Help Starter??? - BMW Luxury Touring Community
post #1 of 5 Old Oct 12th, 2006, 3:23 pm Thread Starter
bulletbill's Avatar
Help Starter???
Started to leave on a camping trip, packed the trailer (UNIGO) Hit the starter button and the battery is dead.. OK it's about 3 years old, so got the spare off the shelf. installed battery, hooked up the positive touched the ground and the starter turns over???? Ideas???
Bill Jennings, fhp
Denison, TX
BMW States
BMW years and miles, 32 years 500K+
AMA, CMA, IBA, POG, MSF, FHP, etc
'99 K1200lt
'76 R900/6
Various Vintage Dirt Bikes
-Greeves (Sold), Pentons, Hodaka, etc.
Remember you are not lost till you run out of gas!
bulletbill is offline
post #2 of 5 Old Oct 12th, 2006, 3:57 pm
Hey, Bill - three or four of the "similar threads" listed at the bottom of the page of your post will lead you to the fix for the stuck starter syndrome. HTH.
post #3 of 5 Old Oct 12th, 2006, 5:56 pm Thread Starter
bulletbill's Avatar
Help Starter??
Hep! Common problem, pulled the starter relay hit it with a small hammer, problem solved.. So while I have the stuff off called Plano "no starter relay in stock". So Chicago BMW is overnighting a new one.
Thanks for the replys
Bill Jennings, fhp
Denison, TX
BMW States
'99 K1200lt
'76 R900/6
post #4 of 5 Old Oct 12th, 2006, 7:23 pm
zippy_gg's Avatar
I like your course of action! Sometimes that's what it takes to get throught that thick German skull!
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #5 of 5 Old Oct 13th, 2006, 1:12 am
Glad you were able to figure it out in a matter of hours. Sometimes you can unstick the relay by charging or replacing the battery then making the final battery connection with the starter button held down. Many folks have done that and kept on riding just fine as long as the battery stays charged.
Replacing your "bad" relay with a new one of the same vintage will just get you back in the same situation if your battery goes dead again later. BMW's fix is to provide a newer relay that is wired such that it won't attempt to close if the trigger voltage is too low. But since you've already torn it down that far and a new relay is on the way, I'd just install it then get going on your trip.
Maybe during your next full 12K service you can change to the newer style relay. Or just keep the battery charged and forget about it. And be glad it happened at home, rather than in the middle of nowhere.
HEEELP! Stuck Starter Tim_in_NJ K1200LT 13 Nov 22nd, 2012 4:13 am
starter stuck ?? MLHAYES K1200LT 4 Sep 9th, 2006 8:35 pm
Starter problems Yiet K1200LT 5 Aug 14th, 2006 2:32 pm
Starter Sprag Clutch TimVipond K1200LT 3 Nov 17th, 2005 3:33 pm
