LinkBack | Thread Tools | Display Modes |
6" LED Light Bar?
Thinking of adding a single row led light bar, under the headlight of a '00
Think I'll have clearance issues under braking, making contact with the front fender?
It's 2" deep
It's 2" deep
2000 K1200lt
"Some have hot dinners, some have bikes... I have (had!) both!"
Sponsored Links | |||
Re: 6" LED Light Bar?
Originally Posted by zamfield
View Post
It's 2" deep
It's 2" deep
Gordon
Sugar Hill, GA
I ended up going with a slightly different led bar than yours... This one has a fairly tight U bracket si it sits very close to the plastic under the headlight.
How did you gauge that there wasn't enough clearance?
Do you know the amount of travel?
2000 K1200lt
View Post
Eazymount who made the mounting brackets for the PIAA lights on the LT made sure that they had adequate clearance. Probably the smallest form factor light of its type but expensive. I looked at other small lights to try and add some like the PIAA lights but they would have been an inch lower and probably would have interfered so I went this route with it mounted above and am happy with the way it turned out.
Just curious, what LED bar did you get?
Gordon
Sugar Hill, GA
Total suspension travel at the wheel is just over 4 inches, even more when your front ball joint lets go. Fender will touch the fairing. But then that is a different story.
Originally Posted by jzeiler
View Post
.......... even more when your front ball joint lets go. Fender will touch the fairing. But then that is a different story.
Enjoy the journey!
2003 K1200LT
2005 Yamaha R1
1975 CR125 Elsinore
1974 Honda CB750K4
1974 H2 750 Kaw
1970 Triumph 650
1961 Pan/Shovel
Couple Mini Trail's QA' & CT's
Not mine but I know of three that did fail with a fracture on the ball joint shaft that goes into the telelever and one where the ball joint was loose in the fork bridge and pulled out. All four cases were repaired with the replacement of the ball joint.
Hmmm... Sounds like I'm playing with fire!
I may cut into the small bit between the gap under the light and put it in there... I'll be taking a look at it Saturday - I'll update then!
Of course, it may just get sent back too! 😁
I git the Auxbeam light... 6" with cats eyes lenses.
Its a 30w single led with a fairly wide spot pattern... Don't need a spread as I have the piaas on the sides.
2000 K1200lt
View Post
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Gordon
Sugar Hill, GA
View Post
Consequences of this failure at the wrong time could be deadly.
You know of four failures, wonder how many more there were.
Could have been be some bad ball joints but I assume a significant hit (pot hole, etc.) started a fracture then let loose at a later date..
Enjoy the journey!
2003 K1200LT
2005 Yamaha R1
1975 CR125 Elsinore
1974 Honda CB750K4
1974 H2 750 Kaw
1970 Triumph 650
1961 Pan/Shovel
Originally Posted by CR125Honda
View Post
It's off the light bar subject discussed in this thread but I'm glad you brought it up.
2000 K1200lt
View Post
Soooo.... Stay away from potholes and light bars then?!!
Again, glad John brought it up.
If you think this could be a serious subject worth knowing about, I'm glad to see it's taken life in a new thread.
Let's all help keep our LT riders community vertical.
Enjoy the journey!
2003 K1200LT
2005 Yamaha R1
1975 CR125 Elsinore
1974 Honda CB750K4
1974 H2 750 Kaw
1970 Triumph 650
1961 Pan/Shovel
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Odd brake system and cruise control behavior | Bitsko | K1200LT | 34 | Oct 12th, 2017 6:40 pm |
Glenda or Krista? | four12 | RT Series | 39 | Feb 3rd, 2013 7:58 pm |
Cruise Control OD with new cables. | airborneod | K1200LT | 24 | Jun 14th, 2011 7:42 am |
Forum Humor | Sunderland | Humor | 1 | Nov 8th, 2007 8:18 pm |
Posting Rules | |
