Rear ABS Sensor - BMW Luxury Touring Community
post #1 of 12 Old Oct 20th, 2006, 3:50 pm Thread Starter
acs5166's Avatar
Rear ABS Sensor
Looking at my rear ABS sensor on the rear caliper - it has two screws holding it, but also has some black, hard gunk which looks like it was melted around it in the caliper hole to hold it tight. The sensor is cocked about 10 degrees, ie not seated flat into the caliper.
Is this normal, or did the guy before me do a butcher job?
Cheers - Jack
2000 K1200LT
acs5166 is offline
post #2 of 12 Old Oct 20th, 2006, 4:29 pm
Hi, Jack. I can say that on my LT, (DAMHIK) there is only the two screws holding it on and it's square in the bracket. Looks to me like you need to get out the big knife and start correcting the butchery.
Carvin' Karl
Disreputable Rode Hard & Put Up Wet Old Deadbeat Geezer
"We're all here because we're not all there"
--Ken & Gene Hunt
'09 Aprilia Scarabeo 500ie -- QuickSilver II
'02 LTE Silver -- Retired
'02 LTC Mauve -- RIP
2009 Subaru WRX, Stage 1 269 whp, 293 ftlb - INTERCEPTOR
2003 Ford Focus, 220 hp @ wheels 180 ftlb torque @ wheels - Traded
Northern Colorado
kmurphy165 is offline
post #3 of 12 Old Oct 20th, 2006, 5:10 pm
Cheers - Jack
2000 K1200LT
Possibly overheated the caliper and melted the sensor housing? Just guessing.
post #4 of 12 Old Oct 20th, 2006, 6:06 pm Thread Starter
acs5166's Avatar
Duh! You probably nailed it. I found it while I was repairing my final drive. During the disintegration of the bearing my wheel was pretty loose and the rotor rubbed against the caliper. Probably heated the thing up and melted it.
I've been trying to figure out what's going on since when I push on my back brake it barely stops the bike now. When the bearing went, most of the brake fluid disappeared. Don't ask me where. My guess is that it boiled out - probably overflowed back through the reservoir. I refilled it, got the air out, but it's really weak stopping the bike.
-- Jack
2000 K1200LT (stops on a real large dime)
acs5166 is offline
post #5 of 12 Old Oct 20th, 2006, 6:08 pm
Old Slow Guy in A Fast Car
katnapinn's Avatar
Cheers - Jack
2000 K1200LT
If you could post a pic of it ,it would help a bunch
Stevie Shreeve
katnapinn is offline
post #6 of 12 Old Oct 20th, 2006, 6:50 pm Thread Starter
acs5166's Avatar
Ok, it took me a while to figure out how to post images. I think this is clearly melted.
Thoughts??
-- Jack
acs5166 is offline
post #7 of 12 Old Oct 20th, 2006, 9:37 pm
harrowbmw's Avatar
Cooked sensor
Greetings all.
Hey, nice photograph if nothing else Jack!
I recently picked up a used rear abs sensor for my '99 LT Jack. I'm sure they have plenty in stock. They even sent it all the way over here to Australia for me.
Kindest regards to all.
Paul Harrington
Australia
[email protected]
1999 K1200LT Champagne "Bismarck"
1983 base K100 "Bavarian Belle"
harrowbmw is offline
post #8 of 12 Old Oct 20th, 2006, 10:33 pm
strsout's Avatar
It's melted...
Mine has only the 2 screws holding it.
Loma Linda - CA
IBA#14,458 - AMA
strsout is offline
post #9 of 12 Old Oct 20th, 2006, 10:57 pm
kevincook's Avatar
I had trouble seeing that picture. Maybe this is a little better.
Kevin
Slave Cylinder Procedure->
kevincook is offline
post #10 of 12 Old Oct 21st, 2006, 6:22 am
grifscoots's Avatar
When my rear drive went south, the first thing I did was pull the rear brake pads before riding any further. It could save you some heartache and bucks.
-=grif=-
Grok
grifscoots is offline
post #11 of 12 Old Oct 21st, 2006, 11:08 am Thread Starter
acs5166's Avatar
I would assume that final drive oil and probably brake fluid got on the brake pads. Is that absorbed into the pads? Because my braking in the back is terrible.
Cheers - Jack
____________
2000 K1200LT
acs5166 is offline
post #12 of 12 Old Oct 21st, 2006, 7:50 pm
grifscoots's Avatar
You should definitely replace the pads if gear lube got on them. I pulled mine before any spitting, spotting and spouting happened.
-=grif=-
Grok
Inductive speed sensor on Rear drive problem? hoodoodrum K1200LT 31 Feb 5th, 2014 9:12 pm
ABS Sensor Gap, Just Curious Hilton K1200LT 2 Jul 1st, 2006 4:05 am
Rear Drive Speed Sensor dgl57 K1200LT 12 Jan 13th, 2006 6:08 am
