2005 KLT ABS Question - BMW Luxury Touring Community
post #1 of 10 Old Jun 13th, 2016, 1:57 pm Thread Starter
want2tour's Avatar
I just flushed all circuits and road tested the bike. All looks normal but I noticed a 3" spot of brake fluid on the concrete below the ABS vent line.
My question is how often should I see this and is it pretty normal after a flush?
I'm supposing the system is regulating the reservoir level and it should cease to drain.
2005 KLT Graphite Gray
2003 F650GS Black
*Too slow for fast women
want2tour is offline
post #2 of 10 Old Jun 13th, 2016, 1:59 pm
Re: 2005 KLT ABS Question
If no errors on the dash... You should be okay. You probably just overfilled the module reservoir. Or when you pushed the pads back. Shouldn't be an issue.
BMW K1200LT 2007
BMW K1200R: "Drophammer" 2006
BMW R1200GS 2008
BMW K1200S 2007
Suzuki DR-Z400E 2000
Sachs MadAss FY125-20
mondrage is offline
post #3 of 10 Old Jun 13th, 2016, 2:08 pm Thread Starter
want2tour's Avatar
No ABS faults. And my spacers were same thickness as pads, so pistons were not pushed in after flush. Just used clean syringe to top up reservoir at the end so maybe a tad too much fluid.
Makes me wonder about the vent line though. Is it a one-way vent to prevent air from getting into the closed system?
2003 F650GS Black
post #4 of 10 Old Jun 13th, 2016, 2:16 pm
If you notice, the caps of the reservoirs drain into the same hose. So, if one of the circuits had too much fluid it'll drain there.
Will that hose prevent air from entering the system?
I don't think so... But it helps. Since there's no air coming in, it doesn't drain fast if you tip the bike. But I think it'll still drain if you lay the bike on the side.
Again, you should be fine. Just to be sure. Check the levels again.
BMW K1200LT 2007
BMW R1200GS 2008
BMW K1200S 2007
mondrage is offline
post #5 of 10 Old Jun 13th, 2016, 2:19 pm Thread Starter
want2tour's Avatar
I've already re-dressed the bike. I figure if level goes too low I'll see a fault.
2003 F650GS Black
post #6 of 10 Old Jun 13th, 2016, 2:22 pm
The correct procedure is to push the pistons all the way into the caliper (minimizes dead fluid) for the flush and subsequent reservoir top off. Then re- install the pads and seat them, and add no more fluid. This is for the 05 and up only. If fluid was added between flushes you will push fluid out the vent the next time to fully retract the pistons. The 05 + is not so sensitive to fluid level like the early bikes so when you do get the low fluid wig-wag it means your pads are worn out.
post #7 of 10 Old Jun 13th, 2016, 2:33 pm Thread Starter
want2tour's Avatar
John,
I did follow your DVD tutorial pretty religiously. I did fine tune the reservoir level with a clean syringe after the funnel was removed since I wasn't practiced at stopping the pump at the perfect level. After cap went back on and pads were seated, no more fluid was added.
Had no issues afterward, just wanted to understand how the vent line functioned.
KUDOS on the video!
2003 F650GS Black
post #8 of 10 Old Jun 14th, 2016, 3:34 am
My '05 did exactly the same thing a couple of years ago after we replaced the brake lines with Spieglers and new fluids.
In fact it "leaked" a couple of times (venting) I guess until everything settled down and it was happy with the amount of fluid that was in there.
Never a problem since (touch wood)
cws is online now
post #9 of 10 Old Jun 14th, 2016, 6:56 am
K100Dennis's Avatar
The vent line is straight to atmosphere, it exits on the right side of the swing arm just in front of the rear wheel. Yes, moisture can enter the reservoir (s) because the line is open. I installed a miniature dessicant filter in my line, it went in just behind the battery box. I'm not certain of the brand, I borrowed it from the instrument techs at work.
Dennis
1987 Yamaha TY250R
1991 Aprilia Climber 280
1988 K100RT (the pack horse)
K100Dennis is offline
post #10 of 10 Old Jun 14th, 2016, 10:19 am
Scouter-50's Avatar
Unless the dessicant is changed very often or recycled often it becomes useless with exposure to moist air rather quickly. We tried using dessicant dryers on our air control systems. Waste of time and money.
Robert
2000 K1200LT "Latifah"
1994 R1100RSL (wife's)
1981 R80GS
1976 R90S
2011 Bunkhouse Queen
Scouter-50 is offline
2005 k1200lt abs questions pdrrock K1200LT 22 Jan 4th, 2015 10:21 pm
2005 k1200LT ABS ibeamhd K1200LT 1 Aug 26th, 2014 3:07 pm
2005 ABS problem!! bowdon K1200LT 4 Apr 7th, 2014 6:52 pm
ABS Question fredthead K1200LT 3 Aug 7th, 2008 1:34 pm
ABS Question country-bum K1200LT 2 Jun 3rd, 2008 5:24 pm
