Calling all Gurus - BMW Luxury Touring Community
post #1 of 24 Old Oct 11th, 2006, 9:30 am Thread Starter
Steve_R's Avatar
Red face Calling all Gurus
Let me setup my situation, give the facts as they stand now, and then ask for advice.
Situation: I'm 546 miles from home in Columbus, OH. The bike feels like it has a little wiggle in the end at slow speed, <35MPH. >35MPH it goes away and is smooth as glass. My plan was to leave here today and head toward Clinton, IA, then down to Little Rock on Friday, and return home on Tuesday. A total of 1500+ miles in the next week.
Facts: Spinning the rear tire there is no drag. There is no play side to side. No play up or down as best I can tell. There is no noise other than the pads on the rotor. I do get a clunk as the tire spins at the same place in the rotation, that sounds and looks like it is coming from the rotor.
Advice: Do I head for home today, where I know I've got 2 dealers available and with one I know for sure exists between me and there? Or do I do like everyone says and "Just Ride It?" Is there something else you'd look at, pinion bearing, rear end seal, etc?
TIA
P.S. I'm not even going to mention the weather.
On His Ride,
Steve
KA5MTE
'00 Unigo - Dragon's Egg
Have you
bmwlt.com lately????
Steve_R is offline
post #2 of 24 Old Oct 11th, 2006, 9:42 am
Me? First thang I'd do is check tire pressures and look/feel for tread separation/bumps/etc. Next thang I'd look for is oilage, spillage, fluidage, leakage, and seeing none, ride on. Next thang I'd do is look in my Anonymous book for a dealer nearest Columbus; call 'em and describe the deal; ax 'em if they're prepared for a VOR (vehicle off road) lookee and verdict. What's on your route 'tween Columbus and Clinton? Any dealers?
I'll leave the good stuff to the gurus, Steve. Good luck, Bud. Oh, and one other thang; you did mount the rear shock correctly with no left over parts?!?! ;-)
post #3 of 24 Old Oct 11th, 2006, 9:49 am
Steve,
I don't know how to answer your questions, but if I can be of any help, I am in Xenia OH, about an hour ride from C-bus. I am off today and you can call my cell phone at 937-372-8019. I am sure you know there are two BMW shops in Columbus. I have used BMW of Columbus and they seem pretty good, except they are usually very busy. Good luck.
Steve McMullen
2004 LT
xenia is offline
post #4 of 24 Old Oct 11th, 2006, 9:55 am Thread Starter
Steve_R's Avatar
Tire pressure is fine. Matter of factly, I'm running 44/50 instead of the 42/48, just changed out the front radial 020 with 12K on it running these pressures. The rear was changed out at the same time and appears to have tread left and appears okay from the outside. Since I don't have x-ray vision , I can't tell about the inside.
No oil spillage, did a lubricant change all around on Satidee as a health check. Rear end good at 91K miles with just the normal sludge on the magnet. I'll go out to the bike and bring the Anon Book in and have a looksee.
Route to Clinton is I-70 due west to Indianapolis. I-74 to Moline, IL and then the river road up to Clinton. Just over 500 miles from here to there.
Bwahahahahahaha. Go get another cup of *$$ and a couple of donuts. Wish I could meet you guys for "Q".
Be safe.
On His Ride,
Steve
KA5MTE
Have you
Steve_R is offline
post #5 of 24 Old Oct 11th, 2006, 9:58 am Thread Starter
Steve_R's Avatar
Thanks Steve. I'll run by BMW of Columbus before I leave town and see what they say.
On His Ride,
Steve
KA5MTE
Have you
Steve_R is offline
post #6 of 24 Old Oct 11th, 2006, 10:09 am
bowlesj's Avatar
... The bike feels like it has a little wiggle in the end at slow speed, <35MPH. >35MPH it goes away and is smooth as glass. ...Facts: Spinning the rear tire there is no drag. There is no play side to side. No play up or down as best I can tell. There is no noise other than the pads on the rotor. I do get a clunk as the tire spins at the same place in the rotation, that sounds and looks like it is coming from the rotor.
It sure sounds like a medium worn rear tire. The wiggle feel could be increased due to your slightly higher than normal pressures and my personal experience is a worn rear is more noticeable after putting on a new front. Even though the edge of the rain channels may not be feathered or cupped, does the tire in general feel scalloped if you run your hand around the circumference?
Since everything feels tight, seems like a tire matter.
Good luck, we're heading to Columbus Friday.
2004 - LT - Anthracite
bowlesj is offline
post #7 of 24 Old Oct 11th, 2006, 10:49 am
DGM
Steve,
If you think that the rear end bearing is going, mine did have some outward signs before it gave out. The tire was making marks on the swing arm and the bike felt like I was on an uneven surface when I was going between 3 &5 mph. Other than that it rode smooth as glass at highway speed, even when it dumped oil all over the back rim.
Sounds like a tire to me, 35 mph a worn tire will make the bike wobble some.
Don
DGM is offline
post #8 of 24 Old Oct 11th, 2006, 11:02 am Thread Starter
Steve_R's Avatar
DOH!!! I'll go back and check. Thanks.
On His Ride,
Steve
KA5MTE
Have you
Steve_R is offline
post #9 of 24 Old Oct 11th, 2006, 11:03 am Thread Starter
Steve_R's Avatar
Thanks Don. By the way bring your coat. Highs in the low 40s up here this weekend.
On His Ride,
Steve
KA5MTE
Have you
Steve_R is offline
post #10 of 24 Old Oct 11th, 2006, 11:09 am
tmgs's Avatar
TIA
Are you running the radial B-stones? if so replace the rear , just in case it is one coming apart and you can not tell it, you do not want a rear or friont tire coming apart at 80mph down the highway, it is CHEAPER than your deductable if you wreck or a major TOW if you don't
OH BTW your safe, my major trip was cancelled so i'm about 5500 miles shy this season
Tom
Tom
tmgs is offline
post #11 of 24 Old Oct 11th, 2006, 11:16 am
bikesnumbnuts's Avatar
Warped disc hitting abs sensor ?.
regards bikenumbnuts
04 updated in graphite
in blighty.
bikesnumbnuts is offline
post #12 of 24 Old Oct 11th, 2006, 11:36 am Thread Starter
Steve_R's Avatar
Nope. BTDT. Thanks.
On His Ride,
Steve
KA5MTE
Have you
Steve_R is offline
post #13 of 24 Old Oct 11th, 2006, 11:47 am
kellenbenz's Avatar
Steve,
Are you pulling a trailer, or do you have the bike loaded more than usual. I have found that different tongue weights or loads can cause a little slow speed shimmy...Just a thought.
Ron
IBA 45658 MOA167437
Total BMW miles 509,508
Goldwing miles 238,383
kellenbenz is offline
post #14 of 24 Old Oct 11th, 2006, 11:59 am
I know this might sound stupid , but are all the wheel nuts tight ?.
04 updated
in blighty
post #15 of 24 Old Oct 11th, 2006, 12:15 pm Thread Starter
Steve_R's Avatar
Actually I'm running about what I normally run when I don't have the SWMBO onboard. So I'm beginning to think it is the tire (tyre).
On His Ride,
Steve
KA5MTE
Have you
Steve_R is offline
post #16 of 24 Old Oct 11th, 2006, 12:20 pm Thread Starter
Steve_R's Avatar
Thanks for the thought, I checked all those during the oil change this weekend just to make sure.
On His Ride,
Steve
KA5MTE
Have you
Steve_R is offline
post #17 of 24 Old Oct 11th, 2006, 12:26 pm Thread Starter
Steve_R's Avatar
John, I think you've nailed it on the head. This rear has 14K with tread still left. There are rough edges like the BT020s get when they start to feather. Called both dealers in Columbus, BMW of Columbus didn't have one in stock and NorthWest BMW, Honda, Suzuki, etc, only carries Metzlers. And I'm not going that route. Next call is to Cincinatti to see if they have one in stock.
Where's Joe when you need him?
On His Ride,
Steve
KA5MTE
Have you
Steve_R is offline
post #18 of 24 Old Oct 11th, 2006, 12:29 pm
I work in Columbus... 1.2 miles from BMW of Columbus. I'm here until at least 5:00 today if you need a ride or whatever.
cell: 740.974.3524
post #19 of 24 Old Oct 11th, 2006, 1:15 pm
bowlesj's Avatar
Steve,
Competition Accessories just west of you on I 70 in Springfield may have the tire you need. Also, a call to Iron Pony might be worth trying. They are in Westerville, north suburbs.
Try to Google them.
Try this Comp Acc has em
http://www.competitionaccessories.co...?Category=2359
bowlesj is offline
post #20 of 24 Old Oct 11th, 2006, 1:25 pm
NOGILLS2's Avatar
I had an experience similar at CCR and it turned out to be a slipped belt in the tire, I thought it was a front wheel out of balance, when I got home found a split in the tire wall, went out and kissed "The Beerburner" square on the mouth.
NOGILLS2
Booze Brother# 69
2003 K1200LTE "BEERBURNER" RIP 07/21/09
2006 Aluma Trailer "AFTERBURNER" SOLD
2007 ST1300ABS "Quicksilver"
NOGILLS2 is offline
post #21 of 24 Old Oct 11th, 2006, 1:34 pm
Just a quick FYI. Tri-State BMW in Cincinnati is closed, although a group of motorcycle mechanics did take over the location.
xenia is offline
post #22 of 24 Old Oct 11th, 2006, 3:20 pm
Exclamation Spare Metz
Steve,
For-what-it's-worth....I keep a spare new Metz rear tyre in the garage for emergences.
If you (or any one on the board) might need one, I'll be glad to ship it to you.
wardenross is offline
post #23 of 24 Old Oct 11th, 2006, 6:39 pm
zippy_gg's Avatar
Exclamation
I have a spare rear BT020 in my garage as well, in case someone needs one in a big hurry, although in the past www.swmototires.com have been very fast at shipping tires to me, both Metz and BT020.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #24 of 24 Old Oct 14th, 2006, 4:59 pm Thread Starter
Steve_R's Avatar
Got the answer
Couldn't find a BT020 anywhere near Columbus that I could get installed that day. As a matter of fact, one of the dealers in Columbus doesn't even carry BT020s.
After a careful inspection of the bike and the rear tire, I started a sub-light ride home on Wednesday and Thursday. Made it with no other issues except the rear end was a little twitchy >35 but smooth at ~50. Called both of the local dealers yesterday to find out that one had the correct BT020 radial. I told them to put my name on it and I'd be in tomorrow.
After having breakfast with my lovely wife it was off to the dealer to get the tire replaced. The tech moved the bike into the tire changing area. I looked at the tire before he pulled it and the light hit the tire in such a way that I could see the a small buldge on the left hand side of the tire. So it looks like I've got one of the BT020s with belt separation. The buldge was not there are the beginning of the day Thursday or Thursday evening, but it sure was there today.
The tech pulled the tire and proceeded to put the new tire on. While he was mucking with the tire and wheel before putting it back on, I looked in on the swing arm and there were a couple black marks on the it. I checked the right side of the old tire and there was another buldge about 180 degrees opposite the one on the left side.
While putting the right tire back on, the tech noticed some oil on the final drive right at the boot. He opened it up and fresh oil spilled out of the boot onto the floor. So besides having a bad tire, it looks like I've got a leaking seal at the tranny output shaft and possibly at the pinion seal. I'll know more on Tuesday.
So it looks like Someone is watching over me. And Grif "Thanks for the replacement bell!"
On His Ride,
Steve
KA5MTE
Have you
Steve_R is offline
Do you hear the highway calling? Tallyho North West 0 Sep 11th, 2006 5:40 pm
Calling all Route Masters . . . dfinazzo GPS 11 Sep 2nd, 2006 11:57 am
Calling all Nut and Bolt Gurus zaphod Ergonomics & Rider Comfort 10 Jun 6th, 2006 11:00 am
Calling All Clutch Gurus early1 K1200LT 22 Oct 18th, 2005 12:09 am
Gang, please don't bother calling the hotel yet eljeffe Curve Cowboy Reunion 0 Oct 11th, 2005 1:11 pm
