shift linkage adjusting - BMW Luxury Touring Community
post #1 of 13 Old Oct 15th, 2006, 3:31 pm Thread Starter
Reid's Avatar
Hi.
Can anyone guide me through the correct adjustment procedure for the shift linkage? My BMW dealer adjusted my shift linkage, but screwed it up. I can get to first gear but no other gears. Since I just moved to Sioux Falls, SD I can't take it back to the dealer (180 miles in first gear is a bit much!) I was told by the dealer that the distance between the two lock nuts is 36mm. However, mine is adjusted to about 2.25 inches. So, I assume I'll have to disconnect the ball end and thread some rod into it. However, I'm not sure they know what they're talking about.
Thanks much!!!!
Reid
Reido
K1600GTL...Blue Metallic
USMC 1971-1975
Ham Radio Call: W0FVR
"The right to be heard does not automatically include the right to be taken seriously."
--H.H. Humphrey
Reid is offline
post #2 of 13 Old Oct 15th, 2006, 5:06 pm
zippy_gg's Avatar
Lightbulb
Originally Posted by Reid
Hi.
Thanks much!!!!
Reid
Actually you don't have to disconnect the ball end. Just remove the foot rest plate, move it around so you can reach the adjusting nuts behind it and try different settings, put the foot rest plate back on and test, repeat until you are satisfied with the results. Then you can tighten everything back into place. It worked for me!
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #3 of 13 Old Oct 15th, 2006, 5:51 pm Thread Starter
Reid's Avatar
That's what I did when the rod broke, but now I'm told there's too much rod between the locknuts, so I believe I need to shorten that distance which requires removing the ball end I think!
Reido
USMC 1971-1975
--H.H. Humphrey
Reid is offline
post #4 of 13 Old Oct 15th, 2006, 6:17 pm
Miles of Smiles
Hilton's Avatar
Smile I'll Measure My Spares.
Not sure if this may help, but as I have both linkages in my tool box as spares I measured. Both original as supplied :
Long one. 112.92mm end of ball to end of ball. 38.10mm between lock nuts.
Short one. 67.07mm overall, but one ball has a slight flat on the end of the ball. 12.52mm between the lock nut and the round moulding on the ball. HTH
Jenna: Ocean Blue '06
Rena: The Committee.
ET4 Thing 1
ET4 Thing 2
Hilton is offline
post #5 of 13 Old Oct 15th, 2006, 9:53 pm
Reid,
Mine are set: as measured, locknut face to locknut face on the long rod = 38mm
as measured, locknut face to (no locknut) short rod = 14mm
Hope this helps. My 99 shifts perfectly. And, to clarify you have 38 mm of threads showing and 14 mm of threads showing.
Carl
K1200LT w/ KLT s/c
K1100LT w/ ECC
KLR-650
N9BMN
FD <> 4%
bmwmoa 100984
Tourdog is offline
post #6 of 13 Old Oct 15th, 2006, 10:15 pm
zippy_gg's Avatar
I never measured mine...
I just tried different settings until I was satisfied.
I also replaced my linkage with a kit from Philjohn, a member on this forum, on both my '99 after it broke and on my '03 as a preemptive strike. Very smooth!
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #7 of 13 Old Oct 16th, 2006, 10:15 am Thread Starter
Reid's Avatar
Thanks a lot, everyone. The confirmation of measurements is very helpful. I think I know what I need to do.
Reid
Reido
USMC 1971-1975
--H.H. Humphrey
Reid is offline
post #8 of 13 Old Oct 16th, 2006, 10:57 am
You do have to disconnect one ball end, or you cannot make any adjustment. The nuts just lock the setting in place, but at least one ball end has to be turned in or out to adjust the length.
post #9 of 13 Old Oct 16th, 2006, 12:09 pm
Dave is correct and additionally, if you want the shifter to a higher position for comfort you 'COULD' file the chrome plate that the shifter bar was hitting after they improperly adjusted it. My dealer said "you can't adjust the shifter height" well I did and experienced your adventure and now can adjust em in 5 minutes FLAT!
2013 BMW Damask Red K1600GTL
2014 BMW K1600GTL-E EXCLUSIVE
2001 Honda C-250 Helix
Smokin'
SmokinJoe is offline
post #10 of 13 Old Oct 16th, 2006, 12:46 pm
zippy_gg's Avatar
I tried... and tried... to be right all the time, but alas it ain't so. Dave you are absolutely correct.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #11 of 13 Old Oct 16th, 2006, 2:14 pm
dglenn1's Avatar
Originally Posted by Tourdog
Reid,
I measured between the centers of the ball ends on mine. Probably the short shaft - the one that connects directly to the pedal shifter. Factory was 3.75". I adjusted out to 3.875" when I had the Suburban Machinery peg extenders on. The only measurement that counts is the distance between the centers, and only then on the same bike. All the others will vary depending on the vendor of the components and their tolerances and how the engine/trans was placed in relation to the foot pedal. The locknut faces, ends of the ball ends etc are not functional surfaces and will vary, not significantly, but they will vary from bike to bike. (Just the annoying engineer in me coming out.)
Dan
2005 K1200LT - Ocean Blue
; Nolan 103 Helmet w/Bluetooth;
and
(Secures gear/luggage);
; Droid X (Replaces
and factory radio);
(Not installed);
(Currently unistalled),
; Clymer Manual; BMW Service DVD
dglenn1 is offline
post #12 of 13 Old Oct 16th, 2006, 2:40 pm
The center distance affects where the shift lever is positioned, and can easily be adjusted up or down to the rider's preference. I have adjusted at least three other riders gear shift levers, plus my own. This has no affect on the transmission shifting though, unless you can adjust the lever so far that it hits something, then you will not get full throw on the transmission lever.
post #13 of 13 Old Oct 16th, 2006, 3:11 pm
dglenn1's Avatar
Really just commenting on the measurement exchange. Can't see how it would effect shifting either other than positioning the pedal too high or too low for the shifter to grab the next gear like you are saying. It's the only part of the bike I've dug into, looking forward to the 12K to learn more.
Dan
and
; Droid X (Replaces
and factory radio);
(Not installed);
dglenn1 is offline
Shift linkage lube - it's a sinch! Zotter K1200LT 14 Jun 20th, 2008 2:26 pm
Need a shorter shift linkage DarrellM5 K1200LT 17 Mar 11th, 2007 1:53 am
Broken Shift Linkage on 05 Big_E K1200LT 6 Oct 1st, 2006 5:31 pm
Shift Linkage Broken carl_k1200 Bike Talk 4 Jul 17th, 2006 10:48 am
Broken Shift Linkage zaphod K1200LT 3 Jun 13th, 2006 6:03 pm
