2000 1200 LT gear witness blurry - BMW Luxury Touring Community
post #1 of 11 Old Jun 19th, 2016, 9:31 pm Thread Starter
Hi, I have a 2000 1200lt and the clock and gear witnesses or indicators are almost gone, can't see them but blurry digits.
Is there anything to fix them, do I need to change them?
Thank you!
Jose
Puebla, Mexico
02/2000 BMW K1200 LT (Canyon Red)
Barkaino is offline
post #2 of 11 Old Jun 19th, 2016, 10:02 pm
Munmi's Avatar
Re: 2000 1200 LT gear witness blurry
Is there any blurring over the other indicators such as speedo, turn signal indicators, etc? There may be an issue with the instrument cluster lense. Here is a link to a possible fix.... http://www.bmwlt.com/forums/k1200lt/...cover-diy.html
Scott and Theresa
Munising, MI
2004 K1200LT Black
2014 Kawasaki KLR650
Munmi is offline
post #3 of 11 Old Jun 19th, 2016, 10:30 pm
My radio display was hazy where it was difficult to read the letters. A forum member suggested Denatured Alcohol and a cotton swab. It worked perfectly. I purchased a can from my local hardware store.
Rob, 2000LT
Navarre, FL
Name:	Denatured Alcohol.jpg
Fun Bobby is offline
post #4 of 11 Old Jun 19th, 2016, 11:20 pm
Axle's Avatar
photo please !! the unit could be replaced I had mine out this past weekend or is it the outer plastic causing the problem
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #5 of 11 Old Jun 20th, 2016, 8:18 am
Yeah, it would be nice to be blurry. Mine is missing digit segments on watch and gear. How do we repair this?
nikosK1200LT is offline
post #6 of 11 Old Jun 20th, 2016, 6:29 pm
Axle's Avatar
there are 11 clusters posted on ebay presently, buy one and put your speedo into the replacement cluster
Regards Linton
2002 K1200LT
My Toys
1976 Datsun 260Z
Axle is offline
post #7 of 11 Old Jun 21st, 2016, 9:13 am Thread Starter
Hi guys,
here are the pictures of both the radio and the gear display.
any ideas on how to fix them?
thank you.
ID:	110937   Click image for larger version
Jose
Puebla, Mexico
Barkaino is offline
post #8 of 11 Old Jun 21st, 2016, 9:15 am Thread Starter
Rob, 2000LT
Navarre, FL
hi rob, i'll check if i can get it here. hopefully it will work at least with the radio, im still missing the gear display.
Jose
Puebla, Mexico
Barkaino is offline
post #9 of 11 Old Jun 21st, 2016, 9:17 am Thread Starter
actually mine has the same issue... does it look like mine?
did you get a way to fix it?
Jose
Puebla, Mexico
Barkaino is offline
post #10 of 11 Old Jun 21st, 2016, 1:29 pm
I'm confident the denatured alcohol will work with your radio display. Mine had the same appearance as yours before I used the alcohol. As for the missing segments on your gear display, I'm at a loss. I'm sure one of the forum wise ones will chime in with a suggestion.
Rob, 2000 LT
Navarre, FL
post #11 of 11 Old Jun 21st, 2016, 7:30 pm
Try Google "fix LCD display". There were several there none of which were as comprehensive as I would have liked. Two things cause this. Failure of the ribbon cable to LCD "sandwich" and failure of the "sandwich" itself. The links will help with the cable but the sandwich is not well described. The LCD is connected via silicone strips with flexible conducting lines in them. They make the contact from the electrical board to the glass LCD display. Often just taking it apart and cleaning up the contacts on the electrical board (pencil eraser) and re-assembling the sandwich holder will fix missing pixels. Here is one good source for how they are hooked up.
Shifting Problems / Gear Indicator Problems rwflier K1200LT 0 Jul 12th, 2008 2:09 am
Gear shifting points revisited bmwrubbercow K1200LT 20 Jul 10th, 2007 1:34 am
French Test of K1200GT eljeffe K1200/1300GT (The Next Generation) 2 Apr 8th, 2006 6:29 pm
Pick a gear - any gear.... cpaine K1200LT 9 Nov 17th, 2005 8:13 am
