Stumped - Won't switch audio to headset - BMW Luxury Touring Community
post #1 of 6 Old Oct 14th, 2006, 7:55 pm Thread Starter
Enthusiast - KI6CDF
Tom_Becker's Avatar
Angry Stumped - Won't switch audio to headset
I'm in the middle of finishing up an install of an amateur radio transceiver. This required pulling the tupperware, windshield, nose cone and stingray.
Prior to the install everything was working 100%. Always had sound through helmet headset, GPS announced through headset and cell phone worked. Also, I have an iceLink for my iPod. Well that was before.
I installed the radio transceiver. It operates through the CB interface to the BC3. After completing the install to the dashboard I started buttoning things up, re-installed the stingray, etc.
I started testing things before putting back all the tupperware. Now, I am unable to get the BC3 to switch to headphones from the speakers. Anyone have any ideas? Yes, I've connected it and disconnected it from the battery multiple times.
Tom
Tom Becker
Rancho Mirage, CA 92270
2003 Titan Silver LTE "Cantabile"
2001 Black R 1150 GS
BMWMOA
AMA
IBA (SS1000, B2B-36)
KI6CDF
Tom_Becker is offline
post #2 of 6 Old Oct 14th, 2006, 10:11 pm Thread Starter
Enthusiast - KI6CDF
Tom_Becker's Avatar
Thumbs down Additional info...
I tried using the intercom through the helmet headset/mic. Its dead as a door nail. This suggests that power isn't getting to the bc-3.
Anybody know whether there are fuses or fusible links in the bc-3?
Tom
Tom Becker
BMWMOA
AMA
KI6CDF
post #3 of 6 Old Oct 14th, 2006, 10:54 pm
You need a break, go ride the GS with no phone, stereo, gps, radio, nothin!
Just you the breeze and the road...
Keith is offline
post #4 of 6 Old Oct 15th, 2006, 10:15 am
MSPSGT's Avatar
Many times this is switched using a relay under the seat. Open your seat and cycle your key a few times. Your should hear the relay "Click" as you cycle the key on and off. It may be the relay and/or the power that supplies the relay. Some dealers, when tapping power for the LTE equipment, used the heated seat circuit. You may want to check that. The easy way to check that would be to power up your heated seat, if it doesn't work you may find the problem. I have also found that the Relay BMW uses isn't sufficient and may need replacement. I hope this helps.
MSPSGT is offline
post #5 of 6 Old Oct 15th, 2006, 12:08 pm Thread Starter
Enthusiast - KI6CDF
Tom_Becker's Avatar
Talking Thanks for your help - Problem FIXED!!
You were very, very close to the problem. I started backtracking and checked the relay. Yes, it clicked. So, I'm thinking the relays ok. Well.....
I unbuttoned everything again and started checking obvious places where supply voltage was supposed to be. Got nada.... Made no sense to me. Kept checking with the voltmeter and decided to check the supply voltage coming out of the relay and nada once again. Hmmmm. Bad relay?
I started looking at the relay - I'm thinking how am I gonna test this puppy and then I noticed the fuse. A fuse.... can't be the fuse could it? I pulled the fuse and damn it was blown. Replaced it - voila!!!
Thanks for re-directing me from making things worse. I was gonna dive into the bc-3 and start probing around. I surely would've caused myself more grief.
Tom
Tom Becker
BMWMOA
AMA
KI6CDF
post #6 of 6 Old Oct 15th, 2006, 12:12 pm Thread Starter
Enthusiast - KI6CDF
Tom_Becker's Avatar
Talking Problem fixed!
Keith,
I didn't do the ride but I did sleep on it. See below.
Today, I put the beast at least partly back together. And yes, I do need to ride.
Tom
Tom Becker
BMWMOA
AMA
KI6CDF
Garmin 2730 audio connection to Autocom wcarter GPS 5 Jan 8th, 2011 10:12 am
Garmin 26xx/27xx audio problem bmwhd GPS 17 Apr 2nd, 2010 11:32 am
Garmin 2730 Audio Help Needed for 02' k1200lt ehaughn GPS 7 May 18th, 2006 10:23 am
Radar Detector Audio With Voice II Options rexray Intercom, CB, & 2-Way Radios 14 Mar 9th, 2006 9:32 pm
Oops, I let out the magic smoke jkersh1 K1200LT 4 Oct 27th, 2005 9:36 pm
