Front end shimmy - BMW Luxury Touring Community
post #1 of 22 Old Oct 21st, 2006, 12:51 am Thread Starter
Unhappy Front end shimmy
I have a 2006 LT that has had a front end shimmy present since about 3000 miles Now at 13,000 miles it persists. Occurs most noticeable when I roll off the accelerator. Do not feel when accelerating. ALso feel on grooved pavement, or any rough pavement. Put wrong Metzler (radial) on reat at 9000 miles and it got really bad. Immediately put new set of Metzler 880s on front and back and it calmed down a bit put persists. Dealer replaced steering damper 5 weeks ago with no change. Had a long time BMW mechanic take a peak and he felt the steering damper, new or not, was too weak and recommended to dealer he check the new dampers to guarantee they were not defective or put after market damper on. Dealer called the field engineer who recommended putting dunlop tires and replacing the front ball jount and fork it sits in. Had that done today at the dealer--the shimmy in deceleration is gone but the bike feels squirrely. At 70mph the front end wants to wobble a bit--enough to make me uncomfortable when riding it. ie--if I were test riding my bike I would not buy an LT due to the front end instability at high speed. ANy ideas.
Thanks in advance
greg
gregorysharp is offline
post #2 of 22 Old Oct 21st, 2006, 1:38 am
Shimmy with hands on?
Thanks in advance
greg
Greg, my LT doesn't shimmy, but my brother complains about his '05. His dealer said it's normal. My dealer said it is normal. If it's a hands-off problem, consider trying handlebar weights. Otherwise, you need the help of more experienced LT owners.
Regards,
2000 K1200 LTC - Canyon Red
jgburns is offline
post #3 of 22 Old Oct 21st, 2006, 8:13 am
Thanks in advance
greg
Greg: I also have a 2006 with 14K on her! The shimmy/shake/wobble has persisted since the bike was new. New tires and different air pressure has not remedied the persistent problem. It is a hands off the bars problem. Seems strange but I guess we have to live with it. There has been many posts and many suggestions.
For one to truely understand the problem they must ride a 2006 model to experience the effects. The symptoms are most noticeably at 25-45 mph with cruise set or when deaccelerating. Rough road surfaces increase the dynamics.
I truely believe the steering damper it the the problem. Hope you find the answer.
AL
Serebigal is offline
post #4 of 22 Old Oct 21st, 2006, 12:53 pm Thread Starter
Question Lt front end shimmy
Thanks for the input guys. It is somewhat comforting to know I am not the only one with this problem. The hands off shimmy is now gone sine the dunlop tires and new front fork part but I am left with instability in the front at 70 plus mph--feels like a slow wobble that is very discomforting to me. any other ideas
greg
post #5 of 22 Old Oct 21st, 2006, 1:07 pm
greg
Hey Greg, I'm glad you found relief from the shimmy. Please post the Dunlap tire model with load rating that you are using. I looked a while ago and didn't see Dunlaps suitable for the LT.
Regards,
jgburns is offline
post #6 of 22 Old Oct 21st, 2006, 1:43 pm
I remember someone posting positive results with this damper:
http://www.hyperprousa.com/catalog.p...acement)%2099-
Sunderland is offline
post #7 of 22 Old Oct 21st, 2006, 2:34 pm
Steve_R's Avatar
Your answer to question is in the FAQ under Brakes and Tires.
On His Ride,
Steve
KA5MTE
'00 Unigo - Dragon's Egg
Have you
bmwlt.com lately????
Steve_R is offline
post #8 of 22 Old Oct 21st, 2006, 7:01 pm
ez_rdr55's Avatar
shimmy fix
My '04 would shake so bad I was ready to get rid of it, but I bought a balancer and put some Avons on it and it's fixed. The Avons saved my LT...for now anyway.
ez_rdr55 is offline
post #9 of 22 Old Oct 21st, 2006, 8:48 pm
Hi Greg,
I've had the front end shimmy since about day-one. No matter what tire pressure and basically hasn't changed with over 10K now. Had the same thing on a 97 GL1500SE. To me its the same old BS from BMW as with the infamous "surging" issue with the pre-2004 R engines. Some bikes were worse than others, some just denied having it and low and behold, BMW finally admitted it and fixed it in 04 with the twin-spark. I predict it will be the same with the "LT Shimmy"! BTW, I also just had my steering damper replaced under warranty and - no change. I have heard that the GL1800 suffers from the same thing shimmy and some have changed the steering head bearing from one type to another (sorry, I forgot the details) and it appears to have resolved the problem. I plan to look into a similar fix if possible over the winter. Until then, I just "hold on"!
Hope this helps,
Lee
leckhart is offline
post #10 of 22 Old Oct 21st, 2006, 11:33 pm
I balanced my tires on my Marc Parnes balancer. Problem resolved for about 3K miles.. now it's back.. but not very severe. Now, I rode it "hard" today, about 350 miles... lots of hard corners and braking...plus some good straight line running. Strange, but now the "shimmy-shimmy-doo-wha" is G-o-n-e... Once I have some "commuting" miles it may return.. that will be interesting to see...
J.M.J...
Dcn Channing
post #11 of 22 Old Oct 22nd, 2006, 2:50 am Thread Starter
Fixed the shimmy
Al--seems I have fices the shimmy--the dealer replaced the front end Fork just below the ball joint--changed the rake angle I believe. Have gotten used to the much quicker handling. They also put dunlop tires on. Had an experienced LT rider check my bike out today and he feels the rear shocks are shot and that may give me the slight feeling of instability I feel in the front end with higher speeds. I plan to put ohlin shocks on ASAP. Dealer told me it was not unusual for the stock shock to die at 13 to 15 thousand miles.
Thanks for the input--I was really firm with the dealer that I was not going to accept the shimmy--like please fix it or give me a different bike. They called the field engineer to come up with the fix for mine. They did tell me that there is an 06 LT in washington that they have replaced both wheels, tires, shocks, steering damper and still not fixed. Oh well.
greg
post #12 of 22 Old Oct 22nd, 2006, 9:58 am
Hmmm. I wonder if the Telelever needs it's bearings replaced? Sounds similar to the way my HD acted. The problem with that was movements in the "drive" component seperate from the "frame"...in this case any slack in the telelever pivot would result in 'instability' feel...
Just a thought.
J.M.J...
Dcn Channing
post #13 of 22 Old Oct 22nd, 2006, 1:10 pm Thread Starter
Smile Dunlop for LT
The Dunlops are D 205 . The front is a touring 120/70 B17 M/C 58V and the rear is a 160/70 B17 79V. Not sure if the 59 and 79 V mean anything. I am a rookie at this stuff. Front is at 42 lbs and the rear at 46.
greg
post #14 of 22 Old Oct 22nd, 2006, 6:31 pm
2005 LT Shimmy
My '05 never had a shimmy until I had both front and rear tires replaced together for the first time. My bike came stock with ME 880's and I continued to use them. At 13k I replaced the rear tire and no shimmy afterward. I replaced both front and rear at 26k and I have had a shimmy since. I have adjusted tire pressures up and down with no effect. I even adjusted the rear shock preload, strange I know but a higher preload seemed to improve the condition slightly. I now have 30k on my LT and I have not had a chance to do much riding this year other than day trips but I just returned home last week from 10 days on the road and guess what. NO Shimmy! I put 26k on my LT during the first 20 months of ownership. Draw your own conclusions but I think there is a correlation between the tires, amount of riding and shimmy. Hard compounds causing flat spots from setting for a week between day trips or whatever. I've decided to do as I've always done; keep my tires properly inflated and balanced and just keep on riding.
ramlin is offline
post #15 of 22 Old Oct 22nd, 2006, 10:52 pm
Dochatley's Avatar
Greg,
Since purchasing my bike used a year and a half ago I have run Stones 020 radials. I recently changed over to Metz's and I too experience a wondering type behavior at speeds of 60-80 (afraid to go faster on these tires). Running 42/48 but plan to try a lower pressure to see if there is a change in this unstable handling. I hate it.
If you want to make God laugh, tell him your plans
Jerry P. Hatley
2007 R1200RT (Betty Lou)
2009 Harley Roadglide (sold)
2007 Goldwing (sold)
1999 BMW K1200LT (sold)
2004 Harley Ultra Classic (sold)
2002 Harley Ultra Classic (sold)
1998 Harley Roadking Classic (sold)
Dochatley is offline
post #16 of 22 Old Oct 23rd, 2006, 1:33 pm
BlackBMW's Avatar
Is it really a shimmy? As a new LT owner, I have noticed a little "instability" in it's handling. My early opinion is that it is simply a ride characteristic of the LT. I've played with the suspension pre-load and found that running higher tire pressures (42/48), I gained stability improvement. Also, since I removed the rear trunk....significantly better handling.
One of the other "big" machines (Honda Valkyrie) I owned really felt like it was on rails. I mean really planted. The Valk's handling was outstanding for a long wheelbased, heavy-ass machine.
I'm guessing the geometry of the LT (and maybe more-so with the new rake/trail on the 2005+), doesn't lend to that planted-feeling handing, as much.
I have owned other big machines (HD Road Glide for instance) that were far inferior to the LT in handling. It all depends on the bike and it's geometry.
I haven't owned the LT long enough to make a definative statement on it yet. My early opinion is it's handling for a big machine is very good, just not great.
Mike M
2007 K1200GT Dark Graphite
BlackBMW is offline
post #17 of 22 Old Oct 23rd, 2006, 5:55 pm
charlieg's Avatar
Yes, it really is a shimmy or a wobble if you prefer. I have had this condition come and go on my '05 depending upon tires and their wear. I completly lost the shimmy condition when I last replace my rear Metz with a new Metz. I believe most of these shimmy-wobble problems are a tire issue either balance, production quality, inflation or wear. The big bike is just affected more so than a lighter machine. As for handling, with the preload up so the center stand won't touch, she will lay over and hug a corner right down till the pegs are pushed up then touch the fairing without a problem. -Chuck-
'05 K1200LT
'92 FXSTC
'66 HD Sprint
IBA #375
"Eat, Drink and be Merry for tomorrow we Ride"
charlieg is offline
post #18 of 22 Old Oct 24th, 2006, 2:52 pm
jpalamaro's Avatar
Thanks in advance
greg
I had the dreaded front end wobble AND a shimmy a low speeds. The original Bridgestones were in sorry shape, thru no fault of my own as I checked inflation frequently. Under warranty the dealer replaced some knuckle/ball-joint in the fork ass'y AND I replaced the tires with whatever Metzelers were recommended. All issue gone . . . bike now perfect again. My '05 has about 8500 miles on it.
Jacksonville, FL (USA)
jpalamaro is offline
post #19 of 22 Old Oct 25th, 2006, 1:28 am Thread Starter
Red face Replaces part
John--thanks for the input. I found out the dealer replaced the lower ball joint fork bridge with the stock part. The new tires were not the only part of the fix or I am sure they would not have popped for about $850 worth of warranty work not counting the tires. ANyway--I am a happy camper now--she rides like a big rocket like I expected her to when I bought her.
greg
post #20 of 22 Old Oct 26th, 2006, 10:02 am
PATTERSON's Avatar
GREGORYSHARP
I might be the other Washington bike that they told you about. Went from the OEM tires to 880's (fantastic mileage!!) Changed out shocks to the Ohlins....had the front end work done......to no avail. They called (So. Sound) and want me to come in for the Dunlops now, which I will do....but I'm getting such good mileage on the 880's (13k Miles), I'll run them on out for a while yet. I was told that out of the 12 05's they'd sold, that 4 of them have this problem.....and that your problem had finally been resolved with the Dunlops. Just turned 22k miles last night (10 months 2 weeks) and was doing the "hands off" thing.....and had to really hunt for that "spot" where it'd get all "jiggy".....anything outside that (above or below) the wiggle would quiet down right away.....completely the opposite of what it'd do when the tires were new. I keep my tire pressure at the high end of things (F46-R48)....
Patterson/USAF1....'05 LT
and the little guy behind me is the world famous "Marty Hill"
Never look into a lazer with the remaining eye
363K on BMW's
PATTERSON is offline
post #21 of 22 Old Oct 26th, 2006, 6:29 pm
zippy_gg's Avatar
It still doesn't sound right to have to purchase a brand new $300.00 damper for a brand new bike.
Could this phenomenon be related to the different camber used to make the bike handle easier at low speeds?
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #22 of 22 Old Oct 28th, 2006, 11:43 am
LJSMITH1's Avatar
Front End Wobble
Being an engineer, I am intrigued at all of the responses regarding the causes for front end 'wobble' or 'shimmy'. Having wrenched on many vehicles and bikes over the years, I feel that I have a unique perspective on the causes of this phenomenon.
In this case, I am convinced the wobble/shimmy problem is due to any one of the following (in order of likelyhood):
1) Front tire out of balance or wheel out of round - Can be caused by sitting for a long time, low air pressure, hitting an object hard, bad bearings, tire defect (internal delam), or worn out tire. A problem with the rear tire could also cause a similar issue. Don't assume that the tire is balanced unless you actually check it again at the time you are performing your analysis. As it is spinning, check for a hop or distortion in the tire or wheel. Heavy, rotating assemblies are notorious for creating harmonic type vibrations or movements. If your wobble goes away at a certain speed, you have certainly identified a rotating assembly balance problem - no question.
2) Steering Damper - Worn out seals or no fluid inside damper. This damper is designed to dampen lateral road input and/or rapid user input to the pivot of the steering forks. If not enough resistance is offered during a frequency input, it will allow a harmonic 'shimmy' to develop. One way to test the damper is to raise the front wheel off the ground and rapidly cycle the handlebard right to left. If you feel a significant resistance doing this fast versus slow, then the damper is probably working. If you see evidence of a leak around the piston rods, you should replace the damper.
3) Front Shock - Worn out, no damping effect. If the roadwheel is not kept from bouncing on the pavement, this 'hopping' may feel like a wobble or cause a shimmy. Leaking shocks are a giveaway, but are not the only way to tell. If you drive slowly along and stop suddenly using only your rear brake, it will cause the front end to dive. The bike should only bounce 1X (down-up-stop). If it goes for more than that, the front shock should probably be replaced.
4) Front Telelever - Worn or loose ball joint or other main suspension component. Same as #3
If all of these areas/components truly check out ok, there is a likelyhood that there may be a problem with your rear suspension or frame alignment.
Balancing tires requires a good, repeatable technique. In the case of a shimmy being solved by balancing of a front tire, and then its return 3K miles later, I would remove and rebalance the tire/wheel again. Spin the tire multiple times to validate the balancing before mounting it back in the forks. Tire characteristics change over time and may cause out of balance condition. Riding style and road conditions play a big part of why this happens. Sometimes a balance weight is thrown off and there is no evidence that you may notice (i.e. no adhesive residue). You might think that the weights that are there are the weights that were applied at the last balancing. Sometimes the tire is just defective due to belting defects or compound thickness uniformity issues.
I hope this helps shed light on these hard to diagnose issues.
Good Luck!
-Larry
2005 BMW K1200LT Blue
BMWMOA #124788
Predecessor:
1999 K1200LT (entered the BMW "organ donation program" on 6/2/11) 38,256 Miles
LJSMITH1 is offline
Front Brake Pad R&R (looong story) was K1200LT 1 Sep 3rd, 2006 11:48 pm
Front Axle Is Stuck! microdoc K1200LT 15 Jul 4th, 2006 4:45 pm
Low front tire miles, and rear brake noise tobiwan K1200LT 1 Jul 3rd, 2006 11:42 pm
Rear brake squeal linked to front brakes? Vince_nj1 K1200LT 19 Apr 2nd, 2006 11:37 am
now for something different: front fender failure docwagner K1200LT 18 Nov 27th, 2005 5:22 pm
