Engine Inspection-Help - BMW Luxury Touring Community
post #1 of 5 Old Oct 23rd, 2006, 9:12 am Thread Starter
murray's Avatar
Question Engine Inspection-Help
Anyone on the list live near Morgantown NC ? I need someone to check out a engine transmission I may buy. If interested please let me know. Thanks in advance.
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #2 of 5 Old Oct 23rd, 2006, 12:06 pm
If you're talking about a used transmission out of the bike there isn't much you can check without opening it up. Look for signs of abuse, leaks, or obvious damage. Whether or not it wiil function properly will take a road test after install. You can try spinning the shaft by hand to see if it's locked up or has shifting issues but I wouldn't count on that as a dependable test. Why was it removed from the bike, do you feel the seller is being up front with you about it's history?
If it's the engine and tranny there is a little more to look at. I usually try to run a used engine before buying or installing it but with all electronics involved in an LT that would take a little effort to set up.
mjordans2000 is offline
post #3 of 5 Old Oct 23rd, 2006, 12:45 pm Thread Starter
murray's Avatar
Mike Thanks
This motor and trans is from a crashed LT in the area with under 30K miles. I agree not much to check on the outside of the trans. Motor can inspect throttle bodies, Spark plugs and valve clearance to get a impression of internals etc..
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #4 of 5 Old Oct 23rd, 2006, 12:54 pm
With only 30K I wouldn't worry too much about the internal goodies. I'd be more concerned with crash damage to the case and exposed parts.
post #5 of 5 Old Oct 23rd, 2006, 1:29 pm Thread Starter
murray's Avatar
Agree mike, this was a front end colllishion. I hope to have pictures sent .
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
DaimlerChrysler & BMW Co-Develop Hybrid eljeffe Chit Chat 31 Sep 7th, 2009 11:14 am
Any round engine types out there? BobShirley Chit Chat 24 Aug 19th, 2009 9:24 pm
Is the K1200LT engine really like a car engine? TimVipond K1200LT 30 Jul 8th, 2007 6:23 am
MMO - Marvin's Miracle Oil Challenges Engine Ping Dan-Peggy K1200LT 5 Aug 12th, 2006 12:07 pm
Engine Blow Up Part II ronk1200lt K1200LT 8 May 25th, 2006 9:00 pm
