Source for electrical switches - BMW Luxury Touring Community
post #1 of 14 Old Oct 23rd, 2006, 2:37 pm Thread Starter
Hey All- I've installed my heated seats that I got from a salvage yard. My '99 did not have any wiring harness for this and had to build that. Now I want to mount a switch on the dash to control the power to the seats. I'm looking for a good source for toggle/rocker switches. Needs to be waterproof obviously, miniature and illuminated. I've googled, but what I'm finding is either too big or need to buy in bulk. I just need a couple to mount in the dash. I'm sure a couple of you LT gurus must have a good supplier. Thanks.
Bruce_N is offline
post #2 of 14 Old Oct 23rd, 2006, 2:43 pm
Try a marine supply store. I have found lots of interesting stuff there.
rixchard is offline
post #3 of 14 Old Oct 23rd, 2006, 2:50 pm
mcmaster.com, grainger.com, or newark.com
do a search for illuminated switches. don't know which ones are waterproof or not. you can pick rocker, push-button, toggle, or whatever you prefer.
rjhammetter is offline
post #4 of 14 Old Oct 23rd, 2006, 3:50 pm Thread Starter
Guys, Thanks for the suggestions. I should find what I need.
Bruce_N is offline
post #5 of 14 Old Oct 23rd, 2006, 3:55 pm
I take it you are not using the factory switches, which are mounted on the underside of the r/h side of the seats?
Buck W.
San Diego
1999 K1200LT
Canyon Red
Buck is offline
post #6 of 14 Old Oct 23rd, 2006, 4:05 pm Thread Starter
Yes, I will. But since I didn't have the factory wiring, I'm tapping into a power outlet which was convenient. I figure by adding a lighted switch in-line I can easily check to be sure I shut off the seat power so I don't kill the battery. May sound confusing, but I think it will be a clean addition.
Bruce_N is offline
post #7 of 14 Old Oct 23rd, 2006, 5:04 pm
Ranger's Avatar
The seats won't have power anyway after you turn the key off. Are you not turning the key off?
Peter Tessin
2002 Champagne
Ranger is offline
post #8 of 14 Old Oct 23rd, 2006, 5:23 pm
Just wire in a relay that triggered when the key is turned on, you'll never have to worry about the battery running low and you won't have to remember to turn it on or off just use the seat switch as it was intended.
BMWMOA #120588
website has been hacked - down for now
Riding since '65 - 30+ bikes (lost count)
Current Stable:
'06 R12GS Adv, '98 Buell, '95 Ultra, '95 Fatboy, '71 Rickman, '53 Panhead
2009-2010 KxxxxLT or whenever BMW updates the platform
dronning is offline
post #9 of 14 Old Oct 23rd, 2006, 5:46 pm
ksawatsky's Avatar
Seems like an Autoswitch would work...
I'm thinking the Model AS-5NCY. It would not require a big, possibily ugly additional switch, and it would even have that nice little LED to install in the dash...
http://www.cyclegadgets.com/products...ct.asp?Item=AS
Kevin
Kevin B. Sawatsky
Caddo Mills, TX
IBA #487 (IBR 2013, 48 Plus!, B2B Insanity, 10 Tenths, SS5000, 50CC, BBG, SS1000...)
'03 Yamaha FJR1300
'08 Kawasaki KLR
ksawatsky is offline
post #10 of 14 Old Oct 23rd, 2006, 6:42 pm
myk_edwards's Avatar
Some time back, there was a tread about adding a light on the dash to indicate if the seat was set to high or low setting. Might be worth lookig for that thread. I thought there may even have been a wiring diagram??
anyone else remeber this?
Rgds
"For those that know, no explanation is needed,
For those that don't, no explanation is possible."
2001 K12 LT Toscana Green AKA Baby Sh*t Green
Kawasaki EN500 - been sold on!
Hardtail Chopper ( Honda CB 500 engine) in a box still!
myk_edwards is offline
post #11 of 14 Old Oct 23rd, 2006, 6:52 pm
Electrical Connection sells a nice seat heat indicator kit http://www.electricalconnection.com/...at_k1200lt.htm
They're also a good source for switches http://www.electricalconnection.com/...witch_main.htm
Michael
Gaithersburg, Maryland
'09 R1200RT
mteitler is offline
post #12 of 14 Old Oct 23rd, 2006, 7:01 pm
wcarter's Avatar
Bruce, I also added heated seats to my '99. How exactly did you wire it?
I put a BMW plug on mine temporarily but since the front accessory outlet is unswitched, I did manage to run my battery flat when I forgot to turn the seat off.
wcarter is offline
post #13 of 14 Old Oct 23rd, 2006, 11:03 pm
dwillie's Avatar
This may not be exactly what you're looking for, but may give you some added ideas. d.
dwillie is offline
post #14 of 14 Old Oct 24th, 2006, 7:13 am Thread Starter
Hey guys, thanks for the replies. I used the power outlet on the left side on the bike near the shift lever. I wired a relay into the harness, but the outlet is always hot, at least on my bike it is. I'm not real comfortable with that, so that's why I want to add a manual switch with an indicator light. I suppose I could look for a switched power source, but the power oulet was easy to get to without tearing down half the bike.
Bruce_N is offline
New switches added to stingray (must see) rbryant K1200LT 41 Sep 29th, 2006 7:04 pm
Odyssey Battery source mostlyirish K1200LT 14 Mar 23rd, 2006 10:56 am
Tapping The Correct Brake Power Source DaFlake K1200LT 5 Jan 23rd, 2006 10:38 am
Pheonix Switches tiedend Lighting 3 Jan 21st, 2006 3:17 am
ice>Link Source Selector? atps1234 iPod/MP3 9 Jan 15th, 2006 11:55 am
