.jpg
Name:	3.09 FD 2000LT Build 019.jpg
ID:	116145   Click image for larger version
Name:	3.09 FD 2000LT Build 020.jpg
CharlieVT, Hilton, Patric and 5 others like this.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #2 of 12 Old Sep 25th, 2016, 7:26 pm Thread Starter
Enjoy The Ride
saddleman's Avatar
Re: 3.09 FD LT Gear Ratio Build
The next thing I have to do is machine the hole for the speed sensor, drill & tap the hole for the bolt that holds the speed sensor. I've had a friend do this for me before but I decided to make a fixture so I can do it myself. The fixture should be done tomorrow & the reamer for the hole will be here on Tuesday. The housing on the left is the GS 3.09 gear ratio that I'm converting for the 2000 LT.
Name:	3.09 FD 2000LT Build 007.jpg
ID:	116161   Click image for larger version
Name:	3.09 FD 2000LT Build 013.jpg
Hilton, Patric and bmwcoolk1200 like this.
Dave Selvig
2004 Black LT
2000 Canon Red LT
post #3 of 12 Old Sep 26th, 2016, 1:13 am
Miles of Smiles
Hilton's Avatar
Dave, it's a pleasure to see your attention to detail.
A true craftsman at work.
Thanks for sharing.
Munmi likes this.
Jenna: Ocean Blue '06
Rena: The Committee.
ET4 Thing 1
ET4 Thing 2
Hilton is offline
post #4 of 12 Old Sep 26th, 2016, 7:03 am
ProfSnape's Avatar
Dave,
Dealing with a Simpleton here, what is the benefit for the conversion of gear ratio? Thanks!
ProfSnape is offline
post #5 of 12 Old Sep 27th, 2016, 6:25 pm Thread Starter
Enjoy The Ride
saddleman's Avatar
Originally Posted by ProfSnape View Post
Dave,
My 2000 LT came with a 2.75 ratio. I like how the lower ratio's start out in first gear better & the LT accelerates quicker with the lower gear ratio's. I've been using a 2.91 for highway riding & have used 3.20 & 3.36 gears in the mountains. This time I'm trying a 3.09 ratio. My 2004 LT that I use for my daily in town bike has a 3.09 gear in it.
Dave Selvig
2004 Black LT
2000 Canon Red LT
post #6 of 12 Old Sep 27th, 2016, 7:58 pm
bmwcoolk1200's Avatar
Dave, what is the difference between the ring gear and pinion of the different sets? Does the ring gear have a different number of teeth, smaller, larger same? I expect the pinion has fewer teeth so does that make the ring gear thicker to account for the smaller diameter of the pinion? I don't remember if you have posted any side by side pictures of the different sets.
Gordon
Sugar Hill, GA
bmwcoolk1200 is online now
post #7 of 12 Old Sep 27th, 2016, 8:36 pm Thread Starter
Enjoy The Ride
saddleman's Avatar
2.62 gear ratio = 34 tooth ring gear & 13 tooth pinion gear, 2.75 = 33/12, 2.82 = 31/11, 2.91 = 32/11, 3.0 = 33/11, 3.20 = 32/10, 3.36 = 37/11. The gear sizes also change.
sailor and bmwcoolk1200 like this.
Dave Selvig
2004 Black LT
2000 Canon Red LT
post #8 of 12 Old Sep 28th, 2016, 7:48 pm Thread Starter
Enjoy The Ride
saddleman's Avatar
I got the sensor hole drilled & reamed tonight. I also machined the bolt hole pad for the sensor clearance to the sensor wheel, drilled & tapped it.
ID:	116345   Click image for larger version
Name:	3.09 FD 2000LT Build 005.jpg
Patric and JaL3_SD like this.
Dave Selvig
2004 Black LT
2000 Canon Red LT
post #9 of 12 Old Sep 28th, 2016, 7:58 pm Thread Starter
Enjoy The Ride
saddleman's Avatar
I use Richie Wauters race car shop when I need to use a mill or lathe. I've known Richie for 28 years & work for him now & then.
ID:	116361   Click image for larger version
Dave Selvig
2004 Black LT
2000 Canon Red LT
post #10 of 12 Old Sep 28th, 2016, 8:09 pm
That is pretty handy to have.
bmwcoolk1200 likes this.
post #11 of 12 Old Sep 28th, 2016, 8:31 pm Thread Starter
Enjoy The Ride
saddleman's Avatar
The ring gear on the left is a stock LT 2.75 the one on the right is the 3.09 I'm using in two weeks.
Name:	3.09 FD 2000LT Build 008.jpg
ID:	116385   Click image for larger version
Name:	3.09 FD 2000LT Build 012.jpg
Dave Selvig
2004 Black LT
2000 Canon Red LT
post #12 of 12 Old Oct 14th, 2016, 4:07 pm
dmatson's Avatar
That is a very good idea! I have always hated how tall first gear is, so what is the top gear rpm at 80mph? That would also be very good for two up riding. Are you making these for sale?
14' KTM 1190
03' KTM 450 EXC Dually
72' Honda SL 100
67' Triumph Bonneville
65' Honda CB160
70' Honda CB350
dmatson is offline
2.62 To 2.75 Gear Ratio Report saddleman K1200LT 11 Aug 13th, 2014 4:38 am
Changing final drive gear ratio brock29609 RT Series 18 Jun 25th, 2014 9:29 am
Trouble getting into 1st gear durq K1200LT 27 May 11th, 2010 8:25 am
1st Gear Question blackcat54 RT Series 18 Jan 7th, 2010 2:17 pm
Pick a gear - any gear.... cpaine K1200LT 9 Nov 17th, 2005 7:13 am
