Blue Smoke - BMW Luxury Touring Community
post #1 of 15 Old Oct 18th, 2006, 5:26 pm Thread Starter
Blue Smoke
Buying a 2000 K1200L, 48,000 miles. When the dealer started it up, blue smoke came out of the exhaust. He told me that this happens on this model when it sits too long on the kickstand without being started. Maybe about 3 weeks. The smoke did disappear after running for a bit, but I don't know if he's giving me a line or not. I know Ventures and Harleys and Hondas, but this will be my first BMW. ANyone every heard of this?
siwillia is offline
post #2 of 15 Old Oct 18th, 2006, 5:30 pm
JPSpen's Avatar
It's OK
Don't worry about it.. Because the engine is tilted sideways...
When the bike sits on the side stand oil can seep into the cylinders if it's just shut off and immediately put on the side stand.... They all do it... It's normal..
As long as it goes away after a bit... then you're fine....
Just remember to keep it standing straight up or even a little to the right for 15-30 secs after you shut it off and it'll never smoke....usually ......
Good luck, You'll love your LT..
91 R100GS "It'sNotAMoneyPit"
JPSpen is offline
post #3 of 15 Old Oct 18th, 2006, 5:39 pm
DGM
Wink
It will smoke even if you leave it on the side stand half a day. Three weeks should have killed all the bugs for a block.
Don
DGM is offline
post #4 of 15 Old Oct 18th, 2006, 5:51 pm Thread Starter
Blue Smoke
For a moment I thought this was a BMSW (Blue Motor Smoke Works). You must really love the bike or you wouldn't put up with it. Is it really that good of a ride? About how long can this motor last? 100,000 miles, or more?
siwillia is offline
post #5 of 15 Old Oct 18th, 2006, 6:11 pm
JPSpen's Avatar
Yes it is...
siwillia
Yes is is that good of a ride.... It's just a little quirk....
Bob's motor cratered at 186,000 miles ........Many go over that...
JPSpen is offline
post #6 of 15 Old Oct 18th, 2006, 7:19 pm
Parking on the centerstand pretty much eliminates the start up smoking, but even then if parked on a surface that leans it a little to the left it may smoke a little. Since the head is on the left side, and the side stand leans it to the left, any oil on the cylinders at shut down may slowly seep past the rings and into the combustion chamber. It does not do it all the time, just occasionally. I think it depends on how the ring gaps are positioned around the pistons, and which pistons are to the left when the engine stops.
Yes, it is that great a ride!
It is not at all unusual for a K engine to go well over 200,000 miles with no major work. One member here was WAY over 300,000 miles, and would undoubtedly put many more on, but the bike was totaled in an accident.
I had an unusual problem, in that a misdiagnosed vacuum leak caused detonation damage to my pistons, so I replaced them at 100,000 miles. There was NO really measurable wear in the engine, even the ring gaps were still within INSTALL tolerances! The crank bearings measured in install tolerances, so the engine went back together with the original bearings in it. There was absolutely no measurable cylinder wear. So basically, if you do not get well over 100,000, probably nearer 200,000, there is something unusual that happens. There will always be the rare early failure, but there have been only two or three including mine in the 5 years I have been on this site.
post #7 of 15 Old Oct 18th, 2006, 8:50 pm
dwillie's Avatar
"Is it really that good of a ride?"
Yes, it is really that good of a ride. d.
dwillie is offline
post #8 of 15 Old Oct 18th, 2006, 9:08 pm
motorman587's Avatar
Sometimes, before starting lean it to the other side for a few seconds, helps too.
motorman587 is offline
post #9 of 15 Old Oct 18th, 2006, 9:32 pm
Actually, that is right after stopping. Before starting would not do anything. The idea is that right after you shut down the engine, lean it slightly to the right for a few seconds to let the majority of the oil on the cylinder walls drain back to the sump and not sit there on the lower side of the cylinder behind the piston when the bike is put on the side stand.That oil can try to work it's way through the small clearances to the top of the piston, to be burned on start up.
post #10 of 15 Old Oct 18th, 2006, 10:54 pm
Wink But not too far to the right
...or you'll be joining the 'which way did you dump you LT poll.'
If you're looking for another don't worry about it, add me to the list.
Regards,
2000 K1200 LTC - Canyon Red
jgburns is offline
post #11 of 15 Old Oct 18th, 2006, 11:26 pm
I don't worry about which way to lean it while parking. Whatever smoke comes out always seems to be way behind me.
Too bad the Germans didn't just flip the engine across. Would have solved that problem easily.
post #12 of 15 Old Oct 19th, 2006, 8:07 am
rkirker's Avatar
Yep but,
Who wants a front wheel drive bike
Rich Kirker
2002 LTC Pacific Blue
Caliper Moto Lights, Hyper light brake lights, Spiegler brake lines, Ride West side markers, Grip puppies, HyperPro Springs and CA HID Kit.
BMWMOA #124306
2009 Honda Shadow (Wife's)
Blue & Pearl
"Well It’s not rocket science but absolutely a nightmare. At the end of the day you had a fairly unique situation that I personally at this moment in time could see me having as well 24/7. With all due respect, it shouldn’t of happened."
rkirker is offline
post #13 of 15 Old Oct 19th, 2006, 12:26 pm
hognot's Avatar
That is a good question for you guys that know all about the design of this engine. Inquiring minds want to know.
hognot is offline
post #14 of 15 Old Oct 19th, 2006, 2:15 pm
Nice.
Actually, Yamaha/Öhlins develop a hydraulically power front wheel drive assist. They said it worked great in loose traction (think dirt bike) and on heavier bikes (think large tourers). I imagine it added weight and cost which means unless someone could prove a significant benefit, it will remain in the R&D realm.
post #15 of 15 Old Oct 19th, 2006, 2:21 pm
I don't know why they designed the original K-motor that way, but once they did it was pretty much stuck there. The K11 and K12 motors are just incremental improvements, and flipping it would be an entire redesign.
Note that the new KGT has the sam swingarm as the R bikes, but that it is flipped to accommodate the new slant-4 motor.
H9 Cool Blue White High Beam BToliver K1200LT 2 Oct 4th, 2006 5:19 am
Smoke!!! hognot K1200LT 15 Sep 22nd, 2006 8:27 am
Blue Butt Rally, 2006 tlash Northern California 24 Aug 11th, 2006 9:58 am
Color mine Blue / qick helmet lock Randy K1200/1300GT (The Next Generation) 22 Jun 16th, 2006 9:51 pm
Cardo Blue Tooth Adapter ehaughn Intercom, CB, & 2-Way Radios 1 Jun 12th, 2006 7:22 am
