Which Fluid is Green? - BMW Luxury Touring Community
post #1 of 14 Old Oct 13th, 2006, 9:32 pm Thread Starter
Noticed dark green oil drops on garage floor this afternoon, directly under bike. Which fluid is green?
_____________________
Brad Toliver
06 Ocean Blue
BToliver is offline
post #2 of 14 Old Oct 13th, 2006, 9:48 pm
Zotter's Avatar
Anti-freeze, I'd guess.
Tate
02 Mauve - my 'Light Truck'
Zotter is offline
post #3 of 14 Old Oct 14th, 2006, 12:19 am
strsout's Avatar
Anti-freeze is light green... not exactly dark, but right in the middle of the bike, that would be my best guess too.
Loma Linda - CA
IBA#14,458 - AMA
strsout is offline
post #4 of 14 Old Oct 14th, 2006, 4:15 pm
Talking
You've got a problem because the coolant fluid should be blue. Some one has run regular stuff in there. Find the leak and replace it with the factory smurf water.
captainasty is offline
post #5 of 14 Old Oct 14th, 2006, 5:24 pm
murray's Avatar
He's correct!
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #6 of 14 Old Oct 14th, 2006, 9:46 pm
What about tranny fluid? I havent changed mine yet but on my Harley's this stuff was almost pea green.
Coopjr is offline
post #7 of 14 Old Oct 14th, 2006, 10:01 pm
RonKMiller's Avatar
That brings up an interesting question: IF someone did run a non-compatible anti-freeze could the reaction between this and the original BLUE OEM BMW anti-freeze cause a leak?
Hmmmm.... stroking chin.
What year is your scoot, and maintenance history would be helpful.
Never seen green tranny fluid - but then again...
"Like Butt-ahh!"
RonKMiller is offline
post #8 of 14 Old Oct 14th, 2006, 10:34 pm
Amsoil ran their engine oil a greenish/blueish color for a bit; however, once put in the engine, it doesn't take long to darken/blacken as it picks up the leftover old oil from the case galleys; so unless the engine oil wuz *just* changed, using Amsoil, his "green oil drops" shouldn't be from that source. The Amsoil tranny lube wuz a honey color, IIRC.
Location of the drippage in relation to rider pegs or centerstand bracket might help folks with suggestions.
post #9 of 14 Old Oct 14th, 2006, 10:58 pm
grifscoots's Avatar
What does it taste like?
-=grif=-
Grok
grifscoots is offline
post #10 of 14 Old Oct 14th, 2006, 11:08 pm
tmgs's Avatar
I was thinking my BMW coolant is blue as well
Tom
Tom
tmgs is offline
post #11 of 14 Old Oct 16th, 2006, 11:54 am
Tom
you know mine is dark blue (somewhat greenish) and the owners books don't specify what anti-freeze to use (or I could not find it). Does it have to be BMW coolant?
Check your coolant reservoir to see if it is low when cold.
2013 BMW Damask Red K1600GTL
2014 BMW K1600GTL-E EXCLUSIVE
2001 Honda C-250 Helix
Smokin'
SmokinJoe is offline
post #12 of 14 Old Oct 16th, 2006, 12:35 pm
Talking
The smurf water has stuff not in it (I don't remember what) that the others do. The factory made a special blend for the components inside. I think it was something to do with the nitrades. I think your local robber has it for about $15 a gallon, so not bad but not good either. It's not something that you change all the time so not to bad of a cost.
Pull the lower hose on the pump and you will be able to drain the block and radiators. It's not a bad job at all. You should also fill it up with regular water and flush out the "evil" then fill with the good stuff. Happy Smurfing
post #13 of 14 Old Oct 16th, 2006, 3:12 pm
AlaskaFish's Avatar
Cool
It could easily be some Prestone coolant, as this is a bright green color. The real test is not to taste as Grif suggests, but rather to smell it. If it smells sweet, it's Anti-Freeze! And it may not be all bad if someone has substituted something other than the BMW Coolant, as long as they were cognisant of the requirements that BMW has for the Coolant.
If it is Coolant, and you notice it when you first shut down in real hot weather, it may just be the expansion tank overflow. Especially if you have topped it off recently, as it may have gotten over-serviced. Just a thought.
John & Marilyn Fisher
'00 K1200LTC "Katie"
'95 Triumph "Tigger"
Hillsboro, Oregon
AlaskaFish is offline
post #14 of 14 Old Oct 16th, 2006, 3:56 pm
Ben Franklin's.
J.M.J...
Dcn Channing
Brake Fluid Change Ouestion patrick2000 K1200LT 0 Oct 8th, 2006 4:59 pm
vent hose leaking fluid alanforn K1200LT 3 Aug 12th, 2006 11:48 pm
Brake fluid level....none visable at sight glass ltlfeat K1200LT 11 Aug 11th, 2006 12:04 pm
Does Old Brake Fluid Smell? Jerrod Maguire K1200LT 7 Dec 13th, 2005 3:00 pm
Brake fluid indicator issues Rich_in_Tampa K1200LT 2 Oct 2nd, 2005 11:30 am
